953 nut 69,161 #51 Posted August 31, 2021 10 hours ago, jtrosp1980 said: I have a 1970 raider 10 that my dad bought long before a was even thought of it has set for at least 10 years I have oil on the blade it ran when it went in his shed what would I want to start to look at. Please begin a new thread, your needs will get a lot more attention there. Just click on the link below and begin your own thread. https://www.wheelhorseforum.com/forum/3-wheel-horse-tractors/?do=add 2 Share this post Link to post Share on other sites
Pullstart 71,215 #52 Posted August 31, 2021 @Mike Van Eman, please forgive me for my ignorance on this thread! In the past year, I’ve been able to score an RS-83 for my wife, along with a Lever Steer for myself. The Lever Steer had a stuck exhaust valve as well. Because of your hood, it’s not so easy to remove the head. I popped the head off “Jackie” the Lever Steer and simply twisted the exhaust valve with a little WD-40 on the stem and it returned to it’s home in a jiffy. Best of luck getting that beautiful piece of history running! Those tires, they are awesome. The 3-12’s aren’t made any longer and I believe I’ve only seen one set of them in good shape, on @Shynon’s Senior. Here’s a few pics of ours and a lineup of a handful of ‘em in Portage, WI as well. 4 5 Share this post Link to post Share on other sites
jtrosp1980 89 #53 Posted October 26, 2021 Just wondering ideas on what for rear tires would be good for plowing snow and a garden on my raider 10 without making modifications I have a different set for mowing Share this post Link to post Share on other sites
rjg854 13,341 #54 Posted October 27, 2021 Put chains on a set of turfs for snow plowing. As for gardening someone else might have a good idea. Share this post Link to post Share on other sites
WHX?? 58,076 #55 Posted October 27, 2021 1 hour ago, jtrosp1980 said: Just wondering ideas on what for rear tires would be good for plowing snow and a garden on my raider 10 without making modifications I have a different set for mowing On 8/31/2021 at 7:11 AM, 953 nut said: Please begin a new thread, your needs will get a lot more attention there. Just click on the link below and begin your own thread. https://www.wheelhorseforum.com/forum/3-wheel-horse-tractors/?do=add As Richard said ... 2 Share this post Link to post Share on other sites
Mike Van Eman 73 #56 Posted December 2, 2021 Hi Everyone, Fortunately I have a few friends that are pretty knowledgeable with engine work and we were able to get it running! here is a link to see it: https://drive.google.com/file/d/16vVIIzYJ41QpxJplghn-frQd4Ot9RGCU/view?usp=sharing The exhaust valve was stuck open. Both valves also weren't seating properly. We've gotten that corrected but are still having trouble with the carb specifically the main jet adjustment needle and main nozzle. All the rebuild kits I've come across so far don't seem to contain this needle so if anyone has any sources on where to get one I'd appreciate it. The model is Zenith L48AD 11595. I see that there is a replacement model 12522 that runs $300-$400 and if consensus here is to go that route I'll do that if needed. Also looking for a Fairbanks Morse X1B7E faceplate. This one has a slight crack. The video has a makeshift starter but the tractor is starting on one rope pull as of tonight. And finally here is the Wisconsin serial # for those that are interested: Serial# 2443691 spec 102703 Model AEN Thanks again and take care, Mike 4 5 Share this post Link to post Share on other sites
AMC RULES 37,259 #57 Posted December 2, 2021 (edited) You'll have to give them a call, should be able to help with your needs. https://www.steinertractor.com/ Just type your needs into the search bar there at the top of the main page. https://antique-tractor-parts.steinertractor.com/search?w=zenith carburetor Edited December 2, 2021 by AMC RULES 3 Share this post Link to post Share on other sites
Gregor 4,848 #58 Posted December 2, 2021 The Carburetor Doctor Poke Here 2 Share this post Link to post Share on other sites
WHX?? 58,076 #59 Posted December 2, 2021 (edited) For the magneto Mike try giving this guy a jingle. http://www.rebuiltmags.com/ Edited December 2, 2021 by WHX?? 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #60 Posted December 3, 2021 Mike, I have 3 seniors and each one had carb issues. I have tried to clean with some luck but when you take apart make sure you take the Venturi out of the carb as there is a passage that does not get cleaned behind there. It just slides out but looks like part of the casting. Keep an eye on eBay for nos carbs as they will pop up every now and again. New carb always does the trick! All three of mine now idle down to about 300rpm and just pur. Glade to see you getting that old girl going!! 👍 5 Share this post Link to post Share on other sites
WHX?? 58,076 #61 Posted December 3, 2021 (edited) I don't know if you have this Mike but will post it here for you and others. ...a AEN manual. Lowell gave me a document, if I can find it, that will date the engine. Kev @Pullstart has it too I think. AEN_AENL_AENS_instr_parts.pdf A interesting piece of literature here. Wheel-Horse-Ride-Away-Sr-Brochure.pdf Edited December 3, 2021 by WHX?? 1 Share this post Link to post Share on other sites
Pullstart 71,215 #62 Posted December 3, 2021 Here is Lowell’s post on the date ciphering 1 Share this post Link to post Share on other sites
WHX?? 58,076 #63 Posted December 3, 2021 Thanks Hosen I just saved them now to where I can find them! Share this post Link to post Share on other sites
Pullstart 71,215 #64 Posted December 3, 2021 10 minutes ago, WHX?? said: Thanks Hosen I just saved them now to where I can find them! Until the next time you ask me… 1 Share this post Link to post Share on other sites
Gregor 4,848 #65 Posted December 3, 2021 20 minutes ago, WHX?? said: to where I can find them! I can usually find them if I remember I even have them. 1 Share this post Link to post Share on other sites
Mike Van Eman 73 #66 Posted December 3, 2021 Thanks for this! Share this post Link to post Share on other sites
WheelHorse_of_course 101 #67 Posted December 12, 2021 (edited) Nice dog you have. Pretty awesome tractor too. I am happy to hear you've made so much progress. This is going to be a fun ride for you (in multiple ways)! Edited December 12, 2021 by WheelHorse_of_course 2 1 Share this post Link to post Share on other sites
Mike Van Eman 73 #68 Posted December 15, 2021 Thank you on both! Share this post Link to post Share on other sites
Mike Van Eman 73 #69 Posted March 23, 2022 Here it is running. Smokes a bit while it's in gear. Thanks to everyone for your help. 6 2 Share this post Link to post Share on other sites
ebinmaine 80,651 #71 Posted March 23, 2022 11 minutes ago, Mike Van Eman said: Here it is running NIIIIICE 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #72 Posted March 23, 2022 39 minutes ago, Mike Van Eman said: running Only thing cooler than that would be if you mounted one of your modulated TC's on the hood! Share this post Link to post Share on other sites
Mike Van Eman 73 #73 Posted March 23, 2022 LOL That would be a sight 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #74 Posted March 24, 2022 Looks great! Smoke is probably the rings. Worth an engine rebuild as you should be able to still get nos piston for it 1 1 Share this post Link to post Share on other sites
Pullstart 71,215 #75 Posted March 24, 2022 Awesome work! We’ve had some smokers clean up after some run time and oil changes too. When I saw the first chicken walking in the back, I thought you were being blessed by a walking bald eagle! 2 Share this post Link to post Share on other sites
