kpinnc 18,960 #26 Posted January 12, 2022 I have another one, but it won't come close to looking "original" on anything. That being said, it's crazy bright. Like mow in the dark bright... 2 3 Share this post Link to post Share on other sites
19richie66 17,935 #27 Posted January 12, 2022 I put these on the rear of my gt14. I don’t even have them as bright as they will go and you can’t look straight at them. Same bolt holes as the original. Not sure how bright the whites would be for headlights. https://www.feniex.com/surface-mount/t3 2 Share this post Link to post Share on other sites
peter lena 10,065 #28 Posted January 12, 2022 @19richie66 that battery ground bolt is what i,m talking about ! since adding that to all my stuff , along with previous obvious , past wiring issues , electrical issues are gone. another thing i add to wiring runs is bolt on electrical lugs, not only securing the wire run , but giving you quick access to adding wire. take advantage of a problem and eliminate it , what a concept !, pete 1 Share this post Link to post Share on other sites
kpinnc 18,960 #29 Posted January 12, 2022 1 hour ago, 19richie66 said: I put these on the rear of my gt14. I don’t even have them as bright as they will go and you can’t look straight at them. Same bolt holes as the original. Not sure how bright the whites would be for headlights. https://www.feniex.com/surface-mount/t3 Those are pretty cool! How much of a voltage drop do you get with them? 1 Share this post Link to post Share on other sites
19richie66 17,935 #30 Posted January 12, 2022 Not much draw at all. Rated at .750 amps each. I don’t think the tractor even realizes they are on plus they are metal housing, sealed and five year warranty. I am very happy with them. 4 Share this post Link to post Share on other sites
kpinnc 18,960 #31 Posted January 12, 2022 8 hours ago, 19richie66 said: Not much draw at all. Rated at .750 amps each. I don’t think the tractor even realizes they are on plus they are metal housing, sealed and five year warranty. I am very happy with them. I certainly like them! A bit expensive, but not so much when you realize they probably will never need replacing. Gonna have to try a set! 2 Share this post Link to post Share on other sites
19richie66 17,935 #32 Posted January 12, 2022 (edited) 33 minutes ago, kpinnc said: I certainly like them! A bit expensive, but not so much when you realize they probably will never need replacing. Gonna have to try a set! You can kind of see how bright they are but are way better when it’s dark. Picture does them no justice. You can find them on ebay sometimes at a good price. Place where I got mine isn’t on there anymore. Edited January 12, 2022 by 19richie66 2 6 Share this post Link to post Share on other sites
Jeff-C175 7,211 #33 Posted January 12, 2022 Most excellent Richie! 2 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #34 Posted January 12, 2022 19 minutes ago, Jeff-C175 said: Most excellent Richie! Don 1 1 Share this post Link to post Share on other sites
kpinnc 18,960 #35 Posted January 13, 2022 5 hours ago, 19richie66 said: You can kind of see how bright they are but are way better when it’s dark. Picture does them no justice. They look great to me! I think those are the same that were installed on our company trucks and used as strobes. They were very bright! 2 Share this post Link to post Share on other sites
oliver2-44 11,750 #36 Posted January 13, 2022 22 hours ago, kpinnc said: I have another one, but it won't come close to looking "original" on anything. That being said, it's crazy bright. Like mow in the dark bright... @kpinnc are these bulbs are complete lights with housings. If they are bulbs, will they fit in the C series housings. Any links to source appreciated. Share this post Link to post Share on other sites
kpinnc 18,960 #37 Posted January 13, 2022 (edited) 19 minutes ago, oliver2-44 said: @kpinnc are these bulbs are complete lights with housings. If they are bulbs, will they fit in the C series housings. Any links to source appreciated. The one in the pic you copied doesn't fit any wheel horse without modification. There are dozens of versions to fit C series housings online. Anything corresponding to a 1156 bulb will work. I've ordered several from superbrightleds.com, but you can also find them in automotive sections of any Walmart. Just make sure that you get white LEDs. Even then colors will vary from slightly amber (3000) to bluish (6000). Lumen ratings also vary from low 100s to around 400. The higher the number the brighter. https://www.superbrightleds.com/search/led-products/1156/ Edited January 13, 2022 by kpinnc 2 Share this post Link to post Share on other sites
19richie66 17,935 #38 Posted January 13, 2022 8 hours ago, kpinnc said: They look great to me! I think those are the same that were installed on our company trucks and used as strobes. They were very bright! I believe these have 11 flash patterns and two solid on settings. One is on @10% and the other is @70%. Mine are at 10% and they are bright to look at. I would like to try their work lights. They look well made. 2 Share this post Link to post Share on other sites
kpinnc 18,960 #39 Posted January 25, 2022 (edited) I promised some comparisons, and almost forgot that. Here's one for PAR 36 bulbs in the same tractor. First is incandescent. Second is LED. Edited January 25, 2022 by kpinnc 3 2 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #40 Posted December 3, 2022 Just found this thread while researching to put some LED's on my C-121, thanks for the thread! I just ordered some 1156 led replacements, we will see how they work. I also don't have lenses on any of my horses, so @ebinmaine volunteered Trina to trace a lens for me and I will make some out of lexan. I will let you know how that turns out! Randy 2 Share this post Link to post Share on other sites
RandyLittrell 3,945 #41 Posted December 3, 2022 Just found this thread while researching to put some LED's on my C-121, thanks for the thread! I just ordered some 1156 led replacements, we will see how they work. I also don't have lenses on any of my horses, so @ebinmaine volunteered Trina to trace a lens for me and I will make some out of lexan. I will let you know how that turns out! Randy 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #42 Posted December 3, 2022 Just found this thread while researching to put some LED's on my C-121, thanks for the thread! I just ordered some 1156 led replacements, we will see how they work. I also don't have lenses on any of my horses, so @ebinmaine volunteered Trina to trace a lens for me and I will make some out of lexan. I will let you know how that turns out! Randy 1 Share this post Link to post Share on other sites
peter lena 10,065 #43 Posted December 3, 2022 @19richie66 like your enhanced grounding set up , have found to be the most important part of ensuring electrical issues . usually get to the same spot in a recurring situation , always looking for a chance to improve things , latest gain , has been in throttle linkage set up and spring return follow . eliminating , play , no matter how slight , lubrication detailing , starts are near instant , pete 2 1 Share this post Link to post Share on other sites
peter lena 10,065 #44 Posted December 3, 2022 @Snoopy11 snoop , was just trying to get a slight gain on a start , there was a horizontal throttle spring pull , lower on the linkage set up , noticed a very slight gap in spring reaction . used small channel lock plyer , to tighten the spring pull hole end , eliminating play / response . super lube oil on every movement spot . that did it , instant start , almost immediate choke back off , just the details , my other horse , that has regularly instant started , has made me try this , now have to do the other one , just a little tweak . you know what i,m talking about , pete 1 1 Share this post Link to post Share on other sites
kpinnc 18,960 #45 Posted March 29, 2024 Old thread, but this is a good example of the difference between "cool" (6000) and "warm" (4500) PAR 36 LEDs. And for all the non-believers, that bright thing in the background is afternoon sunlight. These things are bright in daylight! 2 2 1 Share this post Link to post Share on other sites
kpinnc 18,960 #46 Posted March 29, 2024 2 hours ago, kpinnc said: And for all the non-believers, that bright thing in the background is afternoon sunlight. These things are bright in daylight! Same for tail lights for that matter... 2 1 Share this post Link to post Share on other sites
fourwheelhorseman 362 #47 Posted December 4, 2024 On 1/9/2022 at 7:30 AM, kpinnc said: I got them on Ebay. https://www.ebay.com/itm/131350640228 So do those come in the correct size already? That really looks good! 1 Share this post Link to post Share on other sites
kpinnc 18,960 #48 Posted December 5, 2024 (edited) On 12/3/2024 at 9:14 PM, fourwheelhorseman said: So do those come in the correct size already? That really looks good! I have used these on two different tractors and did not have to change anything. Just be careful the wiring is a bit delicate. Mine have lasted more than three years now with no issues. Edited December 5, 2024 by kpinnc 1 1 Share this post Link to post Share on other sites
fourwheelhorseman 362 #49 Posted December 5, 2024 6 hours ago, kpinnc said: I have used these on two different tractors and did not have to change anything. Just be careful the wiring is a bit delicate. Mine have lasted more than three years now with no issues. It looks like thier out of stock, I’ll order when they’re back in stock. Thanks! Share this post Link to post Share on other sites
Bar Nuthin 3,217 #50 Posted December 5, 2024 15 minutes ago, fourwheelhorseman said: It looks like thier out of stock, I’ll order when they’re back in stock. Thanks! There are several on the jungle site. I chose these because of the lens. Give them "somewhat" of an original appearance. These were installed in a pair of vintage light housings. https://a.co/d/ecFMkc1 Untitled_video_-_Made_with_Clipchamp_(3).mp4 1 2 Share this post Link to post Share on other sites
