TractorEd
‘79 C-161 - Parts?
TractorEd
I know WD stands for Water Displacement, but the back of the can specifies many miraculous uses, including penetrating rusty nuts, bolts and valves.
I did find a can of Liquid Wrench Penetrating Oil on the shelf and I gave that valve the 1st dose of it.
Edited by TractorEd
ebinmaine
Give a watch at Project Farm YouTube channel about the penetrating oils and you'll see what some of "better" ones do vs what they claim.
ebinmaine
4 hours ago, TractorEd said:
@ebinmaine
Here’s a couple pics of that tow valve.
I got a little angry at her, LOL.
Here's the tow valve from my 75 C160 Automatic Restoration project currently underway...
I figure to JB Weld the nut on.
TractorEd
Nice to see what it looks like and how deep the threads are.
Great idea with that nut!
TractorEd
All I’m able to work on this weekend is reattaching the hood and headlights.
Hood went on easy enough, but then I realized it wouldn’t open very far.  Someone used a bolt in one of the holes in the front hitch plate to keep it from opening all the way.  Had to remove the hood, take that bolt out, then reinstall the hood.
Like Mustie1 says, “we do it right ‘cause we do it twice”!  lol
I put 2 new led’s I got from iSaveTractors in the headlight sockets, hooked up the wires, but they weren’t working.  I had the taillights working just a couple of days ago!
problem was dirty contacts on the light switch.  Took the fuse out and cleaned all the contacts in there too.
Finally
Oh, and that’s a new lens with the sticker on it.  Wish someone made ‘em like the original lenses.
Edited by TractorEd
  • Excellent 2
ebinmaine
Good catch.
Be sure to install multiple ground wires as well.
When I build a harness I quite often will do an individual ground wire going to every component that's electric. You could see that as overkill but it's saved me a time or two....
  • Like 4
TractorEd
1 minute ago, ebinmaine said:
Good catch.
The wiring certainly needs attention.  I did run a ground straight to the new rectifier.  I’m going to need to do something about the rest of the wiring though as it’s , um, not pretty.  It could always be worse though!
rjg854
Actually the saying goes......
We do it nice
because
We do it twice
:laughing-rolling:
  • Haha 2
TractorEd
Is this lift lever extension part of a snow blade/blower kit? Or home made?
That hairpin clip came with it but isn’t currently doing anything.  Must have lost the original handle and used a wooden one that was laying around.
Edited by TractorEd
  • Haha 1
Blasterdad
I'm pretty sure that is home made, I like it though, I never liked the lift lever location of the C-161, have to reach down to use it...
ebinmaine
What's the stock one look like?
Blasterdad
  • Thanks 2
ebinmaine
26 minutes ago, Blasterdad said:
Looks like that home shop high grab would be quite the improvement
Blasterdad
Indeed, :wh: moved it there whe they changed the tower design in '78.
I like the older C-160 design better, the handle was higher & everything out in the open...
ebinmaine
Yeah that's how my 1975 is of course but even then. You put some great big thick gloves on and my ape hands and it still could be a little higher.
May have been @squonk I think that extended one. I like his design.
Blasterdad
I've thought about doing something similar but, I just have to remind myself "it sure beats the manual lift". :rolleyes:
squonk
Ask and ye shall receive!
TractorEd
6 hours ago, Blasterdad said:
IMG_0490.JPG.01473167e3e28e9160bfa6c77c7b4443.JPG@Blasterdad what is 1 (and is that just a 12V cigarette lighter you installed), 2 (extra switch) and 3 ?
Edited by TractorEd
Blasterdad
Number 1. Yes, it's a cigarette lighter socket, the older :wh:'s came with one, when they changed the black dash cover they left it out, but the hole for it is still in the dash behind it.
It's for the LED Amber beacon.
Number 2.  This is the L-R switch for the electric chute control on the snowblower.
Once again it's in a factory hole that was for an electric clutch, & is covered up by the newer style dash.
Here is a pic of an older style dash with the holes...
Number 3. This is a LED license plate light I mounted to an old magnetic Hide-A-Key box wired to the light switch. It lights up the dash & controls perfectly without putting glare on the windows of the cab. All lights are controlled by the dash switch except the beacon.
I don't like drilling holes in my :wh:'s if I can avoid it, that's why I mounted it on a magnet, works great.
IMG_0483.JPG.32a22baeb81d50661e11b739c87a5a98.JPGIMG_0515.JPG.e4842083671fe45a4b455090278a5682.JPGIMG_0514.JPG.164d4c45b499a82be6a696948ab2c8fd.JPGIMG_0516.JPG.297ec67aed1f55d523b9df37107c2e86.JPG
  • Excellent 5
ebinmaine
Alright. Alright.
That's pretty smahhtt!!
TractorEd
I will have to find a couple of those me thinks.
Genius!  Fantastic even!
TractorEd
3 hours ago, Blasterdad said:
I can see why the snow doesn’t want to fall near you!
  • Haha 1
TractorEd
This is the wiring for the taillights.  I went with the heat shrink instead of the tie.
Unfortunately, I’ll be redoing the ground wire so I can run it to, maybe the battery.  I like doing things twice!
Edited by TractorEd
  • Haha 2
TractorEd
And here’s where I’m currently at with it.
Fender & seat installed, wiring routed and working.
Note: That’s a used seat from the C-100 and not an original seat either.  Better pics to come …
Edited by TractorEd
ebinmaine
When you have enough ground wires that the harness is starting to look like black spaghetti it's just about right 👍
  • Similar Content
    • BruceK
      By BruceK
      Can I pick some brains please? It's just a thought at this stage but I'm wondering whether I could upgrade my C161 so I can get rid of my old Ferguson TEF tractor and topper to save on space and tidy up my outdoor area a bit. The trouble is I need to regularly cut a 2 acre paddock so want to be able to tow a decent finishing mower like a 4ft Wessex or something similar. Has anyone tried fitting a mechanical PTO to an old machine like this or will I have to stick to a self-powered tow-behind mower for the rough work? I could investigate putting in a more powerful engine if I can find one. Any ideas would be welcome. Thanks in advance
    • KP Cool
      By KP Cool
      Hello, Have a C-161 Manual transmission Kohler engine.
      I had been mowing a good bit and thought I would wash grass and dirt off it.  Well apparently got something wet and now may have shorted something out. After drying out, something is still wrong it tried to start a couple of time, but now nothing, unless I use two jumpers from the switch connector (and I even replaced switch and still have issue).  It will start and run and lights will work etc. except with way I have it jumper-ed it won't shut off unless you disconnect the 1st jumper.
      To start and keep it running, use two jumper wires from the switch connector (five blade).  1st. jumper wire from the black wire to the positive on the battery and 2nd jumper wire from red wire to positive on the battery to engage the starter to start it.  hope that makes sense, see pictures  (Note - the amp meter was showing charging even though switch off and even disconnected, so to rule the amp meter I by passed it.).  Did the the one relay block get too wet and short out?   Other side note,  have had some issues with mice and even had a black snake in it this morning, guess it was looking for food.  Do not see any wires chewed, and it was running fine until hosed off dirt and grass clippings.
      Thoughts or suggestions??
      Thanks.
    • D_Mac
    • D_Mac
      By D_Mac
      Well fellas since I had to sell off my Wheel Horses I felt like I didnt belong anymore. The Lambert and the Speedanza are cool but THIS IS a Wheel Horse Fourm. Well guess what....... Im back in ! Picked this up a little while ago. Saw it on CL and jumped right on it. Not a model I know anything about but it does say Wheel Horse on the side of it ! I am so excited to have it and the best part is that it runs and drives!!! It does need some work... I think the hydro is leaking as a saw a puddle of oil on top of the deck. Checked the dip stick and was hardly any in there. When you raise the deck it seems to come up higher on one side then the other. Seat is horrible, someone glued vinyl on it. Front head light lens busted, rear one is busted and no lights work. came with wheel weights for the rear but nothing else. Still trying to figure it out. I just got it home and off the truck. As usual any info I would love to hear about it. I dont know the year, I believe thats a 16 hp Kohler, not sure but it runs really good. Not a fan of driving it by a stick, seems like something you have to get used to then maybe like. Right now it just seems funny but I only did a little lap in my yard. I think I got a smoking good deal on it that makes me even happier.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
