moe1965 774 #1 Posted November 26, 2021 I'm knit picking everything before I start it was told it ran 3 years ago. . New rear end seals new fuel line cleaned tank fixing a few minor issues on the way. One question .....the lift leaver only has locked in up.position and down. No settings in between????? My 854 has a knob adjuster that i can set the down position where i choose. Am i missing something or is something frozen up on this modle i need to look at. Thanks in advance. 5 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted November 26, 2021 6 minutes ago, moe1965 said: I'm knit picking everything before I start it was told it ran 3 years ago. . New rear end seals new fuel line cleaned tank fixing a few minor issues on the way. One question .....the lift leaver only has locked in up.position and down. No settings in between????? My 854 has a knob adjuster that i can set the down position where i choose. Am i missing something or is something frozen up on this modle i need to look at. Thanks in advance. Nope, some 312, didn't came with the dial a height knob 4 Share this post Link to post Share on other sites
clueless 3,438 #3 Posted November 26, 2021 Most of the early 312-8 came with a 1 inch rear axle and no adjustment implement height knob unless you ordered it. 2 Share this post Link to post Share on other sites
JCM 11,415 #4 Posted November 26, 2021 1989 312-8 No dial a height here. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,484 #5 Posted November 26, 2021 Click on the picture in the link 1 Share this post Link to post Share on other sites
953 nut 69,148 #6 Posted November 26, 2021 1 hour ago, moe1965 said: knit picking everything before I start it That will day dividends in the future, make it correct now and you'll have less downtime later. 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #7 Posted November 27, 2021 I added the dial a height to a 310-8 some years ago . Took a couple of hours . 2 Share this post Link to post Share on other sites
oliver2-44 11,735 #8 Posted November 27, 2021 You can get a used Dial-A-Heigth and add it if desired. 2 Share this post Link to post Share on other sites
clueless 3,438 #9 Posted November 27, 2021 Did my '89 312 a couple of years ago, got everything I needed off ebay and A-ZTractors, got the decals from Terry. 2 Share this post Link to post Share on other sites
kpinnc 18,939 #10 Posted November 27, 2021 (edited) 1 hour ago, Maxwell-8 said: Nope, some 312, didn't came with the dial a height knob 17 minutes ago, oliver2-44 said: You can get a used Dial-A-Heigth and add it if desired. He beat me to it! Might not have come with it, but almost certain the proper holes and such are in the hoodstand for the stop and adjuster to be added. Edited November 27, 2021 by kpinnc 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #11 Posted November 27, 2021 Do you all think I could add a “Dial-a-Height” to a 1984 Work Horse GT-1600 ? Share this post Link to post Share on other sites
kpinnc 18,939 #12 Posted November 27, 2021 15 minutes ago, Horse Newbie said: Do you all think I could add a “Dial-a-Height” to a 1984 Work Horse GT-1600 ? If your dash tower has the hole in it on the left side. Then yes you can. See the zoomed pic below. 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #13 Posted November 27, 2021 Thanks @kpinnc… I’ll check ! Share this post Link to post Share on other sites
peter lena 10,047 #14 Posted November 27, 2021 @moe1965 , the condition of your rig looks clean , remove that related shifter plate , an aerosol the cross shaft end points , if you start getting a rusty run out , that could be your issue . track down every related area /opportunity to get some lubrication in there , constantly attempt to function it , if it starts to leak rust and it starts to move , you are on track . pete 1 Share this post Link to post Share on other sites
