D_Mac
My Little Pony
squonk
1 hour ago, D_Mac said:
. Then I used it to cut the grass in the front yard. Did a really nice job..
Nobody started playing a Calliope whilst you were out there? :lol:
  • Haha 1
pfrederi
Someone hacked your belt guard.  That is why you are having gear grinding.  You could get a new belt guard form A to Z or elsewhere  In the interim you could fabricate some steel rod to make a support under the crank pulley.   Belt guard should look like this.  Yellow line approximates what you need.  Ignore my bent rods they were for the snowblower
  • Thanks 1
D_Mac
Ok so after work today I went out to the garage to address the grinding of the gears. I noticed the tab on the end of the belt guard was bent way back. I bent it up towards the pulley.  I also made a bracket to hold the belt closer to the engine pulley so it will balloon off of the transmission pulley. Sounded good on paper but it didn't seem to help. I'm wondering if the wrong size belt is on. Anyone know the proper length? Maybe I'm doing something wrong? I also drilled holes and put this seat on it. I planned on using this seat on the 875. Guess I still need to find another.
Handy Don
The tab should be clear of the belt when the clutch pedal is released. The tab should touch the belt when the clutch pedal is depressed and the belt gets a little slack. In other words, the tab should apply friction only when the pedal is depressed to stop the belt turning.
Belt is part # 1576 in my OM.  the internet parts guru shows that as widely available for under $10 as a 4LK 1/2 x 70in OC.
  • Thanks 1
D_Mac
Well I went to tractor supply and picked up a new belt for this little pony. Got home and installed it and it worked perfectly. No more gear grinding when putting it in gear. So I decided to mow the back yard with it.  Got halfway done and it just stopped. Ughhhh. Engine just quit. Pulled it a few times and nothing. Pushed it back in the garage. Look at it later.
D_Mac
Went out after dinner. One pull it started up again. <head scratch>. So I took the blower housing off. Cleaned out a small nest. I also ran the fuel line through it like it should be. I always said how easy it is to work on Wheel Horse tractors. Who ever designed these Lawn Rangers ??? Nothing is easy with these little horses.
Handy Don
I had mine running the other day (still a list of to-dos, but hey, grab some fun when you can)!
It has the dozer/snow plow and I was disappointed that there wasn't anything I could find that needed plowing around my house. Mentioned it to a friend and he invited me over later this week (with the LR) to level out a pile of gravel at his house--oughta be fun to see what this little guy can do. There will be pictures, of course.
  • Excellent 1
pfrederi
If you think Lawn Rangers are difficult to work  on do not ever buy a D series:P
D_Mac
Its just you have to remove the steering wheel and unbolt the hood to remove that. I had to take the seat and the rear fender off to remove the belt guard. No Tach-a-matic for the deck. Pain in the butt compared to other models.
Handy Don
The plow on/off is quite challenging, too, but remember none of the early 60's horses had the slick attachamatic!
D_Mac
Well went out again this morning gave it 2 pulls and it fired right up again. Don't know why it quit on me yesterday. I did notice seemed very hot when I was mowing. Maybe because of the muffler style ? Anyways I have a new battery for it. Might install it later today.
rjg854
how's the vent on the gas cap?
pfrederi
Muffler is not correct.  Should be a pepper pot type aimed out to the side.  That much heat trapped next to the carb may cause issue of gas boiling in the carb bowl.
You also are missing the piping and support bracket for the muffler.  Thinking motor may not be original...
Handy Don
Good spotting @pfrederi!
That style of muffler was often found on the HH60 engines of late 60's and early 70's and it is definitely trapping a lot of heat under the hood around the carb. I have an HH60 with that same muffler and am in the process of trying to get the bolts holding it unfrozen since I also have a gap in the gasket that seals the muffler to the manifold. I've been running mine with the hood off until I can get the muffler replaced with a proper one (or a stack?) vented out the side.
D_Mac
I will check the cap. As far as the engine being original I don't know. I do believe it is correct though. 6 hp Lauson Tecumseh ? Maybe I will look into changing the muffler.
pfrederi
Look on the air shroud Tecumseh stamped Model/Spec numbers into the metal.  Yours should be 75117E
Handy Don
It should also show H60 as the model.
D_Mac
squonk
Tecky Tecky Tecky! :) Make sure the kill wire isn't chafed somewhere. My 704 kept shutting off until I found the worn spot by the steering shaft. That had a Kohler so I new it wasn't the engine! :lol:
pfrederi
Correct spec number but also could be Cover was swapped on to a different engine.  Original engine was painted red all over.  End Plate on yours seems to be black with no red peaking through.  No big deal as it fits and works but you should re-plumb the muffler to avoid overheating the carb.
D_Mac
Better book an appointment with my exhaust guy. He hates tecumseh so I dont know if he will work on it. Last time he was over he put the whammy on my 500 Special Tecumseh engine.:ychain:
Handy Don
KA-CHING! Original spec H60 shroud on there (nod to @pfrederi)!
So a PO changed the muffler at some point--probably 'cause it rusted out or maybe the threaded pipe broke off. Not gonna make your "muffler guy" happy!
squonk
My sledge hammer is all polished up!
  • Thanks 1
  • Haha 1
  • Similar Content
    • HansPeter Ganz
      By HansPeter Ganz
      Lawn ranger, very complete, replacement engine from early 2000, with mower deck. Hasn't run in at least 10 years. Great parts unit for restoration, Hate to scrap.
    • CeeBee
      By CeeBee
      Good shape. Electric Start. Kept in a shed. Need the space now. Includes Manual. Pickup only.
    • jp_vikings
      By jp_vikings
      I have what I believe is a 1964 Lawn Ranger.
      I'm wondering how rare they are and wondering what it is worth in the original condition it is in now.
      May possibly restore it when I catch up on all my other projects.
      Thank you!
    • WHX??
      By WHX??
      Another interesting score here today. So I get a text from the nephew the other day about some horses for sale on FB. The ad was put up Monday the 3rd sometime in the evening. Mr. and Mr. Seller said the computer start smoking and phone was getting texts so fast it went dead. More on the Sellers and approaching a potential buy later.
      Seller and I  we really hit it off, more on that later too, so he threw in a nice little complete AND unmolested L167 AND a brand new square pan seat cover... . Will  fit in nice with my '67 line up & now don't feel so bad about missing the 702 labeled 701. (701 with a 702 belt guard).
      I gotta get crusin cause Dan is coming over to pick one up but here is  a few that I got. Missing a few things and POized for sure but both savable. Smokin deal.... 3 bills for the whole load!
    • D. McKinley
      By D. McKinley
      Hi I was wondering if all this grease needs to go, I am thinking you are supposed to just grease the spindle through the access hole.
