ebinmaine 77,340 #1 Posted January 17, 2022 I'm no metallurgist. I need to make a couple belt guard guides for the Colossus project. It'll be "open concept" with only the belt covered and supported leaving the middle space open except possibly the area where the clutch pulley moves up and down. Would aluminum L or C channel be strong enough and have good enough wear resistance to the belt rubbing? Or do I really need to stick to using steel sheet metal? Share this post Link to post Share on other sites
SylvanLakeWH 30,594 #2 Posted January 17, 2022 No input on the type of metal as I am not knowledgeable enough to comment. Look forward to the responses. Question though: why open? Seems you are exposing yourself to accidental safety concerns… shoelaces, clothing, fingers etc. Those guards have evolved for a reason and, notwithstanding the never ending OSHA jokes, I’d be very cautious with exposed belts… Share this post Link to post Share on other sites
ebinmaine 77,340 #3 Posted January 17, 2022 10 minutes ago, SylvanLakeWH said: No input on the type of metal as I am not knowledgeable enough to comment. Look forward to the responses. Question though: why open? Seems you are exposing yourself to accidental safety concerns… shoelaces, clothing, fingers etc. Those guards have evolved for a reason and, notwithstanding the never ending OSHA jokes, I’d be very cautious with exposed belts… Oh no no no no. No chances taken here. The MIDDLE will be open. The belt will be completely covered. Two separate pieces at top and bottom. 2 Share this post Link to post Share on other sites
peter lena 9,764 #4 Posted January 17, 2022 @ebinmaine how much different is your plan , vs original set up ? personally ,channel steel , is bombproof, would also get it in a thicker grade, that also applies to the possible angle. make your contact / set area on the best ,flat area , for effect , pete 2 Share this post Link to post Share on other sites
Ed Kennell 44,877 #5 Posted January 17, 2022 Steel would be my choice. It is harder and would wear better. Also, IMO, steel is much easier to fab tham aluminum. It cuts and grinds easier... no smearing and clogging of abrasive wheels and it is easier to weld. I can see 1X1 steel "U" channel working well to cover and support a belt. Just remember the top loop will need to move vertically with the belt tensioner pulley. 7 1 Share this post Link to post Share on other sites
ebinmaine 77,340 #6 Posted January 17, 2022 17 minutes ago, peter lena said: how much different is your plan , vs original set up ? Original on a C series, as we know, covers the whole area of travel of the entire belt except the very ends around the engine and transmission pulleys. I'm building something like "Captain 315" & "Creepy crawler" on YT have done to increase grip... but ENCLOSING the BELT ONLY in a C channel as referenced by @Ed Kennell. The lower portion would be fairly easy as it's a straight shot. The upper half... Not sure yet. Perhaps a pulley setup sort of similar to this: Which would give a fuller wrap at the rear pulley. 23 minutes ago, Ed Kennell said: Steel would be my choice. It is harder and would wear better. Also, IMO, steel is much easier to fab tham aluminum. It cuts and grinds easier... no smearing and clogging of abrasive wheels and it is easier to weld. . Thanks for that reminder. Very true. 27 minutes ago, Ed Kennell said: I can see 1X1 steel "U" channel working well to cover and support a belt. Just remember the top loop will need to move vertically with the belt tensioner pulley 1 x 1 or .75 x .75 is what I was figuring. The larger would certainly offer a bit more rigidity and adjustment. I hadn't considered to make the top piece movable but that could be a good idea. Fastening it directly to the clutch lever somehow with a sliding pivot could give constant proper position of the top of the belt. Share this post Link to post Share on other sites
Lee1977 7,553 #7 Posted January 17, 2022 (edited) His tractor is working backwards from yours he's lossen the belt on the transmission pulley, You need the bottom of the top belt supported and the bottom of the lower to loosen on the engine pulley this will be when the belt is stopped with the clutch pushed in. Set that up first fixed position should work just fine, Then add the rest it will just be a guard doesn't have to be that close to the belt, you can set it with the clutch out. Edited January 17, 2022 by Lee1977 2 Share this post Link to post Share on other sites
ranger 1,840 #8 Posted January 17, 2022 (edited) Stainless steel, no rusting, nice and ‘Slippery’ you can polish it up to a nice finish, no need to paint it. Added ‘Bling’ (not sure what the ‘Paint Shop’ would have to say about this though?). If you need to weld it, consider, ‘stick’ welding rods, ( if the metal is thick enough), rather than Mig, with Mig you need Pure Argon or Helium gas, (Expensive on this side of the pond!). (Beware, if stick welding Stainless, the ‘Slag’ covering the weld, as it cools, will shatter and fly in all directions, this even before you lay into it with the chipping hammer, so Safety Glasses Please).You can Mig Stainless with mild steel wire and Argon/Co2 mix, but you will then need to paint it! However, if you have a ‘TIG’ set, you will already have a suitable gas. Edited January 17, 2022 by ranger 2 Share this post Link to post Share on other sites
8ntruck 8,603 #9 Posted January 17, 2022 I agree with @Ed Kennell. Steel is about 3 times stronger than aluminum, but also about 3 times heavier. In your application, I don't believe that weight will be a consideration. Being stronger, steel will stand up better to oopseies that might happen out in your woods. Will also stand up better to occasional contact with bear feet..... 1 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #10 Posted January 17, 2022 25 minutes ago, 8ntruck said: I agree with @Ed Kennell. Steel is about 3 times stronger than aluminum, I once had my shoe against the belt for just a second. big cut in the sole. Those belts grind fast! try sanding alloy or steel. you will see the different. Haven't seen someone making a belt guard out of alloy. Probably for good reason. 2 Share this post Link to post Share on other sites
CCW 1,491 #11 Posted January 17, 2022 Only aluminum I would consider is aircraft quality material. I have a piece, but welding it is very difficult and not bendable. 1 Share this post Link to post Share on other sites
ebinmaine 77,340 #12 Posted January 17, 2022 2 hours ago, 8ntruck said: I agree with @Ed Kennell. Steel is about 3 times stronger than aluminum, but also about 3 times heavier. In your application, I don't believe that weight will be a consideration. Being stronger, steel will stand up better to oopseies that might happen out in your woods. Will also stand up better to occasional contact with bear feet..... In my particular situation More weight is better. Valid point on the Bear 🐻 contact. 😂 1 Share this post Link to post Share on other sites
Reddart 213 #13 Posted January 22, 2022 I would also be concerned about galvanic corrosion with aluminum, depending on how the guard is bolted up to the steel. 1 Share this post Link to post Share on other sites
CCW 1,491 #14 Posted January 22, 2022 11 hours ago, Reddart said: I would also be concerned about galvanic corrosion with aluminum, depending on how the guard is bolted up to the steel. Would need to use stainless steel washers between aluminum and steel along with a SS bolt. Share this post Link to post Share on other sites
