wh315-8
50” D series Tiller Top Lift Link measurement
wh315-8
Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
Edited by wh315-8
Reference picture
  • Similar Content
    • Rick3478
      By Rick3478
      - SOLD - Moderator may remove at will
      0736TL04 tiller and fitments needed to mount on many long frame, C series, 300/400/500 series tractors.
      Notable details:
      Gearbox and tines have low hours.  Tarp had blown off mid-mount idlers and got rusted up, probably need penetrating oil and new idlers.
      Axle mount is rusty/restorable/useable.  Lift cable has nylon worn through on one side (they tend to do that).  One rear jackshaft bushing
      has couple ears broke off, and jackshaft e-clips are lost (edit: found those).  Belt is original.
      Pick up in my back yard near Elida, Ohio.  Bring help to load, or ramps or something.
      I think it may be worth $100.
      - or -
      Would consider trade for a used car or truck hood that I can use for a sled to drag firewood and equipment around on, something kinda
      rounded without points or ridges to catch.  Have been using an S-10 hood for years, and it's wearing through becoming less useable.
      What 'cha got?
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
