Jeff-C175
More C-125 / K301 questions with photos...
Jeff-C175
I put together a replacement for the missing clutch handle today.  I like it so much I'm going to make one for my C-175 also!
Now I need to figure out how come it's not staying DISengaged.  It EASILY jumps off the detent at the slightest touch.  It appears to be a new bracket / lever, judging from the paint on it, but I have not investigated further yet.  Wonder if anyone has run into this and solved it?
What is the correct routing for the throttle cable?  This just CAN'T be correct!  It's right on the cooling fins of the engine, it's done melted the skin off the cable!  Maybe it's a replacement cable and simply too short?
If someone could post a pic of the correct routing it would be much appreciated!
While looking that over I noticed some oil 'weepage' at the front of the engine.  To me it appears to be concentrated right under the fuel pump.  I presume there's a gasket there that may need to be refreshed?
The only other suspect is the valve cover but and that appears to be a little weepy too, but  more so the fuel pump.
What say you K301 gurus?
Jeff-C175
Edited by Jeff-C175
rjg854
That seepage, does it feel oily or just wet? Does it smell like oil or gas?
Snoopy11
:text-yeahthat:
Google... KOH 25-041-10
Don
23 Reo
My 1981 C-125 clutch handle would not stay disengaged either. I never tried to fix as I thought it was just worn out. It was my first Wheel Horse.
Jeff-C175
Ya know what?  I didn't actually stick my fanger in it !  I'll do that later, and maybe give it a taste too.
But, I don't believe it's gas... I would have smelt that being that I've been working up close the past few days.  Almost certain it's Earl.
Now that ya got me thinkin' about it though, aren't these the fuel pumps that can dump gasoline into the crankcase if the diaphragm takes a dump?
"I'll fix your flat tire Merle,
don't ya get your sweet country pickin' fangers all covered in Earl..."
Edited by Jeff-C175
Snoopy11
And yes, I knew that part number off the top of my head... :laughing-rolling:
Don
  • Haha 1
Jeff-C175
It can be especially exciting if you're not in the seat and the motion lever is in FORWARD, and the machine lurches toward your wife's vintage Monte Carlo!
  • Haha 1
rjg854
Yeap
Maxwell-8
16 minutes ago, Jeff-C175 said:
That looks killer.
Your problem would seem to be a worn backet? wrong spring angle?.
Since my new belt is not yet stretched. I have the opposed problem where the disengage is jumping on, and the handle gets hung up in the up position
sparkie333
That looks like where my cable is at----I don't know the part #:eusa-think::laughing-rofl:
Snoopy11
:hilarious:
Neither do I... :laughing-rolling:
Don
Maxwell-8
22 minutes ago, Jeff-C175 said:
Thats How my M12 looks currently. fuelpump is leaking...
sparkie333
Now that made me laugh ----Good to be able to laugh once in a while---
I need to get used to it my sister called me today and wished me a belated 71th as of yesterday--:USA::snooty::text-offtopic:
Snoopy11
Let me be the second!
Happy Birthday buddy! :lol:
Don
sparkie333
Don
Thanks -----and to all a ----Happy Thanksgiving--- And I'm unanimous in this.....
  • Excellent 2
Jeff-C175
Changed the transmission oil and filter this evening.  It was really black and stunk pretty bad.
Ran a magnet through the drain pan, only a few tiny tiny little chips of metal, so trans is probably OK.
I'll run it for a while and change it again before it's due date.
Anyone know if this is a date code on the old filter?
First week of 2006?  If it is, I believe it.  But then, I've got underwear older than that!  :omg:
Also, the fender pan had been sprayed with rubberized bed liner and I just didn't care for it so I stripped that all off.  Heat gun and a scraper and it came right off.  Quite a bit of rust under the bedliner.  Tomorrow I'll clean up the metal and try to get it painted before dinner.
@sparkie333 Happy Birthday!
And to everyone, HAPPY THANKSGIVING!
Edited by Jeff-C175
Tuneup
My 125's replacement was off a 520H so it's for an auto. You did better - clearly a manual's pan. Sadly, once they went to the foil labels, we can't even make an educated guess. Looks like it will clean-up nicely. Just turned the turkey in the brine for a wonderful frying around 2PM. Happy Thanksgiving back at'cha!
Jeff-C175
3 hours ago, Tuneup said:
manual's pan
How can you tell?
The one I got for my 175 decades ago is the exact shape of this one but there are some differences.  The one on the 175 has a square opening in the center under the seat. You can see this one goes not.  Also, there's an extra hole on the 175 for the seat safety switch, that hole is not in this one.  I'll have to use one of the other ones or drill a new one.
peter lena
@Jeff-C175  noting that cabling issue , looks like it needs a total reroute , not in the book , another thing i noticed was the linkage spring pull  point, have two springs , mounted on all my  cable mountings , one pulling each way . along with a thorough lubrication verification , with super lube , makes for total cable ease , also a great spot to fuel check valve just under that carb . rerouted my cables long ago , and increase the cable mount areas , cable flop , amounts to  poor reaction . pete
peter lena
@Jeff-C175  just some of the spring improvements i use, ever try to push a cable ? that's what a single spring will amount to , also mount perforated trim metal to related mount so i have an instant counter pull point . that gives linkage a smooth sweet spot of direction, lots of hours on this set up , this in not in the book . but it sure does work , pete
Jeff-C175
10 minutes ago, peter lena said:
total reroute
Looks like the routing is correct just that the cableis a little short, like maybe 2" or so.
Dorman has a 'universal' cable for not much $$ but it's not plastic sheathed which I would prefer.
But that part is low on the priority list because for now it's working fine.
Snoopy11
Don
:text-yeahthat: @Maxwell-8!!! :P
Don
peter lena
@Snoopy11  that should be a quick fix and possible upgrade , always have a new spare pump in my w/h stuff , along with heim joints , fuel filters , oil additives , lots of goodies , pete
Jeff-C175
I routed the cable on the OUTSIDE of the oil dipstick tube and clamped onto the very end of the cable, there was about an inch extra there.  I turned the clamp bracket a few degrees and put a couple layers of heat shrink over the cable.
Looks like this will do the trick, it's not laying on the cylinder head fins any longer.
  • Similar Content
    • Natejc_98
      By Natejc_98
      I’m looking for the recommended process to restore old wheels from grinding to sanding to painting. Also what tools are preferred in the process?
    • Charles99
      By Charles99
      ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
      My troubleshooting so far:
      Fuel:
      • stabil/87 and clean
      • good flow before and after pump
      • carb clean, recently rebuilt, float level correctly set
      Compression:
      •good? - blows finger off spark plug hole
      •good turnover but doesn’t fire off
      •piston and cylinders move freely
      •valve lash set .008 intake .018 exhaust
      •breather assembly correct and recently serviced with new gaskets and filter
      •head gasket not broken, head bolts tight, some carbon on head
      Spark:
      •no spark
      •all electrical/ignition components were replaced 1 year ago except voltage regulator
      •no loose connections, no grounding connections
      •inspected and applied graphite to starter shaft
      •changed plug
      •12v to coil good
      •cleaned points, points wire has continuity
      •condenser ground good
      •swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
      •points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
      What else should I check/do?
    • Tuneup
      By Tuneup
      Hi all,
      Summary: Solid mounts a year ago were very nice. Removed balance gears last December. Unacceptable. Installed eBay originals in good condition. I can ride it again at full throttle AND keep my fillings.
      Long story (I have the day off):
      A thread inspired me last December to look and see if my balance gears were doing well and the rear one was a wobbler. Removed them. She was burning too much oil - original rebuild was just a stone hone and power was not as it should be - it took months to get it bored .020. Hard to find in GA. Installed everything and started her up. Solid mounts USED to be great! That old off-idle vibration that shook the hood was gone thanks to those mounts. A little more vibration was OK. After the removal of the balance gears - NOT! The thing makes my butt numb and I can't mow at higher than about 2500 RPM. The hood vibrates just too much.
      Decided to shop Flea Bay for some used, but OK, mounts. Toro prices are . . . the usual Toro prices. Mine were shot and tossed in the bin. Easily installed, right?
      I thought in my ignorance that I could just remove a solid mount one at a time and pop-in the originals. Heck, the mount rubber has to be pressed in! Who knew? My old ones weren't like this at the restoration years ago.
      Delayed while I figured how to pull the engine on my own. I used to just throw it up on the bench but I've grown more cautious. No buds around in the AM for assistance. Tied some 10 gauge wire around a 2x3. Put one end on the table saw and lifting was easy. Still have to lift the weight but no bending and it was going on the floor. Dead lift at knee level. Pulled the 2x3 across the table to extend the engine to the side of the tractor and let her down slowly.
      Engine bay still pretty clean and the engine oil was due for its 1 hour drop after the rebuild anyway. Looked fine.
      How to get those mounts in? Tried a C clamp and a socket as a spacer - too clumsy. Greased them up nicely and got longer bolts - tightening them a bit at a time and nudging the mounts into the hole with a blunt object. Turned out not to be a bother!
      I've learned not to throw things away. It always seems that you need something the day after it's in the garbage truck. I still had the grounding lead and the large mount washers.
      The wife assisted in the re-installation. Kinda' freaked her out. Back in place, and I got to clean the lower engine area from that minor oil leak around the fuel pump. Attracted grass clippings like a magnet.
      A few bulb squeezes to start her up and, glorious! No more teeth chattering and I can take her up to 3600 if I like - sounds wonderful and she tore through the deep, deep crab grass. Don't discount those mounts. Sure, that off idle vibration is back and stronger than before. Nothing like a fresh bore for power. Something to spend time on tomorrow.
      Now, what to do with these?
    • Jeff-C175
