RT WH520
Snow Blower Sprockets
The bearings went on the two sprockets on the front of the snowblower. Any suggestions, recommendations on how to get them?
Thanks Rob
I got my from Tractor Supply. They are slightly different than factory as they have 1 more tooth. I had to add a half link to the factory chain length,
Read my note on the Chain Question 3 posts above this one for the sprockets.
I didn't realize these posts get reshuffled when a response is posted.  Look at the post asking about the chain on a tall chute blower
  • Similar Content
    • By Decker4
      Previously had this listed with a wagon. Sold the wagon and dropped the price.
      1984 Wheel Horse C-195 black hood edition
      19.5 hp twin Kohler engine
      3 point hitch (NO rear PTO)
      60" heavy plow
      51" mower deck (That's without the guide chute attached; not sure if that's considered 60". )
      36" Snow thrower
      original owners manual
      Wheel weights (Tires are also filled, gel I think)
      Chains on front tires and parts for chains on the rear (rear chains in picture are not available)
      An assortment of other part, including heavy bar for the snow thrower, a pull chair, spare oil filter, etc.
      The tractor starts and runs well. It has some cosmetic issues but not what I would call damage. It's big, powerful, and a lot of fun.
      It starts, but the current battery is undersized, so while it starts fine in the summer, I've been using my truck to jump it in the winter. The easy solution is battery with more cold cranking Amps.
      The mower deck has been redone with some welding (heavy duty steel) where it rusted through. The center guide wheel it missing.
      The snow thrower works, but is currently missing a link on the chain, and the sprockets are worn.
    • By Bexter207
      So I have a 312 Wheel Horse. I have the Snow Blower attached and it was working great. I was using it last night when all of a sudden I heard a bang up near the the blower. I quickly disengaged the PTO lifter the blower and backed up to see if I had hit something. After inspecting i found that i did not hit anything. So I started clearing out any snow I realized nothing was stuck and the shear pins were still good. The augers had the normal amount of play. So I fired it back up and tried to engage the pto again it kind of bogged down and stalled out the engine almost. So I drove it to where i had better light. I could not see anything wrong still so I decided to try to engage it one more time to see if I could see anything. Well it started throwing so I decided to test it out and it worked fine. Then as I was going along it just stopped throwing again. So I don't know what it is. I plan on taking a look at the gearbox when I get home to make sure that's all set. Just thought I would check to see if any of you have suggestions of what I could check.
    • By tntatro
      Looking for plow blade and snow blower for C-160 8 speed. Have stuff for trade or will buy if price is low. Not for looks, just want usable stuff.
