TJ5208 1,841 #1 Posted February 12, 2022 (edited) Okay i seen a video @Pullstart made about tire widths the thinner ones worked better. So why do pullers use wide tires which one gives you more traction wide or thin? The reason I ask is because I haul a alout of loads and I want to be able to pull dead weight what do you guys recommend? I think fluid in them would help a lot with either one but the wider ones you can put more fluid in which in trade gives more weight. Edited February 12, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
pacer 3,180 #2 Posted February 12, 2022 My choice would be AG tread in wide as whatever your rims call for..... 3 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted February 12, 2022 Narrow tires are better in snow. But with weight and chains it shouldn't matter... 4 Share this post Link to post Share on other sites
ebinmaine 79,048 #4 Posted February 12, 2022 4 minutes ago, pacer said: My choice would be AG tread in wide as whatever your rims call for..... . ... There is a line of thinking that a thinner tire will cut down through snow easier to get to solid ground. I can see the logic there. I don't ever try to cut DOWN THROUGH the snow. If I'm on a tractor it's because I'm pushing the snow out of the way and most of it is already gone by the time it gets to the back tires so I went with, heavier the better. I run 10.5" wide tires all year long because that was how I could get the most fluid to get the most weight. 5 Share this post Link to post Share on other sites
SylvanLakeWH 31,483 #5 Posted February 12, 2022 It all depends on what you are doing and on what surface… Running ags on my concrete driveway to plow snow or pull my train full of kids around the neighborhood on paved streets, which is what I do with my horses, makes no sense. I use turfs. If you’re in dirt or grass with heavy loads go with ags. If you’re on pavement like me, go with turfs… 6 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #6 Posted February 12, 2022 11 minutes ago, SylvanLakeWH said: Running ags on my concrete driveway to plow snow or pull my train full of kids around the neighborhood on paved streets, which is what I do with my horses, makes no sense. I use turfs turfs will give you more traction on pavement. Have seen GT's with turf tires pull small size pickup trucks on concrete. 4 Share this post Link to post Share on other sites
pacer 3,180 #7 Posted February 12, 2022 28 minutes ago, SylvanLakeWH said: f you’re in dirt or grass with heavy loads go with ags. If you’re on pavement like me, go with turfs… Short & sweet --- that pretty well covers it............. 2 1 Share this post Link to post Share on other sites
squonk 46,722 #8 Posted February 12, 2022 I have 6-12's on my 857. Good old General Garden Tractor S.S's. 40 lbs of weight on each wheel. I've been plowing snow with no chains. 5 Share this post Link to post Share on other sites
TJ5208 1,841 #9 Posted February 13, 2022 Either one of these is what I'm probably going to do. The 24s look aggressiverer than the 23s. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #10 Posted February 13, 2022 (edited) What do you guys think I should do? Which one? Edited February 13, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,441 #11 Posted February 13, 2022 21 minutes ago, TJ Salyers said: What do you guys think I should do? Which one? Your 520 doesn’t have wide enough rims that will work for the 24-12-12’s. 2 1 Share this post Link to post Share on other sites
TJ5208 1,841 #12 Posted February 13, 2022 2 minutes ago, Sparky said: Your 520 doesn’t have rims that will work for the 24-12-12’s. Okay 23-10s it is. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #13 Posted February 13, 2022 (edited) Heres several brands im looking at. I'm liking the otrs. Edited February 13, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,441 #14 Posted February 13, 2022 Between the two I would choose the 4 ply tires over the 8 ply. In my opinion the 8 ply is to stiff and non-flexible for our type of machines. 1 2 Share this post Link to post Share on other sites
kpinnc 18,320 #15 Posted February 13, 2022 9 hours ago, TJ Salyers said: Okay i seen a video @Pullstart made about tire widths the thinner ones worked better. So why do pullers use wide tires which one gives you more traction wide or thin? Traction is affected by contact area and weight. The surface has a great deal to do with it as well, obviously. Pullers operate on a soft surface. Wide tires float on softer terrain, but will slip if the tractor isn't heavy enough. For most residential use, narrow ags grip great. But once they slip, they dig a hole pretty quick. Wider tires float more, but slip sooner for a given weight. In other words, wider ags slip sooner than narrow ones on a garden tractor unless additional weight is added. Short of ice and snow, just about any aggressive tire is more than sufficient for a 600lb tractor. 23x8.5-12 ags are a very good "middle ground" tire. 3 Share this post Link to post Share on other sites
kpinnc 18,320 #16 Posted February 13, 2022 This probably belongs to a member here, but I don't know. 23x10.50-12 OTR ags on a 520: 2 1 Share this post Link to post Share on other sites
TJ5208 1,841 #17 Posted February 13, 2022 (edited) I looked at Carlisle they look like a good tire but the Otrs look good also. But I think I might try Otr or Carlise. Which ones do you guys recommend? Edited February 13, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #18 Posted February 13, 2022 18 hours ago, Maxwell-8 said: turfs will give you more traction on pavement. Have seen GT's with turf tires pull small size pickup trucks on concrete. Do you mean “pull a small truck” as in a pulling contest, or simply moving the truck that had no power of its own ? 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #19 Posted February 13, 2022 (edited) @TJ Salyers… I went with the Hi-Run brand, 23x10.50-12 for the 1984 Work Horse GT-1600 that I am refreshing. My main concern was not traction, but looks… I think Ags look cool. Another reason I went with them is price. I ordered 2 online and picked them up at Lowes. Two of them were about $176.80… after taxes $188.73. I wanted tri-ribs for the front, again mainly for looks, but tri-ribs were a little more difficult to find, and more expensive, so I went with straight ribs… Hi-Run 16x6.50-8 I got two at Lowes also, ordered online and picked them up in the store. I think they were $51.85. Around here near NC-SC border, we don’t get much snow so I won’t be pushing a lot of that. If fact I don’t know what I will actually “use” my Ags for other than to make me look cooler driving the Work Horse. Now I know there are guys on this forum that move a LOT of snow, or till a LOT of earth, so they have the experience on that. Sounds like they are suggesting you to use turfs with chains… and add weight. Edited February 13, 2022 by Horse Newbie 3 Share this post Link to post Share on other sites
Sparky-(Admin) 25,441 #20 Posted February 13, 2022 Are you sure you have the wide rear rims? I’ve looked at pics of your 52O and I’m not completely sure you do. It’s hard to tell in a picture though. 3 Share this post Link to post Share on other sites
Maxwell-8 4,371 #21 Posted February 13, 2022 1 hour ago, Horse Newbie said: Do you mean “pull a small truck” as in a pulling contest, or simply moving the truck that had no power of its own ? pull contest, believe it was a ranger vs a JD 2 Share this post Link to post Share on other sites
TJ5208 1,841 #22 Posted February 13, 2022 (edited) 1 hour ago, Sparky said: Are you sure you have the wide rear rims? I’ve looked at pics of your 52O and I’m not completely sure you do. It’s hard to tell in a picture though. It only has 8 inch rims. Edited February 13, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
kpinnc 18,320 #23 Posted February 13, 2022 3 hours ago, TJ Salyers said: It only has 8 inch rims. I think what Mike was asking is if those rear wheels are the typical 520 wheels. "Standard" WH wheels are 7.5 inches wide, but 520 wheels are 8.5 inches wide. 2 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #24 Posted February 13, 2022 @kpinnc… what are these ? They are from the ‘84 Work Horse GT-1600… 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,441 #25 Posted February 13, 2022 38 minutes ago, Horse Newbie said: @kpinnc… what are these ? They are from the ‘84 Work Horse GT-1600… 7.5” 2 Share this post Link to post Share on other sites
