Mike C160 251 #76 Posted June 11, 2022 @ebinmaine yes it actually is a small pebble that fell in off the top of the case as it was split in situ. 2 Share this post Link to post Share on other sites
ebinmaine 78,557 #77 Posted June 11, 2022 9 minutes ago, SylvanLakeWH said: A Haiku… Confucius wise man @ebinmaine claimed so Consult Colossus A haiku... If it's worth doing It's worth doing tomorrow So says The Large Bear 3 1 Share this post Link to post Share on other sites
Mike C160 251 #78 Posted June 11, 2022 Ok Need some words of wisdom. Is there a good tutorial on removing and installing these needle bearings? Or in the alternative someone with experience at removing and installing these bearings? By better judgement is telling me to replace all the bearings in that case. And if there is a simple way to remove them I will. So i will have to order parts from lowell and it will take at least two weeks for them to arrive. So I have some time to get some tools and a good procedure in place. Any words of wisdom would be appreciated. Cheers 1 Share this post Link to post Share on other sites
ebinmaine 78,557 #79 Posted June 11, 2022 The bearing and outer shield are one piece. Right or wrong... I've used a socket of very close diameter as a driver. 5 Share this post Link to post Share on other sites
Mike C160 251 #80 Posted June 11, 2022 4 minutes ago, ebinmaine said: The bearing and outer shield are one piece. Right or wrong... I've used a socket of very close diameter as a driver. I see that now!! That makes it easy! I thought it was a blind hole I had to slide them out of. 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #81 Posted June 11, 2022 (edited) 43 minutes ago, Mike C160 said: 1) Left side inner axle bearing 1533 Partial failure / full on failure in progress. 2) Right side mushroom gear needle bearing. I have seen broken needle bearings destroy those ball bearings. Edited June 11, 2022 by Maxwell-8 2 Share this post Link to post Share on other sites
pfrederi 20,422 #82 Posted June 11, 2022 Your parking pawl is shot.. Somebody kept engaging it while still in motion. A to Z can probably fix you up with good used one... I also use a close size socket to drive out bearings. 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #83 Posted June 11, 2022 2 minutes ago, pfrederi said: I also use a close size socket to drive out bearings. Great point, also a good idea to drive in bearings 4 Share this post Link to post Share on other sites
Mike C160 251 #84 Posted June 11, 2022 20 minutes ago, pfrederi said: Your parking pawl is shot.. Somebody kept engaging it while still in motion. A to Z can probably fix you up with good used one... I also use a close size socket to drive out bearings. I saw it was pretty chewed. I dont think im gonna worry about it right now. It takes many weeks to get stuff from A to Z for me. I think im going to order all new bearings and seals and call it a day. Thanks. 1 Share this post Link to post Share on other sites
Mike C160 251 #85 Posted June 11, 2022 So the next big question. The machine is a 1977 C160 auto and I dont have a parts manual for it. I do have the 1975 C160 Auto parts manual. Is it ok to get my part #'s out of this manual? Cheers 1 Share this post Link to post Share on other sites
ebinmaine 78,557 #86 Posted June 11, 2022 32 minutes ago, Mike C160 said: So the next big question. The machine is a 1977 C160 auto and I dont have a parts manual for it. I do have the 1975 C160 Auto parts manual. Is it ok to get my part #'s out of this manual? Cheers Should be the same... Lowell will have the numbers for the bearings. I'm very curious to know why it takes so much longer to get stuff from Pennsylvania than it does from Michigan or whatever. 1 Share this post Link to post Share on other sites
Mike C160 251 #87 Posted June 11, 2022 1 minute ago, ebinmaine said: Should be the same... Lowell will have the numbers for the bearings. I'm very curious to know why it takes so much longer to get stuff from Pennsylvania than it does from Michigan or whatever. No idea. I ordered from A to Z long ago. It shipped right away. Its still not here. Its been 3 weeks. Yet stuff from lowell takes about 14 days. Cheers 1 Share this post Link to post Share on other sites
Mike C160 251 #88 Posted June 11, 2022 Ok, 250 bucks later, Ive ordered all the parts. All bearings and seals. May as well completely freshen it up completely. Cept the parking brake pawl. Not really concerned about that right now. Too hard / long to source one. Unless someone just happens to have one hanging around. So now we wait. 2 Share this post Link to post Share on other sites
ebinmaine 78,557 #89 Posted June 11, 2022 10 minutes ago, Mike C160 said: pawl Check eBay Canada. Never know.....? 2 Share this post Link to post Share on other sites
Mike C160 251 #90 Posted June 11, 2022 55 minutes ago, ebinmaine said: Check eBay Canada. Never know.....? Ordered a bearing puller set to get those 1533s out. 6 Share this post Link to post Share on other sites
Mike C160 251 #91 Posted June 11, 2022 4 hours ago, Maxwell-8 said: Great point, also a good idea to drive in bearings Did you find you needed that jig to install the axle bearings? Cant just gingerly tap them into place?? Great home brew jig by the way. Cheers 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #92 Posted June 11, 2022 1 minute ago, Mike C160 said: Did you find you needed that jig to install the axle bearings? Cant just gingerly tap them into place?? Great home brew jig by the way. Thanks, You can, I have done a couple with success but I have also broken one by hammering it in. Had to go out order a new bearing and then made this jig. It insures a more strait install and protects the roller from locking. 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #93 Posted June 11, 2022 1 hour ago, Mike C160 said: Ordered a bearing puller set to get those 1533s out. I had an old set laying around, a must have to remove bearings or left overs like here: 3 Share this post Link to post Share on other sites
Mike C160 251 #94 Posted June 11, 2022 1 minute ago, Maxwell-8 said: Thanks, You can, I have done a couple with success but I have also broken one by hammering it in. Had to go out order a new bearing and then made this jig. It insures a more strait install and protects the roller from locking. Gotcha. Prolly best plan is to start with wood until the brg is well inserted and then level it off with some gentle taps from the knock-ometer. 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #95 Posted June 11, 2022 Just now, Mike C160 said: Gotcha. Prolly best plan is to start with wood until the brg is well inserted and then level it off with some gentle taps from the knock-ometer. If you are going to use a hammer, go for a rubber hammer, I think it's softer on the bearing. 2 Share this post Link to post Share on other sites
ebinmaine 78,557 #96 Posted June 11, 2022 40 minutes ago, Mike C160 said: Gotcha. Prolly best plan is to start with wood until the brg is well inserted and then level it off with some gentle taps from the knock-ometer. That's what I usually do. A closet clothing pole works well. 39 minutes ago, Maxwell-8 said: If you are going to use a hammer, go for a rubber hammer, I think it's softer on the bearing. We use nylon sand filled dead blow hammers. They don't bounce like rubber hammers. Much easier to control the concussion. 3 Share this post Link to post Share on other sites
Mike C160 251 #97 Posted June 12, 2022 16 hours ago, ebinmaine said: That's what I usually do. A closet clothing pole works well. We use nylon sand filled dead blow hammers. They don't bounce like rubber hammers. Much easier to control the concussion. Yep. I think i got a nylon knock-ometer around here somewhere 2 Share this post Link to post Share on other sites
ebinmaine 78,557 #98 Posted June 12, 2022 8 minutes ago, Mike C160 said: Yep. I think i got a nylon knock-ometer around here somewhere I s'pose a wood 🪵 stick would work too. 2 Share this post Link to post Share on other sites
Mike C160 251 #99 Posted June 15, 2022 @pfrederi Would wouldnt happen to have a standard part number for the Orings that go on the hydraulic lines right at the pump would you??? Thanks and Cheers.. Share this post Link to post Share on other sites
Mike C160 251 #100 Posted June 15, 2022 Got my bearing puller set today. All bearings are out and case clean up has begun. Lowell shipped parts today. 1 Share this post Link to post Share on other sites
