ebinmaine 75,787 #1 Posted February 11, 2022 My Lead Dismantler, Head of Rust Removal, The Paint Department, Tractor Assembly Technician, Keeper of RIDICULOUS Energy, occasionally known as Trina, Has been mulling over purchasing and modifying a lift to make it easier for us to work on tractors of course, likely also other machinery. I've looked at a few threads from folks here and I like the ideas. Her current focus seems to be the HF 1000 lb motorcycle lift. I do see that some folks are using lift tables. What are you using? How high does it go? What might you do different? 2 1 Share this post Link to post Share on other sites
formariz 12,352 #2 Posted February 11, 2022 The one she is looking at is the most affordable and available that I found. Anything else within that very type is not even close in price being substantially more. A modification such as extending table in width is necessary to make it safe for a tractor . Tying down tractor prior to lifting a must if you want peace of mind. Trust me on that one. Also need to be careful lowering it. Very sensitive hydraulics. Could be too fast. One thing I been thinking about doing. Unit when not in use is obtrusive and on way of walking all the time. Build up floor around it so when not in use it is part of floor. The only draw back to that will be that it cannot be placed in a different location. Just need to have a dedicated spot for it. 2 Share this post Link to post Share on other sites
ebinmaine 75,787 #3 Posted February 11, 2022 8 minutes ago, formariz said: The one she is looking at is the most affordable and available that I found. Anything else within that very type is not even close in price being substantially more. A modification such as extending table in width is necessary to make it safe for a tractor . Tying down tractor prior to lifting a must if you want peace of mind. Trust me on that one. Also need to be careful lowering it. Very sensitive hydraulics. Could be too fast. One thing I been thinking about doing. Unit when not in use is obtrusive and on way of walking all the time. Build up floor around it so when not in use it is part of floor. The only draw back to that will be that it cannot be placed in a different location. Just need to have a dedicated spot for it. She's been looking at two. One of them is sort of like a forklift and the other one is a raising table. I like the idea of having a dedicated spot for it quite a lot but we have three different spaces in which we regularly work on tractors so we would need the freedom of movement. 1 Share this post Link to post Share on other sites
formariz 12,352 #4 Posted February 11, 2022 1 minute ago, ebinmaine said: She's been looking at two. One of them is sort of like a forklift and the other one is a raising table. I like the idea of having a dedicated spot for it quite a lot but we have three different spaces in which we regularly work on tractors so we would need the freedom of movement. Then the forklift type one or a hydraulic table/dolly like used in warehouses would be it. Small and mobile . Just lifting 20 inches is already a tremendous improvement for ones back and comfort while working on them. 2 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,939 #5 Posted February 11, 2022 So, are you suggesting that laying on one’s back in the mud, with a hunk of rock biting into your ribcage while losing pieces and cussing is not the ideal way to do? Huh. 1 10 Share this post Link to post Share on other sites
squonk 44,884 #6 Posted February 11, 2022 (edited) I had one of those Horror Fright Motorcycle tables. Put an oak door on it to make it wide enough for a tractor. It barely picked up my 1467 once. That was it. Nothing helped getting the jack to work right. Plus pumping it with the pedal seem tedious. ended up selling it. I'd cut loose with the cash and get an ATV table lift. OR a HF lift table will lift will most Wh's. Plus you can roll it out of the way. Not sure of a C160 though. Edited February 11, 2022 by squonk 2 Share this post Link to post Share on other sites
stevasaurus 23,517 #7 Posted February 11, 2022 What I use is stuff I already have. I have my little flatbed trailer and some very sturdy ramps for it. I can drive or push a horse up the ramps and onto the trailer. Probably about 16". I then take blocks and place the ramps from the ground end on them. Now I can push the horse back onto the ramps and work on the horse. My ramps hook onto the back of the trailer, so there is no movement there. I suppose I could do the same thing and then put both ends of the ramps on blocks and push the horse on from there. No hydraulics, no lifting, set up where you want, leave until you need the ramps. If there is a draw back, the horse is sitting on it's tires, but you could jack up one end enough to work on wheels, hubs, seals or what ever. 3 Share this post Link to post Share on other sites
Maxwell-8 4,370 #8 Posted February 11, 2022 Oh Eric, those lifts are a life saver. I have used a car scissorlift, or a forklift. Getting those tractors up in the air, it's just so much nicer on the back, knees, etc You could make yourself a wooden table, whit ramps and a cheap HF 2500lbs winch to pull the tractor up the table. would be a cheap option 3 Share this post Link to post Share on other sites
SylvanLakeWH 29,882 #9 Posted February 11, 2022 53 minutes ago, stevasaurus said: What I use is stuff I already have. I have my little flatbed trailer and some very sturdy ramps for it. I can drive or push a horse up the ramps and onto the trailer. Probably about 16". I then take blocks and place the ramps from the ground end on them. Now I can push the horse back onto the ramps and work on the horse. My ramps hook onto the back of the trailer, so there is no movement there. I suppose I could do the same thing and then put both ends of the ramps on blocks and push the horse on from there. No hydraulics, no lifting, set up where you want, leave until you need the ramps. If there is a draw back, the horse is sitting on it's tires, but you could jack up one end enough to work on wheels, hubs, seals or what ever. I’m not visualizing your set up but it sounds good… do you have a pic or two so I can understand the set up? 1 Share this post Link to post Share on other sites
pfrederi 19,278 #10 Posted February 11, 2022 I have a lift table like Squonk but you have to take the belt guard off to use it. Tachmatics cause issues also. Build a table and pick her up slide table under it...... 4 3 Share this post Link to post Share on other sites
squonk 44,884 #11 Posted February 11, 2022 My lift table is used for more than just the tractors. Unloading the truck, moving Ac units and is the base for my engine run stand. 6 Share this post Link to post Share on other sites
Achto 30,210 #12 Posted February 11, 2022 (edited) I use a motor cycle lift to work on my tractors. I made the extension block that you see on top for 2 reasons. 1 - 3" of extra height. 2 - It's only 1/4" wider than the frame on each side. This allows you to assemble the whole tractor while it is on the lift, even the belt guard. The tabs on top fit inside of the frame and keep the tractor from from sliding off side to side. The tabs on the bottom keep the extension from sliding off of the lift. Comfortable height to sit on a shop stool & work on the tractor. Don't take up much room either. Edited February 11, 2022 by Achto 8 5 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #13 Posted February 12, 2022 Get a used hospital bed like @Stormin has , I am sure he will provide photos. 2 1 Share this post Link to post Share on other sites
kpinnc 16,227 #14 Posted February 12, 2022 Whatever you use, either anchor it to the floor or make the base as wide as possible. The center of gravity moves quite a bit when you remove stuff. One loaded wheel can flip the tractor over if the base isn't sturdy. Or make one like mine... 5 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #15 Posted February 12, 2022 3 hours ago, pfrederi said: I have a lift table like Squonk but you have to take the belt guard off to use it. Tachmatics cause issues also. Build a table and pick her up slide table under it...... First pic… I thought that Horse was levitating… 4 Share this post Link to post Share on other sites
Horse Newbie 7,398 #16 Posted February 12, 2022 15 minutes ago, kpinnc said: Or make one like mine... Show - off ! 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #17 Posted February 12, 2022 16 minutes ago, kpinnc said: Whatever you use, either anchor it to the floor or make the base as wide as possible. The center of gravity moves quite a bit when you remove stuff. One loaded wheel can flip the tractor over if the base isn't sturdy. Or make one like mine... Now I know where to borrow one for my next refresh ! 1 1 Share this post Link to post Share on other sites
kpinnc 16,227 #18 Posted February 12, 2022 6 minutes ago, Horse Newbie said: Show - off ! I know, I know... But Eb did ask! I'd love to have a hoist like pfrederi! 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #19 Posted February 12, 2022 5 minutes ago, kpinnc said: know, I know... But Eb did ask! That is true… the walls have eyes… and ears… Share this post Link to post Share on other sites
Pullstart 68,533 #20 Posted February 12, 2022 Why not have HER lift the tractor? She’s Black Belt Trina for cryin’ out loud! 6 1 Share this post Link to post Share on other sites
Stormin 9,986 #21 Posted February 12, 2022 (edited) 11 hours ago, elcamino/wheelhorse said: Get a used hospital bed like @Stormin has , I am sure he will provide photos. Hospital bed tractor lift. Handiest thing I've got for free. A tractor will just fit on nicely. A hand winch is fitted to one end to pull tractors up. A removable handle at the other to move it around. It also comes in handy as a mobile work bench. P.S. Some support at the ramp end is an idea. Tends to lift the winch end at first. I find height wise it's ok when down. It can be raised by the foot pump. OH! And remember to put the brakes on. Edited February 12, 2022 by Stormin 2 6 Share this post Link to post Share on other sites
ebinmaine 75,787 #22 Posted February 12, 2022 10 hours ago, Horse Newbie said: First pic… I thought that Horse was levitating… It is. @pfrederi Paul's a wizard... Lots of excellent ideas here as always folks. Thank you for posting. We both like the tables quite a lot. Space, or lack of, could be a deciding factor there. The ceiling mounted chain falls really got her attention. That may just work out well because I have a chain falls and 10 foot channel I've been considering moving to the basement specifically to lift/adjust/install the engine on Colossus. 7 hours ago, Pullstart said: Why not have HER lift the tractor? She’s Black Belt Trina for cryin’ out loud! I'll tell her this is the final solution and keep you posted for feedback. 3 Share this post Link to post Share on other sites
squonk 44,884 #23 Posted February 12, 2022 Electric lift hospital beds would be cooler! Threw out so many beds at work. Hospital had a strict policy. All old beds had to be scrapped. 3 Share this post Link to post Share on other sites
Stormin 9,986 #24 Posted February 12, 2022 6 hours ago, squonk said: Electric lift hospital beds would be cooler! Beggars can't be choosers. It was at an engineering shop not far from me and destined for the skip. 1 Share this post Link to post Share on other sites
ebinmaine 75,787 #25 Posted February 14, 2022 (edited) As a partial solution and part of my thought process I hung my chain falls in the basement workshop temporarily. I wanted to have both of us be able to get an idea of where it would sit. The hoist itself would be out of the way for the most part because it'll live right where it is sitting now, up against the pegboard wall. For the chain falls bracket fastening, I think I've come up with a good solution. A 2x6 board above the 10' long rail will be 12' long so I can grab an extra joist. Three 4" long (#10 deck screws or 1/4" lags) in every joist. Then, to hang the rail I'll use five total brackets with bolts that go through the 2x6. The deck screws should have a real-world pull out of somewhere above 600 lb each. That should give me a pretty fair safety margin for lifting several hundred pounds. Thoughts comments suggestions questions as always are welcome.... Edited February 14, 2022 by ebinmaine 1 Share this post Link to post Share on other sites
