ebinmaine
'74 C160 Tecumseh engine tractor. Let's put it to use!
ebinmaine
@kpinnc
I had an order for McMaster Carr to place.
Found them there.
Thanks for the size reference.
I also ordered a couple different thicknesses of washers.
ebinmaine
Today I separated out all the new parts and continued clean up.
Replaced all 3 axle grease fittings.
Mounted the axle. Installed new nyloc nuts on the frame to attach-o-matic mount bolts 🔩.
ebinmaine
As explained in this video the hub was going to be out a hair to far.
I needed to cut the spacer that the seal is going to ride on.
I used what I had to get the job done.
Not exactly neat and clean...
but effective.
After mounting the wheel on the hub on the axle I found I needed a wheel spacer.
That's not at all surprising considering these wheels are universal camper or go-kart with a centered backspacing.
Here's a trial fit with the wheel on the spacer on the hub.
That photo angle is a little misleading on the width. I can't get it too accurate yet but I think the front is going to be around 42", 43" across. The back is about 41".
Handy Don
With the stock wheels/tires, the track for the swept axle is 42"
ebinmaine
I thought it was around that range somewhere. This definitely looks like it's going to be wider than that by a fair margin.
Handy Don
I just happen to have a swept axle with stock tires sitting in my storage area....;)
ebinmaine
Imagine that....
ebinmaine
I've had a hankerin'  to see the set of wiiide front tires on this beast but they just didn't quite do it for me.
Well I have a set of 5  x 4.5 narrow wheels with tri ribs.
Those look good!
This evening I got the test fitted hubs and wheel spacers back off.
Removed the dry fitted LH spindle.
Got some grease in both spindles and installed them.
I also used a tool I don't recall getting but it's super handy. A Bearing Packer.
Also, I did some poking around here on the site because I should get new tie rods.
I found an old post showing that I'll need to build some heim joint rods.
The stock C160-8 steering plate won't clear the 520H tie rods.
I'll check the threads another day and order from McMaster Carr.
May have been @JAinVA that had that info years ago...
ebinmaine
Mission this morning is to get the adapter bushings held in place with a little J. B. Weld.
Here's the 2,000 pound rated trailer hubs all set out and ready for installation.
ebinmaine
Bushings are in place.
Here's a wheel installed.
Next project is to build tie rods.
