Mike C160 251 #1 Posted June 3, 2022 Greetings, I decided today i would change the oil and filter in the hydro unit. However upon draining the unit, these pieces fell out. Looks like bearing cages. Can anyone tell me where these piece might have come from and if this is a serious failure? The tractor moves forwards, backward just fine without any odd noise or leaks. Thanks and Cheers! 1 Share this post Link to post Share on other sites
WHX?? 53,334 #2 Posted June 3, 2022 I have no idea Mike but chiming in to see how those came out the drain plug hole. Filter pieces perhaps? 1 Share this post Link to post Share on other sites
Mike C160 251 #3 Posted June 3, 2022 (edited) 2 minutes ago, WHX?? said: I have no idea Mike but chiming in to see how those came out the drain plug hole. Filter pieces perhaps? The second I took the plug out, they fell into the drain pan. So they were right there at the plug. The one piece most certainly is a bearing cage, but from where? Edited June 3, 2022 by Mike C160 1 Share this post Link to post Share on other sites
squonk 44,860 #4 Posted June 3, 2022 No idea. @daveoman1966 2 Share this post Link to post Share on other sites
cafoose 3,522 #6 Posted June 4, 2022 Download these manuals: 3 Share this post Link to post Share on other sites
Mike C160 251 #7 Posted June 4, 2022 36 minutes ago, cafoose said: Download these manuals: Could it be the cage from the dreaded 1533 axle bearing? The pump seems to have great pressure... 1 Share this post Link to post Share on other sites
cafoose 3,522 #8 Posted June 4, 2022 36 minutes ago, Mike C160 said: Could it be the cage from the dreaded 1533 axle bearing? Could possibly be that. Axles should have no up and down or front and back play but can move in and out like 1/16th of an inch. @stevasaurus is our transaxle specialist and may be able to help. 1 Share this post Link to post Share on other sites
Mike C160 251 #9 Posted June 4, 2022 Just now, cafoose said: Could possibly be that. Axles should have no up and down or front and back play but can move in and out like 1/16th of an inch. @stevasaurus is our transaxle specialist and may be able to help. Thanks It would be good to know if its savable before ripping it apart and finding out its toast. I dont relish the thought of trying to get those hubs off only to be stopped by internal carnage. Can bearings from the pump drop down that far? 1 Share this post Link to post Share on other sites
ebinmaine 75,751 #10 Posted June 4, 2022 How much time have you driven the tractor? Been hot enough to do the test where you tie it to a tree and see if the tires spin? That metal may be part of the drive gear set somewhere and not related to the pump section. Maybe you're lucky enough to have the pump section in usable condition while the drive gear section needs repair. The only real way (that I can see/ is to dismantle and diagnose. It's an easy enough transmission to do so. That way you'll KNOW where it came from and how to fix. Being an automatic, the hubs may very well be removable without extreme effort. 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #11 Posted June 4, 2022 I have not seen anything like that clamp part in a transmission. I wonder if it has something to do with holding the dip stick tube?? It is hard to tell about the other piece, but I don't think it is a bearing race. You would know if it was...bearings would have come out also (needles or ball) and they would have been shooting around inside jamming gears and popping inside. I'm not sure, but I would think that pieces like that would not be able to get into the transaxle from the pump. One thing is for sure...you have more pieces floating around in the transaxle. It should be opened and checked before more or any damage is done. I'm curious to see what @daveoman1966 has to say. He is the Hydro-King. 3 Share this post Link to post Share on other sites
Mike C160 251 #12 Posted June 4, 2022 6 hours ago, ebinmaine said: How much time have you driven the tractor? Been hot enough to do the test where you tie it to a tree and see if the tires spin? That metal may be part of the drive gear set somewhere and not related to the pump section. Maybe you're lucky enough to have the pump section in usable condition while the drive gear section needs repair. The only real way (that I can see/ is to dismantle and diagnose. It's an easy enough transmission to do so. That way you'll KNOW where it came from and how to fix. Being an automatic, the hubs may very well be removable without extreme effort. Hey Eric, Yes, last weekend I drove it for about an hour and a half. It drove great. Plenty of power. And more speed than you can really use. It didnt slow down as it got hot at all. Yes I hope the hubs come off without a death struggle Cheers and thanks. 2 Share this post Link to post Share on other sites
pacer 3,177 #13 Posted June 4, 2022 Well, one thing is for sure..... and that is that tranny is gonna HAVE to come out and find what those pieces are (which nobody has yet to identify!) Those pieces being in there cannot in any way be good and are screaming to 'find out what I am!!' we 1 Share this post Link to post Share on other sites
Mike C160 251 #14 Posted June 4, 2022 (edited) 3 hours ago, stevasaurus said: I have not seen anything like that clamp part in a transmission. I wonder if it has something to do with holding the dip stick tube?? It is hard to tell about the other piece, but I don't think it is a bearing race. You would know if it was...bearings would have come out also (needles or ball) and they would have been shooting around inside jamming gears and popping inside. I'm not sure, but I would think that pieces like that would not be able to get into the transaxle from the pump. One thing is for sure...you have more pieces floating around in the transaxle. It should be opened and checked before more or any damage is done. I'm curious to see what @daveoman1966 has to say. He is the Hydro-King. That piece we are looking at in the photo below I believe is the ball bearing cage from the axle bearing. First off, its the right size to be a bearing cage. Its small. The two things at the sides that look like holes are the spot welds that kept it together. So this is my theory. I believe it to be a bearing cage. I believe its the axle bearing right beside the diif. 1533 bearing. Look at the attached photo. - There are so few of those roller bearings in the tranny. -I dont think the bearing like that in the pump could pass large pieces into the bottom of the diff case. -The pump and motor work great. No noise. Plenty of power. If a massive failure like this happened in the pump or motor, I dont think It would have much pressure at all. So this is my theory. This gives me hope that its savable. If it was from the pump or somewhere key were serious damage is involved, I wouldnt take it apart, I would just search for a used one. Does Steve or anyone agree with my theory? Cheers - Edited June 4, 2022 by Mike C160 3 1 Share this post Link to post Share on other sites
Mike C160 251 #15 Posted June 4, 2022 15 minutes ago, pacer said: Well, one thing is for sure..... and that is that tranny is gonna HAVE to come out and find what those pieces are (which nobody has yet to identify!) Those pieces being in there cannot in any way be good and are screaming to 'find out what I am 15 minutes ago, pacer said: Those pieces scream to me one of two things. I need to decide. 1) Its a simple repairable axle bearing, take it apart and repair it. 2) its a catastrophic failure I wont be able to find parts for, source a used one This is the 64 dollar question. Cheers 1 Share this post Link to post Share on other sites
8ntruck 8,334 #16 Posted June 4, 2022 You beat me to it. I was just going to post that piece looks like a piece of bearing cage. If enough of that bearing cage has failed, you eventually will have loose ball bearings in the transmission. If it were mine, I'd open it up to see what is going on before it goes crunch/bang. 2 Share this post Link to post Share on other sites
Mike C160 251 #17 Posted June 4, 2022 6 hours ago, ebinmaine said: Being an automatic, the hubs may very well be removable without extreme effort. I curious and your post gives me hope as I dont have much hope for this tractor right now. Why do the hubs come off an auto easier?? Cheers 1 Share this post Link to post Share on other sites
squonk 44,860 #18 Posted June 4, 2022 1 hour ago, Mike C160 said: I curious and your post gives me hope as I dont have much hope for this tractor right now. Why do the hubs come off an auto easier?? Cheers They don't. 4 Share this post Link to post Share on other sites
WHX?? 53,334 #19 Posted June 4, 2022 We ain't figured out yet what planet EB is from but I just fought with some on a C-121 auto. Gotta be a bearing cage but if they are 1533 bearings Lowell has them. You seem to be pretty good with a wrench Mike I don't think you'd have a problem replacing it other yah the hubs but even then with a hub puller shouldn't be insurmountable. 3 Share this post Link to post Share on other sites
oliver2-44 11,062 #20 Posted June 4, 2022 I'll speculate that second piece is also part of a bearing cage. In its center length it looks like a bearing ball path, and it is about the same width. I think it has just been bent up by the differential gears. 3 Share this post Link to post Share on other sites
cafoose 3,522 #21 Posted June 4, 2022 16 minutes ago, WHX?? said: even then with a hub puller shouldn't be insurmountable DO NOT use a three jaw gear puller in the outside of the hub. If you do, most probably the hub will break. There are numerous posts on pulling the hub properly. Here are some examples: 2 3 Share this post Link to post Share on other sites
Mike C160 251 #22 Posted June 4, 2022 1 hour ago, WHX?? said: We ain't figured out yet what planet EB is from but I just fought with some on a C-121 auto. Gotta be a bearing cage but if they are 1533 bearings Lowell has them. You seem to be pretty good with a wrench Mike I don't think you'd have a problem replacing it other yah the hubs but even then with a hub puller shouldn't be insurmountable. Herein lays the problem. I used to have a fully equipped private shop. Did custom turbo systems development there. But My tenant in the attached apartment BURN IT TO THE GROUND. I LOST EVERYTHING If you would like to see my work, please view the photos attached to this page. This is my last project I completed in my shop before it was burnt to the ground for me. > (5) Pontiac Grand Prix GT - Turbo L36 Project | Facebook So, I am now working outside, in my driveway with a limited amount of tools I have managed to purchase over the last year. If I had my shop this would not be a big job. But I dont have a shop, so this is a big undertaking that I really wish I didnt have to do in my driveway. So careful consideration is being used here. I have the skills indeed. I am space and tool limited. Doesnt matter how you slice it, this is going to be a struggle doing it PROPERLY in my driveway. Ugh 5 Share this post Link to post Share on other sites
Mike C160 251 #23 Posted June 4, 2022 52 minutes ago, cafoose said: DO NOT use a three jaw gear puller in the outside of the hub. If you do, most probably the hub will break. There are numerous posts on pulling the hub properly. Here are some examples: Thank you I will review but Im guessing I dont have the tools to remove the hub should they be stuck. Cheers 2 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #24 Posted June 4, 2022 If one hub comes off, you can use it to make a puller for the one that is stuck. Your transaxle is completely fixable. Would have been nice if you had placed a quarter or something next to those pieces in your pictures so as to give a size relationship. Anyway, you do not need the pump and the transaxle can be taken off without pulling the pump. The directions are above. If you were to buy another transaxle, you would still have to get your wheels and external parts off...so...go for it, it may come apart easy. I would not drive that horse until fixed. It would have been nice to have those pictures in your post #14, it would have saved a lot of speculation. I've taken apart #1533 bearings, and it is almost impossible to put them back together. I thing I want to say here...without that piece holding the balls in place, they can drift all around inside the races. If they all end up on the same side, the whole thing can come apart. As long as the balls are distributed evenly, the balls can not escape. This might be where you are at. By the sound of it, you have no idea when this happened. I think you are lucky you decided to change your oil. 2 Share this post Link to post Share on other sites
Mike C160 251 #25 Posted June 4, 2022 53 minutes ago, stevasaurus said: If one hub comes off, you can use it to make a puller for the one that is stuck. Your transaxle is completely fixable. Would have been nice if you had placed a quarter or something next to those pieces in your pictures so as to give a size relationship. Anyway, you do not need the pump and the transaxle can be taken off without pulling the pump. The directions are above. If you were to buy another transaxle, you would still have to get your wheels and external parts off...so...go for it, it may come apart easy. I would not drive that horse until fixed. It would have been nice to have those pictures in your post #14, it would have saved a lot of speculation. I've taken apart #1533 bearings, and it is almost impossible to put them back together. I thing I want to say here...without that piece holding the balls in place, they can drift all around inside the races. If they all end up on the same side, the whole thing can come apart. As long as the balls are distributed evenly, the balls can not escape. This might be where you are at. By the sound of it, you have no idea when this happened. I think you are lucky you decided to change your oil. So some questions. Can the transaxle case be split without removing the pump? And if so, can I split the case in the tractor removing the two under carriage bolts? I suppose these 1533 bearings are common place failures? Cheers 1 Share this post Link to post Share on other sites
