SylvanLakeWH 32,722 #1 Posted August 2, 2022 So I’m thinking… Yard Art is cool… but an electric cruiser is cooler…. Have assessed nothing on the yard art, but thinking I could use something like this for a “push pedal to go” cruiser for the littles… floor boards etc. would be added to make it little feet user friendly… Thoughts from the brain trust greatly appreciated… just spitballing at this point. ———- 36V Electric Brushless DC Motor Kits 1000W BLDC Mid Motor 3100RPM 27.7A with 30A Speed Controller Handlebar Twist Grip Throttle Go Kart Motor Kit 3 9 Share this post Link to post Share on other sites
davem1111 2,417 #2 Posted August 2, 2022 32 minutes ago, SylvanLakeWH said: 36V Electric Brushless DC Motor Kits 1000W BLDC Mid Motor 3100RPM 27.7A with 30A Speed Controller Handlebar Twist Grip Throttle Go Kart Motor Kit Does it have a reverse? 36V - would you use 3 x 12V batteries in series? Where would they go? Take the old motor off? Sounds like a fun project! 1 Share this post Link to post Share on other sites
Pullstart 71,417 #3 Posted August 2, 2022 8 minutes ago, davem1111 said: Does it have a reverse? If it could have a free wheel clutch I’m sure you could push it backwards.. Share this post Link to post Share on other sites
Pullstart 71,417 #4 Posted August 2, 2022 Or could the motor spin backwards by chance? Share this post Link to post Share on other sites
Pullstart 71,417 #5 Posted August 2, 2022 One more brain fart. Sorry for the visuals Sylvia! At the 2019 Portage Garden Tractor Daze, there was an electric RJ that had a small trailer containing all the batteries. I’m pretty sure I’ve sent you that picture before. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,722 #6 Posted August 2, 2022 (edited) 54 minutes ago, davem1111 said: Does it have a reverse? 36V - would you use 3 x 12V batteries in series? Where would they go? Take the old motor off? Sounds like a fun project! If transmission is free / fixable yes reverse - I think. If not, motor is reversible. Switch maybe? Yes 3 12 v in series. I think small ones would fit under hood and seat. Yes remove existing engine. 46 minutes ago, Pullstart said: If it could have a free wheel clutch I’m sure you could push it backwards.. Yup - only for back yard slow cruising. No real need for reverse… 46 minutes ago, Pullstart said: Or could the motor spin backwards by chance? Yes it can. 42 minutes ago, Pullstart said: One more brain fart. Sorry for the visuals Sylvia! At the 2019 Portage Garden Tractor Daze, there was an electric RJ that had a small trailer containing all the batteries. I’m pretty sure I’ve sent you that picture before. Visuals or smellables…? I’ve seen that pic. Don’t think I’ll want a trailer on this one, but who knows. That could be the “tender” car on a new SL&WHN RR line… Excellent input / Q’s… keep them coming… Thank you!!! Edited August 2, 2022 by SylvanLakeWH 4 Share this post Link to post Share on other sites
Achto 32,849 #7 Posted August 2, 2022 (edited) 2 hours ago, SylvanLakeWH said: Yes remove existing engine. How about gut the existing engine and hide the electric motor inside of it??? Edited August 2, 2022 by Achto 4 1 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #8 Posted August 2, 2022 (edited) If it have no reverse and a pure DC Motor ( 2 Wires to the Motor) it can be reversed by a Doubleacting Switch. if it is a BLDC Motor ( brushless with 3 Wires to the Motor) just twist 2 phase wires, that will reverse the Motor. but on both Motorsystems it is the same theymust be 100% stopped before switching, otherwise the electronic may damage. This is even more important, if it have an electronic Motor brake. Edited August 2, 2022 by Tractorhead 2 1 Share this post Link to post Share on other sites
ACman 7,749 #9 Posted August 2, 2022 …. it may be able to run both directions by reversing the polarity . So why not use the transmission ? Set the steering up like a new model maybe just shorten one down . That would open it up under the hood/bonnet for three batteries maybe and have side panels to cover them up . I was thinking this kind of setup for a project in my head that’ll never happen. Blending a 702 and RJ for achieving a certain look of a orange tractor my case . I would call it a model WH™ To pay homage to the brand. 2 2 Share this post Link to post Share on other sites
ACman 7,749 #10 Posted August 2, 2022 I probably have what you’re looking for but I can’t get you any pictures as most of it is out of reach. I’m also a procrastinator and just putting off the inevitable of selling all my stuff . 1 Share this post Link to post Share on other sites
wallfish 20,699 #11 Posted August 2, 2022 I did an electric Lawn Ranger a while ago and used a starter generator from a cub cadet or simplicity as the motor since they spin the correct direction with a belt to the trans. 1 deep cycle marine battery ran it. It had an onboard charger/ maintainer so just plug an extension cord to it and it was ready to go. Not good for long rides but it went well around at one of the shows. It had a full blown fish aquarium under the hood, lights, bubbles etc etc. Built for a friends young daughter that liked that show Tanked so it wasn't here for very long. I don't know how long one of those S/Gs will last doing that. 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,722 #12 Posted August 2, 2022 Very cool! Any pics? I was wondering if a single 12v motor and battery would do the trick… simpler and cheaper… never thought of a starter generator… would have a strong enough shaft I guess hey? 1 Share this post Link to post Share on other sites
wallfish 20,699 #13 Posted August 2, 2022 12 minutes ago, SylvanLakeWH said: Any pics? S/G is mounted below the frame. You can see it right below the belt guard. You can also see the black plastic battery box behind the rear fender mounted to the rear of the trans. Not filled and not set up with fish here as they were picking it up. I left that up to her to decorate it however she liked. Acrylic tank. Had to seal the top and get creative to vent it so it wouldn't splash water out. 1 2 3 Share this post Link to post Share on other sites
ri702bill 13,229 #14 Posted August 13, 2022 On 8/2/2022 at 5:57 PM, wallfish said: so it wouldn't splash water out. along with the "kitty treats" inside ... 2 Share this post Link to post Share on other sites
Handy Don 17,591 #15 Posted August 13, 2022 I like the hood ornament, too! 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #16 Posted August 19, 2022 I must be brain dead... how the hell did I miss this thread? Snoop is late, but present... I would think... you could buy a speed controller for an EZ go golf cart, with direction controller, and you could have forward and reverse... Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #17 Posted August 19, 2022 Hey Jim, one other idea that just smacked me... why not go with lithium? That would only require 3 batteries to meet 36 volts, would weigh very little... Check it out: https://dakotalithium.com/product/dakota-lithium-36v-golf-cart-battery-set/ Don 1 Share this post Link to post Share on other sites
Evguy 567 #18 Posted August 20, 2022 There are reverse contactors available for reversing. I don’t know the age of operators, but remote shut down might be a good thing. I have electrified a lot of vehicles, using mobility parts, floor scrubber motors, fork lift pump motors, etc. There’s lots of options depending on speed and funds available for project. Golf cart motors usually require axle due to no bearing support on the motor itself. 2 Share this post Link to post Share on other sites
Vurge 158 #19 Posted September 8, 2022 (edited) Not Wheel Horse, but I've done a couple conversions. The golf cart motor will require more work (need to buy or machine a shaft). In my Craftsman, I kept the belt drive and 6 speed transmission but replaced with motor. Keeping the original drivetrain gives you reverse without a FNR switch and the multiple gears give you a lot of options for torque/speed. With a bigger pulley, the top speed is now about 10-12 mph. Low speed is basically a crawl in first gear because you control the motor speed with the foot throttle. My initial 1hp motor burnt up. I thought it was because I was running too slow (low voltage) but in retrospect, I pretty sure it was just overloaded. I'm learning as I go.... Updated with a 2.5hp motor and that's been working perfect. Pics in this thread: Edited September 8, 2022 by Vurge 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,722 #20 Posted March 17, 2025 (edited) @oliver2-44 nudged me to resurrect / reconsider this thread / concept... thx! May consider a 3 hp Predator or a battery powered unit as shown in post 1. Pros I have it in my yard It's a It looks cool Cons Transmission is locked up... Front wheels pretty bad Back wheels pretty bad Engine locked up it is sun-kissed...to say the least... I love it where it is... yard art. If i don't get any roller offers at @Pullstart's plow day next week, me thinks I will go this route... Thoughts / advice / ideas welcome... Edited March 17, 2025 by SylvanLakeWH 2 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,703 #21 Posted March 17, 2025 I have tons of wheels I can donate to the cause!! Just have Jim @WHX?? and Dan @Achto field strip that transmission at plowday and get it cleaned up for ya I bet @Pullstart probably has a transmission floating around in his big shed that's good and loose being next to his 950 degree waste oil burner 1 1 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,722 #22 Posted March 17, 2025 2 minutes ago, Mike'sHorseBarn said: I have tons of wheels I can donate to the cause!! Just have Jim @WHX?? and Dan @Achto field strip that transmission at plowday and get it cleaned up for ya I bet @Pullstart probably has a transmission floating around in his big shed that's good and loose being next to his 950 degree waste oil burner Not a bad idea... how many Capt'n's does it take to screw in a transmission??? If rain is forecast I may just put up a challenge... bottle of Capt'n and some deep fried curds to the team that makes it go first!!! 4 Share this post Link to post Share on other sites
Achto 32,849 #23 Posted March 17, 2025 (edited) 9 minutes ago, SylvanLakeWH said: Capt'n's does it take to screw in a transmission?? One bottle to make it work. 2 bottles.. it probably will not work but I will surely try to convince you that it does. Edited March 17, 2025 by Achto 6 1 Share this post Link to post Share on other sites
oliver2-44 11,786 #24 Posted March 17, 2025 1 hour ago, SylvanLakeWH said: @oliver2-44 nudged me to resurrect / reconsider this thread / concept... thx! Glad I could help! 59 minutes ago, Mike'sHorseBarn said: I have tons of wheels I can donate to the cause!! Just have Jim @WHX?? and Dan @Achto field strip that transmission at plowday and get it cleaned up for ya 44 minutes ago, Achto said: One bottle to make it work. 2 bottles.. it probably will not work but I will surely try to convince you that it does. Man, this really make me want to attend the plow day! 4 Share this post Link to post Share on other sites
Pullstart 71,417 #25 Posted March 17, 2025 Just to be sure everyone is on the same page, plow day is not this week I’m just as excited as y’all, but it’s the 29th, next Saturday 1 1 Share this post Link to post Share on other sites
