peter lena 10,047 #1 Posted May 10, 2022 just asking , most of my replies involve something that I changed or was testing a previous problem area . like to do that , turn something from a regular problem to a reliable area . could be wiring or mechanical function . like to make anything work easier , often just detailing function , shows you the way . like plow quadrant steering function , improving grounding .repetitive failure is your greatest opportunity , to correct its fault , pete 6 1 Share this post Link to post Share on other sites
sjoemie himself 3,186 #2 Posted May 10, 2022 I haven't worked on my Wheel Horse yet so I can't say for that project. However with my Murray to IH 1568 I apply the concept of 'think about it, try and try again' regurarly.. To be honest it isn't always fun to learn through faillure but that's kinda how life works. Mark 6 Share this post Link to post Share on other sites
ri702bill 12,988 #3 Posted May 10, 2022 Green grease! Green grease! Stop that noise & make it cease!! I have switched from the once a week applied Lucas Red & Tacky to Pete's favorite, the Green Grease on the Milling machine spur gears of the Power Table Feed. No more grease slung off onto the guard - regrease it once a month now - no more gear whine. Heim joints on the 48" plow angling rod ends worked fine this winter - no issues or signs of wear... Bill 5 2 Share this post Link to post Share on other sites
ebinmaine 80,653 #4 Posted May 10, 2022 Back in the '80s in high school I took several years of electricity class. That's where I began to understand that DC systems NEED proper ground and great connections or there is no system. I've built modified or repaired at least a half a dozen tractor wiring setups so far and I like to add extra grounds wherever it's practical, and then some. Add an extra washer here and there. Using the heim joints on the steering for quite a while now and I'll be doing that next winter on my plow controls as well. 6 Share this post Link to post Share on other sites
balconio 606 #5 Posted May 10, 2022 1) i wish i would have taken pictures, but on both my 312-8's the frame rail ends where the seat and rear fender tins bolt on were broken or cracked. i fixed this by cutting them short and welding on bed frame iron which i know isn't the best but it's more than adequate for this and way thicker than what was there. i can only imagine it happened because i'm 250lbs and also i get on and off the tractor from the right side 90% of the time and put a lot more stress on that side. 2) i boxed in the steering shaft bushing with some steel bar because it was sloppy AF and i couldn't for the life of me get the roll pin out of the steering wheel to do it right and replace the bushings. i still have 2 NIB bronze steering bushings, but the steering is staying tight. 3) i got rid of the sloppy bar and bushing setup for the hood and just used some bolts and nylock nuts to hold it down. hood is SUPER steady now and it used to rock around visibly as I mowed. 4) not really an improvement but more of a preference: i don't use any cotter pins anymore... i use different size "R" clips for all my retention points so it truly is a tool free process to change decks/blower/remove belt from PTO etc. 6 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #6 Posted May 10, 2022 13 minutes ago, balconio said: got rid of the sloppy bar and bushing setup for the hood and just used some bolts and nylock nuts to hold it down Gonna have to try to remember that one 1 Share this post Link to post Share on other sites
Handy Don 17,465 #7 Posted May 10, 2022 43 minutes ago, balconio said: got rid of the sloppy bar and bushing setup for the hood and just used some bolts and nylock nuts to hold it down I like it. Even better if you can use partially threaded bolts to keep the smooth part at the pivot point. 6 Share this post Link to post Share on other sites
ebinmaine 80,653 #8 Posted May 10, 2022 2 minutes ago, Handy Don said: I like it. Even better if you can use partially threaded bolts to keep the smooth part at the pivot point. Wicked good idea mistah. 2 Share this post Link to post Share on other sites
peter lena 10,047 #9 Posted May 10, 2022 @ri702bill bill as you have found out , that green grease , just flat out works , my experience is the same , use it in the tough noisy spots . smooth / easy and quiet . love it on the mower and pto bearings , silence , those heim joints are the deal , use it on your pto needle bearing too , that spins up easier , go green , pete 1 Share this post Link to post Share on other sites
8ntruck 9,296 #10 Posted May 10, 2022 (edited) 18 hours ago, Handy Don said: I like it. Even better if you can use partially threaded bolts to keep the smooth part at the pivot point. Throw a Belleview washer under the nylock. That would keep some tension in the joint and kill rattles. Edited May 11, 2022 by 8ntruck 4 Share this post Link to post Share on other sites
balconio 606 #11 Posted May 11, 2022 1 hour ago, peter lena said: @ri702bill bill as you have found out , that green grease , just flat out works , my experience is the same , use it in the tough noisy spots . smooth / easy and quiet . love it on the mower and pto bearings , silence , those heim joints are the deal , use it on your pto needle bearing too , that spins up easier , go green , pete i used to be able to get the lucas green grease one tube at a time from amazon for real cheap. like $4 a tube, but not anymore. i have a hard time finding it locally and papa bezos only sells cases of 10 or more. i just can't justify stocking that much of the stuff so i'm back to cheap garbage valvoline crimson. 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #12 Posted May 11, 2022 1 hour ago, 8ntruck said: Throw a Belleview washer under the nylock. That would keep some tension I'm the joint and kill rattles. Again. Despite my best efforts... I've learned something. 4 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #13 Posted May 11, 2022 Pete, I live to work on them. It is a true joy for me. I am in a band that I thought was my passion till I got back into this hobby again for the second time. My true interest is start/gen tractors. Simple but over built. Enjoy the day. 2 2 1 Share this post Link to post Share on other sites
squonk 48,079 #14 Posted May 11, 2022 10 hours ago, balconio said: i used to be able to get the lucas green grease one tube at a time from amazon for real cheap. like $4 a tube, but not anymore. i have a hard time finding it locally and papa bezos only sells cases of 10 or more. i just can't justify stocking that much of the stuff so i'm back to cheap garbage valvoline crimson. Wal-Mart 1 Share this post Link to post Share on other sites
JoeM 10,252 #15 Posted May 11, 2022 11 hours ago, balconio said: i just can't justify stocking that much of the stuff It can get pricey. Another option is the Traveller Brand at Tractor Supply, they have both the Lithium based and Poly stuff. I have been using the Traveller Premium Heavy Duty Lithium Grease for years and no issues. $3.50 a tube and $2.99 on sale. Has about the same spec of the Lucas R&T and no race car tarfs. 6 1 Share this post Link to post Share on other sites
peter lena 10,047 #16 Posted May 11, 2022 @RETIRED WRENCHER , seams to be a common thread to repair , for me its just looking at how its saposed to work / function , thats what usually makes me change out what's there . go after reliability first , verify your gain , then improve function . fount that 2 step , makes the best gain for me . my original mower deck engagement , was at best , sloppy , clunky, noisy . for years now , solid , smooth , and very easy to engage , its also very quiet . thats only what I want , but marvel at how easily it works . glad people are trying things , pete 3 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #17 Posted May 12, 2022 22 hours ago, peter lena said: @RETIRED WRENCHER , seams to be a common thread to repair , for me its just looking at how its saposed to work / function , thats what usually makes me change out what's there . go after reliability first , verify your gain , then improve function . fount that 2 step , makes the best gain for me . my original mower deck engagement , was at best , sloppy , clunky, noisy . for years now , solid , smooth , and very easy to engage , its also very quiet . thats only what I want , but marvel at how easily it works . glad people are trying things , pete Nice post Pete. If you have time like I do I like putting detail where I can. I will post when I am done with the 1257. 2 Share this post Link to post Share on other sites
peter lena 10,047 #18 Posted May 12, 2022 @Retierd Wrencher thanks , always been a stickler for detail function , so when I encountered a trouble spot , would just plan a correction .realize that this breaks with original set up , but it does not have to be radical to make it work reliably . very often my wiring detail improvements are hiding in plane site , big difference is chronic problem is gone , isn't what you want ? big 3 for me is , wire grounding , routing . mechanical function and ease of use. plow , and mower deck ease of operation . have to be fed up with original detail lacking , setup . went step by step , and corrected and improved as I went . eliminate rust and sloppy linkage end points , firm up and lubrication , makes things work seamlessly . every time I engage my mower deck set up , I marvel at how easily it works , and its very quiet too . this is only me , have my original c-85 , 40 years , experiment , improve , pete 4 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #19 Posted May 13, 2022 Pete I have 4 now but really only one worker. This is a winter tractor. Summer one is hardly used. But I like riding once in awhile. Other two is hobby tractors or show putters. 2 2 Share this post Link to post Share on other sites
Lee1977 7,764 #20 Posted May 13, 2022 On 5/10/2022 at 3:57 PM, ebinmaine said: Gonna have to try to remember that one You don't need the bolts unless you have the later model tractors 300, 400. 500 and maybe the Black Hoods not sure about them. The C-series needs good rubber stops between the hinge. I used some of the large 5/8" diameter tubeless valve stims cut them off about 1/2" above the sealing groove and pulled the brass stem out. Did that about 25 years back and they are still working. I had some extra 5/8" valve stims that I don't use any more. 3 4 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #21 Posted May 13, 2022 8 minutes ago, Lee1977 said: 👍 Excellent! 1 Share this post Link to post Share on other sites
Lee1977 7,764 #22 Posted May 13, 2022 (edited) I decided to make a new set of hinges for the 312. Tried putting bushings in the hinges a month or so back didn't help much. They made the original hinges just too thin I used some 1/4" x 2" x 2" angle and cut some out. Haven't completely finished it but got it together. Need to drill hinges and the front hitch out to 7/16" as the holes in the front hitch are worn. I got it finished, used the existing rod and made collars out of a couple of nuts shimmed the rod tight and epoxied it. Then dabbed some paint at it. It's my worker was a sad looking horse when I got it. Now it you shake the hood the hold tractor moves. Edited May 15, 2022 by Lee1977 3 2 Share this post Link to post Share on other sites
war eagle 80 #23 Posted May 14, 2022 My hinges were seriously wallered out causing the hood to rock sideways and rattle so I tack welded 1 inch grade 8 bolts to them and used nylon washers and lock nuts. No slop or rattles now! 6 1 Share this post Link to post Share on other sites
peter lena 10,047 #24 Posted May 15, 2022 @war eagle glad you got after that , once you get in the habit of correction , you look at problems differently . @Lee1977 did a nice strengthening set up on that chronic lower hood area . always adapting for function , make it better . of course if you have to keep it original , thats another issue . pete 2 Share this post Link to post Share on other sites
