Dreamcatcher 102 #26 Posted January 31, 2023 Will a snowblower off of a 280 fit on my 417? I believe i've located one. 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #27 Posted January 31, 2023 4 minutes ago, Dreamcatcher said: Will a snowblower off of a 280 fit on my 417? I believe i've located one. You'll have to be more specific, 280? If that's a vertical shaft Wheel Horse model then no, the mounts & pulley location are different... 2 Share this post Link to post Share on other sites
Dreamcatcher 102 #28 Posted January 31, 2023 6 minutes ago, Blasterdad said: You'll have to be more specific, 280? If that's a vertical shaft Wheel Horse model then no, the mounts & pulley location are different... Yes, the owner says it came off of a Wheel Horse 280. Unfortunate, it is close. Share this post Link to post Share on other sites
Blasterdad 3,163 #29 Posted January 31, 2023 (edited) You will need one tha fits a C-Series or 300 400 or 500 Series or a 2 stage... The single stage will look like this & have the drive pulley on the left (facing it) & lines up with the PTO. Edited January 31, 2023 by Blasterdad 2 1 Share this post Link to post Share on other sites
Dreamcatcher 102 #30 Posted January 31, 2023 Would a 5xi snowthrower work on my tractor? Share this post Link to post Share on other sites
peter lena 9,779 #31 Posted January 31, 2023 @Blasterdad noting your blower drive belt set up , do anything to improve / verify the idler pulley spin up ? also the spring tensioned idler frame mount areas ? did a grease change in bearings , and increase the tension spring pull , also changed the trunnion to a heim joint ,and freed up the pto lever start . washers / grease , like this .looking at washer fill in on start of pto lever , that is also a ground rail, note the battery cable in last photo , going to engine corner / frame , from battery ground bolt . and plug in for battery tender . that ground enhances , rectifier charging , and head light connection , also wakes up your amperage gauge . any nagging problem , was removed , pete 2 Share this post Link to post Share on other sites
peter lena 9,779 #32 Posted January 31, 2023 @TractorEd that battery / related area is a gold mine of improvement opportunities ! once I improved a spot , just kept going , be prepared to be told you can't do that . but you can , and things will work easier / smoother , years on my stuff now , pete 1 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #33 Posted January 31, 2023 1 hour ago, Dreamcatcher said: Would a 5xi snowthrower work on my tractor? No Sorry, I should have said not the xi series 11 hours ago, Blasterdad said: You will need one tha fits a C-Series or 300 400 or 500 Series or a 2 stage... 1 Share this post Link to post Share on other sites
Dreamcatcher 102 #34 Posted January 31, 2023 Another snowthrower question. Will the 79360 work with the 417? Thanks ahead of time 1 Share this post Link to post Share on other sites
Dreamcatcher 102 #35 Posted January 31, 2023 1 hour ago, Dreamcatcher said: Another snowthrower question. Will the 79360 work with the 417? Thanks ahead of time Thank you for verifying this on another thread Eric 1 Share this post Link to post Share on other sites
Dreamcatcher 102 #36 Posted February 1, 2023 Should/can I lubricate the PTO pulleys ? They run very free with a faint squeak. What are the other lubrication points that I should check? Deck bearings, spindles, anything else? Thanks all 1 Share this post Link to post Share on other sites
ebinmaine 77,524 #37 Posted February 1, 2023 4 minutes ago, Dreamcatcher said: Should/can I lubricate the PTO pulleys ? They run very free with a faint squeak. What are the other lubrication points that I should check? Deck bearings, spindles, anything else? Thanks all @953 nut 1 Share this post Link to post Share on other sites
953 nut 64,300 #38 Posted February 1, 2023 3 minutes ago, ebinmaine said: @953 nut EB, I figured Greasy Pete @peter lena would want to cover that subject. 3 Share this post Link to post Share on other sites
peter lena 9,779 #39 Posted February 1, 2023 @Dreamcatcher https://www.amazon.com/Stens-280-750-Heavy-Duty-V-Idler-92-7103/dp/B001OK9YO8/ref=rvi_sccl_4/133- ,notice the wide side grease shields ? as opposed, tiny tight original ? easily remove those shields , clean out original grease , add a hi temp 500 deg + grease , reseal . its the collective drag of every related bearing, that makes the issue .regularly , did this to all my related , pto driven attachments. realise this is a tuff talking spot , but its the lubrication failure , due to hi stress / heat that starts the noise . lucas marine grease , is available , and has a very hi heat level , bearing must be totally cleaned out , and carb cleaner flushed , before regrease . my mule drive bearings , used to whyne with noise , none of my bearings , make any noise now . only a suggestion , but every rotational part should have a better hi temp grease . have this set up on y 3 units , it works , quietly , pete 3 Share this post Link to post Share on other sites
Dreamcatcher 102 #40 Posted February 1, 2023 3 hours ago, peter lena said: @Dreamcatcher https://www.amazon.com/Stens-280-750-Heavy-Duty-V-Idler-92-7103/dp/B001OK9YO8/ref=rvi_sccl_4/133- ,notice the wide side grease shields ? as opposed, tiny tight original ? easily remove those shields , clean out original grease , add a hi temp 500 deg + grease , reseal . its the collective drag of every related bearing, that makes the issue .regularly , did this to all my related , pto driven attachments. realise this is a tuff talking spot , but its the lubrication failure , due to hi stress / heat that starts the noise . lucas marine grease , is available , and has a very hi heat level , bearing must be totally cleaned out , and carb cleaner flushed , before regrease . my mule drive bearings , used to whyne with noise , none of my bearings , make any noise now . only a suggestion , but every rotational part should have a better hi temp grease . have this set up on y 3 units , it works , quietly , pete Very helpful thank you! Please complete this list of items to clean/lubricate. PTO bearings, mule bearings, deck bearings, and steering. Anything else? For pulleys like in the mule do I just sort of mush the grease in? I guess there might be a youtube video? 1 Share this post Link to post Share on other sites
peter lena 9,779 #41 Posted February 1, 2023 @Dreamcatcher typically the mule bearings are the same as the deck spindle bearings , use a small putty knife or a slim pocket flat screwdriver for that seal pop, no need to beat them up ,pop right off. pto inner cone needle bearing , thorough wipe out , very slim amount of grease , or it slings to clutch face , the hi temp grease is typically polyurea rated , ant sling . once the bearings clean , repack to same amount as original , mush in . note , added heim to replace trundle , eliminate sloppy fit . also show added washers at start of pto lever connection, makes it solid/ smooth , that battery rail is a gold mine of improvement opportunity . ask away , glad to help , pete Share this post Link to post Share on other sites
Dreamcatcher 102 #42 Posted February 1, 2023 29 minutes ago, peter lena said: , added heim to replace trundle , eliminate sloppy fit . I apologize, i'm not familiar with what this is. Share this post Link to post Share on other sites
peter lena 9,779 #43 Posted February 1, 2023 @Dreamcatcher open up the lever action picture above , top of battery / pto lever mount start point , go down to second / third pictures , that is a ball swivel HEIM JOINT . much better than the original trundle hook up wich is usually sloppy in its function . just part of the complete elimination of the original intended set up . if you like yours , leave it , no problem pete 2 Share this post Link to post Share on other sites
ebinmaine 77,524 #44 Posted February 1, 2023 1 hour ago, Dreamcatcher said: I apologize, i'm not familiar with what this is. 31 minutes ago, peter lena said: HEIM JOINT @Dreamcatcher Here's a picture of a heim joint. This is on the 1975 c160 restoration that we're doing right now. While I was poking around for this picture I found one of the transmission oil filter that you need. This one's NOS so the box looks a little bit different. The black Beastie looking thing on the floor is called a DOG. Those are not mandatory for a tractor but sometimes help. 2 2 Share this post Link to post Share on other sites
lynnmor 8,644 #45 Posted February 1, 2023 1 hour ago, ebinmaine said: While I was poking around for this picture I found one of the transmission oil filter that you need. This one's NOS so the box looks a little bit different. The black Beastie looking thing on the floor is called a DOG. Those are not mandatory for a tractor but sometimes help. That black beast and the filter were made in the USA, new 51410 filters are made in China. 1 Share this post Link to post Share on other sites
ebinmaine 77,524 #46 Posted February 1, 2023 3 minutes ago, lynnmor said: That black beast and the filter were made in the USA, new 51410 filters are made in China. Exactly why I got NOS. Filter. Not the dog. Dog is regular stock. 3 1 Share this post Link to post Share on other sites
peter lena 9,779 #47 Posted February 1, 2023 @ebinmaine did not know you could get a dog in a black color , and a heim joint in a silver color , did not know either existed , live in closet, pete 4 Share this post Link to post Share on other sites
Dreamcatcher 102 #48 Posted February 2, 2023 Where are the heims purchased? Yes I'm familiar with Jeep guys building suspension parts with them; my question was more of where are they used on the WH. Tractor supply? Admittedly, i've never made anything with them. Are the rods also sourced from the same place? Looking at the link for the PTO lever, I also had some additional questions. Where do I get teflon washers? The rod and/or the heim have to be modified to work together? Share this post Link to post Share on other sites
Dreamcatcher 102 #49 Posted February 2, 2023 What is the correct battery group? U1? 1 Share this post Link to post Share on other sites
953 nut 64,300 #50 Posted February 2, 2023 33 minutes ago, Dreamcatcher said: Where are the heims purchased? Yes I'm familiar with Jeep guys building suspension parts with them; my question was more of where are they used on the WH. Tractor supply? Admittedly, i've never made anything with them. Are the rods also sourced from the same place? Looking at the link for the PTO lever, I also had some additional questions. Where do I get teflon washers? The rod and/or the heim have to be modified to work together? You can purchase just about anything hardware related at McMaster-Care. https://www.mcmaster.com/rod-ends/ https://www.mcmaster.com/washers/ 1 Share this post Link to post Share on other sites
