Sam77 4 #1 Posted January 3, 2022 Ok, I’m having problems with my 1965 wheel horse 875. Is there anyone out there who lives near or around Auburn Indiana? That can come help me get things sorted out?? Way to much to explain, on here! Willing to pay for your time, and fuel if don’t leave extremely far away!! I love this tractor and want things done right on her! Share this post Link to post Share on other sites
rjg854 13,341 #2 Posted January 3, 2022 I'm sure if you can describe at least one problem, we can get you started in the right direction. First off does it run? Share this post Link to post Share on other sites
Pullstart 71,215 #3 Posted January 3, 2022 @bottjernat1 is nearby there, but he doesn’t frequent much lately. We are all here to help too! Share this post Link to post Share on other sites
Sam77 4 #4 Posted January 3, 2022 Yeah she runs! But I done messed with throttle and the rear end. Got lever to say stay in neutral. But as soon as let loose of brake she takes off and belt squeal’s BAD!! And the throttle is my fault I adjusted cable and now runs wide open and then some! I can figure that problem out! Just don’t know about hydrostatics! I spent all New Year’s Day trying to sort it out!! I need help!! Share this post Link to post Share on other sites
Sam77 4 #5 Posted January 3, 2022 Is it maybe that I got the lever sorted out and I need to adjust it again since have forward and reverse lever kinda sorta fixed?? Share this post Link to post Share on other sites
rjg854 13,341 #6 Posted January 3, 2022 Did you have the belt cover off? Share this post Link to post Share on other sites
Sam77 4 #7 Posted January 3, 2022 No, don’t have belt cover off, see I was thinking belt needs replaced Share this post Link to post Share on other sites
rjg854 13,341 #8 Posted January 3, 2022 I was wondering if you had the cover off, did you get the belt routed properly when you put the cover back on. I usually engage the belt in the running position to put the cover back on. That way the belt doesn't get bound up in some fashion. 1 Share this post Link to post Share on other sites
Sam77 4 #9 Posted January 3, 2022 I never took belt off. I adjusted the forward and reverse lever. A while back, but then I got lever fixed where it won’t just drop into forward or reverse now. Should I adjust the linkage again?? Share this post Link to post Share on other sites
Pullstart 71,215 #10 Posted January 3, 2022 Let’s start with a throttle / governor adjustment. No need to blow up the engine trying to figure out the motion control. I realize this is an 8 hp engine, it it’s the same governor adjustment. It should be able to overcome a poor throttle adjustment… but it’s best to disconnect the throttle cable first. 1 1 Share this post Link to post Share on other sites
Sam77 4 #11 Posted January 3, 2022 23 minutes ago, rjg854 said: I was wondering if you had the cover off, did you get the belt routed properly when you put the cover back on. I usually engage the belt in the running position to put the cover back on. That way the belt doesn't get bound up in some fashion. Yeah, I moved the throttle body to where when you pull the cable, she opens up way more then she should!! It’s bad, I need to adjust it back to where it was. That I believe can sort out. Share this post Link to post Share on other sites
Sam77 4 #12 Posted January 3, 2022 I’m a 3rd shifter, and don’t have her up where I can take a video of what my problem is. I’ll do it tomorrow morning, and hopefully this helps with my predicament I’m in. My throttle I done messed with that, where I probably should of left well enough alone!! Share this post Link to post Share on other sites
rmaynard 17,575 #13 Posted January 3, 2022 (edited) I'm with @Pullstart on this one. Sounds like you got the governor out of whack. Not a big problem if you follow the instructions to the letter on properly adjusting it. Your problem with the hydro could be as simple as a bad adjustment of the friction control. or maybe the nylon parts are cracked or broken. Edited January 3, 2022 by rmaynard 1 Share this post Link to post Share on other sites
Sam77 4 #14 Posted January 3, 2022 1 minute ago, rmaynard said: I'm with @Pullstart on this one. Sounds like you got the governor out of whack. Not a big problem if you follow the instructions to the letter on properly adjusting it. Your problem with the hydro could be as simple as a bad adjustment of the friction control. Ok, I will give it go ASAP!! When I get out work in am!! Outstanding!! Thanks y’all for the help! If these don’t work, well I’ll be right back on here!! 😂😂 1 1 Share this post Link to post Share on other sites
Sam77 4 #15 Posted January 3, 2022 Just now, Sam77 said: Ok, I will give it go ASAP!! When I get out work in am!! Outstanding!! Thanks y’all for the help! If these don’t work, well I’ll be right back on here!! 😂😂 Oh I will take a video to show what my issue is!! It’s getting frustrating!! Share this post Link to post Share on other sites
Pullstart 71,215 #16 Posted January 3, 2022 As you can see, we’re all here to help. Sometimes, you even make a couple friends! Sometimes, they feed you off the poop scooper! 2 Share this post Link to post Share on other sites
D_Mac 9,339 #17 Posted January 3, 2022 I would also make sure you have the right size belt. Share this post Link to post Share on other sites
SylvanLakeWH 32,464 #19 Posted January 3, 2022 6 hours ago, Pullstart said: As you can see, we’re all here to help. Sometimes, you even make a couple friends! Sometimes, they feed you off the poop scooper! So that’s where cheese curds come from and the correct way to eat them…?!?! And @Sam77!!! 1 Share this post Link to post Share on other sites
Pullstart 71,215 #20 Posted January 3, 2022 1 minute ago, SylvanLakeWH said: So that’s where cheese curds come from and the correct way to eat them…?!?! And @Sam77!!! Nope, that’s @Achto’s Mac n cheese. Too good to toss, even when it hits the Big Show floor! 1 Share this post Link to post Share on other sites
Sam77 4 #21 Posted January 3, 2022 36 minutes ago, Pullstart said: Nope, that’s @Achto’s Mac n cheese. Too good to toss, even when it hits the Big Show floor! What’s that going on? I See a bunch of wheel horses in background. Share this post Link to post Share on other sites
Pullstart 71,215 #22 Posted January 3, 2022 5 minutes ago, Sam77 said: What’s that going on? I See a bunch of wheel horses in background. The “Big Show” in Biglerville, PA in June. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,464 #23 Posted January 3, 2022 1 hour ago, Pullstart said: The “Big Show” in Biglerville, PA in June. 1 hour ago, Sam77 said: What’s that going on? I See a bunch of wheel horses in background. here is some info… https://www.wheelhorseforum.com/forum/13-wheel-horse-collectors-club-show/ Share this post Link to post Share on other sites
