Handy Don 13,984 #51 Posted June 8, 2022 59 minutes ago, buckrancher said: it's a complete assembly @dmoore Interesting. On mine the through bolt has a hex head and is removable and this pulley and the PTO idler are identical. I'll try to grab a photo when I'm working on it later. Curious why you have the seat spring mounted before the toolbox is there. Share this post Link to post Share on other sites
squonk 43,736 #52 Posted June 8, 2022 @prondzy can repair your pulley if you don't find one. 1 Share this post Link to post Share on other sites
dmoore 962 #53 Posted June 9, 2022 12 hours ago, squonk said: @prondzy can repair your pulley if you don't find one. I may take you up on that Share this post Link to post Share on other sites
dmoore 962 #54 Posted June 9, 2022 Who makes a thin enough puller to get behind the brake shaft pulley? Share this post Link to post Share on other sites
wallfish 18,071 #55 Posted June 9, 2022 1 hour ago, dmoore said: Who makes a thin enough puller to get behind the brake shaft pulley? I have a whole set The brake drum is fairly beefy so you don't have to worry about bending/breaking it. Remove the retainer (there are different ones depending upon the trans) Try tapping it IN with a hammer just to get it to move but DON"T go overboard with a BFH. Once it moves a little tap the screwdrivers in behind it to wedge it off. Spinning it to wedge on different spots helps too. Typically if it's leaking oil they come off pretty easy. If it ain't leaking oil then leave it on there until it does. 2 Share this post Link to post Share on other sites
Handy Don 13,984 #56 Posted June 9, 2022 3 hours ago, dmoore said: Who makes a thin enough puller to get behind the brake shaft pulley? Another alternative I learned from @Docwheelhorse is to use plastic wood splitter wedges. 3 Share this post Link to post Share on other sites
dmoore 962 #57 Posted June 9, 2022 Nice. Ha! But I was thinking of a more controlled method. Share this post Link to post Share on other sites
dmoore 962 #58 Posted June 27, 2022 Had a very good time at my first show! It was good to put a face to a name. Nice meeting you Bob, thanks for the brake lining! VinsRJ as well, Thanks for filling in for Matt and taking care of getting my beautiful seat cover, I did a trial fit last night after getting back home and its perfect. Mr. & Mrs. Pullstart were setup right beside us on the camper lot. That's the way you raise a family! I think I saw more kids on tractors than adults! Especially enjoyed the sunset parade! Picked up a lot of parts from K & B to finish my restoration and even scored a high back genuine Wheel Horse seat for my C-101. Had a very good conversation with "Wild Bill" from Va as well. Looking forward to next year with the 854! Dave 2 Share this post Link to post Share on other sites
dmoore 962 #59 Posted July 11, 2022 Been busy on other projects and keeping my county cool. I have managed to install just about all parts bought from Brian @ K & B Horse Parts. It's been a roller since last week thanks to Miller Tires in Ohio. I will need to source an upper steering shaft bronze bushing since mine is worn. The engine has been disassembled, cleaned, inspected, two new crankshaft seals, honed & ready for new piston/rod assy installation. It is in very good condition with all measurements well within spec. Hoping to have the engine mounted and running by next weekend. 2 7 Share this post Link to post Share on other sites
Handy Don 13,984 #61 Posted July 17, 2022 Looks terrific! Before you get too far on assembly, though, you may want to pause and think about electrical grounds with all those freshly painted components! Regulator to S/G body. S/G to engine block. Battery negative to engine block. Coil ground wire to engine block. When I assembled my nicely painted K181, I carefully scraped off the paint at key spots and used dielectric grease on the joints. Tested with a continuity buzzer and VOM to be sure they were really solid. Did the same for all the "+12v" connections as I went--especially to the ignition switch and ammeter. 6 1 Share this post Link to post Share on other sites
dmoore 962 #62 Posted July 24, 2022 So in attempting to wire up this tractor I have been looking for the copper lugs, #6 with the smaller hole for the key switch and the voltage regulator terminals. Anyone know who may have them? Share this post Link to post Share on other sites
JPWH 6,338 #63 Posted July 25, 2022 (edited) Search 1/4" wire ring terminals at soundextreme1902 on flea bay. Edited July 25, 2022 by JPWH 1 Share this post Link to post Share on other sites
dmoore 962 #64 Posted July 25, 2022 Thanks JP will do 1 Share this post Link to post Share on other sites
ineedanother 1,668 #65 Posted July 26, 2022 I just used some of these on my boat with some heat shrink. Good quality. https://www.amazon.com/Ga-Stud-Copper-Lugs-Pack/dp/B00O7S7INS 2 Share this post Link to post Share on other sites
dmoore 962 #66 Posted July 26, 2022 I actually found them at my NAPA. I guess I just overlooked them. Thanks guy's! 2 Share this post Link to post Share on other sites
dmoore 962 #67 Posted August 2, 2022 Since I cannot get an original shower head muffler what do you guys recommend? Which one last the longest? Share this post Link to post Share on other sites
wallfish 18,071 #68 Posted August 3, 2022 1 hour ago, dmoore said: Since I cannot get an original shower head muffler what do you guys recommend? Which one last the longest? I thought they stopped using shower head mufflers way before 64 Any of those pepper pot mufflers (spark arrestor) will look right. If you can deal with the tone and loudness of those things. Share this post Link to post Share on other sites
dmoore 962 #72 Posted August 3, 2022 From what I have read & seen 64 was the last year. Share this post Link to post Share on other sites
Wild Bill 633 877 #73 Posted August 4, 2022 21 hours ago, dmoore said: Where is the bow tie? Share this post Link to post Share on other sites
peter lena 9,235 #74 Posted August 4, 2022 @dmoore like the overall look of that opportunity , while I can relate to others on electrical lugs , the industrial grade of lugs is very stout , at your frame state , base line ground your battery ground bolt down spot to your engine / frame area , paint free , dielectric grease and serrated washers . @Handy Don ,agrees that is your verified ground go to point. since doing that , my electrical issues are gone. would also detail set up all related linkages , added washers and grease , for solid smooth action . would personally add a few well tried upgrades , while you are there, like fuel check valve , lift lever lubrication , washering , would also cable/wire wrap , wiring , etc . looks very good . should work out well for you , pete 1 Share this post Link to post Share on other sites
dmoore 962 #75 Posted August 4, 2022 (edited) 11 hours ago, Bill633 said: Where is the bow tie? No kidding, straight from the office. Edited August 4, 2022 by dmoore Share this post Link to post Share on other sites
