RedPower47 111 #1 Posted January 17, 2023 Picked this 417-A up 3 weeks ago in someone's barn, last time it ran or moved was unknown. When you put your mind to something its amazing what you can accomplish! Brought it home, power washed it, found the starter ears were broken off the block so I repaired them, Also #2 cylinder had bad head gasket, did a full tune up on the KT17 while I was there. Added an oil pressure gauge to help tell the life of the engine. cleaned the fuel tank and put all new lines with a rebuilt carb. The old kohler fired off within 3 cranks and is putting out about 60IBS of oil pressure. Re wired a lot of loose ends and splices that were cut in over the years. Brand new Carlise turf savers up front and True Powers in the rear. Stripped every piece down to bare metal and primed and painted all in 3 weeks! I absolutely love this stuff. 4 22 2 Share this post Link to post Share on other sites
Achto 31,513 #2 Posted January 17, 2023 Most excellent work !!! 3 Share this post Link to post Share on other sites
peter lena 9,843 #3 Posted January 17, 2023 @RedPower47 excellent recovery on that ! also regularly use STA BIL in all my fuels , in recovering a , used engine , have also regularly used rislone zink additive , in my run in of a used engine , the cleaning and running ease is apparent , solid job on that , pete 2 Share this post Link to post Share on other sites
peter lena 9,843 #4 Posted January 17, 2023 @RedPower47 like to run in an unknown engine with heavily treated fuel , just to see how it sounds / reacts , no screaming , just function , do a hot oil change , been using rislone zink , small measuring cup , to a multi weight oil 5-30 for winter , the combination definitely has a smoothing running ease , as it loosens up and cleans / flushes , passages , frees up ring glands , also use my pto lever drive to enhance oil to that side thrust area , without an attachment , just to engage it . check over every movement area , super lube oil , in all my related cabling , throttle / choke , should be smooth / easy . always looking for any trouble spot , enhance grounding , for related electrical operation. done this for years , just some ideas , pete 2 Share this post Link to post Share on other sites
Ed Kennell 45,662 #5 Posted January 17, 2023 Wow, and in 3 weeks. My 417 is my dedicated mower..cranking a 48" SD. Love that KT growl while mowing up a steep hill. 6 Share this post Link to post Share on other sites
RedPower47 111 #6 Posted January 17, 2023 @Ed Kennell they sure do have a nice growl to them Ed. 4 Share this post Link to post Share on other sites
Bill D 2,729 #7 Posted January 17, 2023 Beautiful work. How many hours on the clock? 2 Share this post Link to post Share on other sites
RedPower47 111 #8 Posted January 17, 2023 @Bill D right around 1100 and thank you ! 1 Share this post Link to post Share on other sites
c-series don 11,787 #9 Posted January 17, 2023 Nice save! Most people would have seen that as scrap metal but you’ve turn it back into a nice tractor! I have a 417-A, it’s my dedicated snowblower tractor. Ed’s right those Kohler’s sound awesome under a load! What are your plans for it? 4 Share this post Link to post Share on other sites
RedPower47 111 #10 Posted January 17, 2023 @c-series don Im not sure yet, definitely holding onto it for now! ill let it sit in the garage nice and warm for the winter lol. 2 Share this post Link to post Share on other sites
Brockport Bill 2,275 #11 Posted January 17, 2023 spectacular !!!!! You can just go sit in garage this winter and admire your craftsmanship 5 Share this post Link to post Share on other sites
Brockport Bill 2,275 #12 Posted January 17, 2023 i did the black wheel rims on one of my C175s -- like the look -- but next time i will use the glossier paint you used on yours - i also did the footrests in black for an added black touch 5 2 Share this post Link to post Share on other sites
RedPower47 111 #13 Posted January 18, 2023 @Brockport Bill Thanks Bill! nice looking 175 you have there. 2 Share this post Link to post Share on other sites
Brockport Bill 2,275 #14 Posted January 18, 2023 53 minutes ago, RedPower47 said: @Brockport Bill Thanks Bill! nice looking 175 you have there. here's the '83 Series 1, C175 ----------- i've never tackled the "full restore" like you did -- you did awesome job - i've just done partial mechanical and body 5 Share this post Link to post Share on other sites
Tonytoro416 1,314 #15 Posted January 18, 2023 Beautiful tractor. Saved another one. What color red did you go with there ? 1 Share this post Link to post Share on other sites
RedPower47 111 #16 Posted January 18, 2023 7 hours ago, Brockport Bill said: Another nice looking tractor Bill! and there is nothing wrong with fixing things up here and there, i have done that plenty of times where you just take the bad parts of the body and freshen them up a little with some new paint! it takes a lot of dedication and motivation to do a full tear down and restore and a lot of people don't have the time or patients. Share this post Link to post Share on other sites
RedPower47 111 #17 Posted January 18, 2023 @Tonytoro416 Tony, I used Rust oleum Sunrise Red, i know a lot of guys use IH Red or Regal Red from Rust oleum but i think the sunrise is just a few shades brighter and looks a little better but that's just my opinion. I have painted plenty of Farmall's in my life and the IH red is definitely darker. 1 Share this post Link to post Share on other sites
c-series don 11,787 #18 Posted January 18, 2023 I too, am a fan of the sunrise red! I think for some reason though regal red looks better on the 60’s and earlier tractors. I’m not sure why? Here’s my C-161 with E-Z Rake dethatcher and C-165 hiding in the corner of the picture, both in sunrise red. 3 1 Share this post Link to post Share on other sites
RedPower47 111 #19 Posted January 18, 2023 I agree Don, I still like the look of Regal or IH but Sunrise just gives it a little more shine to it Nice looking 161 too 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,275 #20 Posted January 19, 2023 14 hours ago, RedPower47 said: I agree Don, I still like the look of Regal or IH but Sunrise just gives it a little more shine to it Nice looking 161 too i have used mostly the IH Red as well as the Regal Red -- but I like the suggestion of the Sunrise -- especially that its "brighter" ----- so might try that once -- but dont want it to not match other same tractor pieces..... so might do a mower deck, or plow first to see its appearance ----- or maybe i need "another" WH tractor to try it on all the tin ...........haha 1 1 Share this post Link to post Share on other sites
RedPower47 111 #21 Posted January 19, 2023 haha Good Idea Bill, yea definitely don't mix the two colors because sunrise is definitely brighter than Regal or IH. Share this post Link to post Share on other sites
