Fombelles
Looking for a deck
Fombelles
Looking for a deck for my gramps charger 12. We used to sell tractors in New Castle, and this is what I have left from that.
I have the feeling he modified it, fits a mule drive in front and attachomatic center.
Also I screwed up a few years ago on a few things I hope you can help with. We had to reset points, but unsure of what they are supposed for be at for cast iron Kohler 12.
I believe I also removed a bolt that keeps the parking lock/belt in tension on it. I’ll attempt to attach files.
thanks a lot, first posting, but have used info from here before.
953 nut
:WRS:
Always glad to see a young member continuing to show love to a family :wh:. Your Ignition points should be set to .020 when full open. If you post your needs in our classified section I'm sure someone can help you out. Just click on this link; https://www.wheelhorseforum.com/classifieds/wanted/
Fombelles
Perfect thank you. I’m not sooo young haha about 40, but finally in my forever home and trying to use what I recognize as the top of the top. I’ll try the classified. Any tips for how to show the lever for hydro engage so I can get that sorted?
SylvanLakeWH
:text-welcomeconfetti:
Fombelles
Hmm. Classifieds are blacked out for me. Maybe it’s a new member prove you’re real thing.
Blasterdad
Do you have the belt cover for it? The belt cover has guides on it for the belt, it keeps the slack out of the belt when disengaged, it wont work right without it... I would take the belt cover off that awesome (what I'm guessing is a C-160) one in the background, they should be the same setup, compare & see what's missing on the Charger....Make sure the belt goes back on top of the guides otherwise they will shred it.
  • Heart 1
953 nut
This thread from a couple weeks ago should be helpful.
peter lena
@Fombelles  noticing  that flat idler pulley on your drive belt set up , looks like rare wide side grease shields on that pulley , could be a good opportunity  , to carefully pocket screwdriver off those 2 side shields , clean out existing grease , carb clean flush out , repack with lucas _ xtra heavy duty chassis grease , push seals back in place , super quiet , reliable. just a thought , pete
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
