westprw8@gmail.com 0 #1 Posted August 8, 2021 I put on all new parts relay pto switches new coil ingiation switch turn the key on blows the fuse is it the wire harness?? Looking for a new harness Share this post Link to post Share on other sites
Crazyredhorse 296 #2 Posted August 8, 2021 first thing I'd do is look up wiring diagram for your model check over wires see if somthing is hooked up wrong. Share this post Link to post Share on other sites
953 nut 69,551 #3 Posted August 8, 2021 7 hours ago, westprw8@gmail.com said: I put on all new parts relay pto switches new coil ingiation switch turn the key on blows the fuse is it the wire harness?? Looking for a new harness If a fuse blows something is grounded that shouldn't be. You need to provide a bit more information. What year and model is your ? Not all Wheel Horses are wired alike. What part number ignition switch did you use? Not all Wheel Horses use the same ignition switch. 2 Share this post Link to post Share on other sites
midpack 1,148 #5 Posted August 8, 2021 8 hours ago, westprw8@gmail.com said: turn the key on blows the fuse I had a machine doing that (bought it that way, knowingly), turned out the guy had put a new solenoid on it and didn't bother to tighten it to the machine! Fixed that and it's run fine ever since Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #6 Posted August 8, 2021 Share this post Link to post Share on other sites
westprw8@gmail.com 0 #7 Posted August 8, 2021 1994 wheel horse 314h I had it in shop. Last week he told me it is electric problem so iam looking for a new wire harness. I bought new ignition switch OEM on ebay part number 116338 this is what toro book call for Share this post Link to post Share on other sites
westprw8@gmail.com 0 #9 Posted August 8, 2021 4 hours ago, midpack said: I had a machine doing that (bought it that way, knowingly), turned out the guy had put a new solenoid on it and didn't bother to tighten it to the machine! Fixed that and it's run fine ever since I put new solenoid on it to all new parts Share this post Link to post Share on other sites
westprw8@gmail.com 0 #10 Posted August 8, 2021 Thanks everyone been talking to me.but iam looking for a complete wire harness now done all I can think of. Had in shop he told me in the electric trouble. But he was going to charge me 65.00 hour to trace it Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #11 Posted August 8, 2021 Does the fuse blow when you turn the key to the RUN position? or Does it blow when you turn the key to the START position? You can replace the fuse with a test light or voltmeter to test. This saves blowing fuses. Each test lead goes to the terminals the fuse occupied. When the test light is lit or a voltage reading appears the short is present. The object is to determine what circuit is causing the problem. The wiring is fairly simple on this model. Garry 3 Share this post Link to post Share on other sites
westprw8@gmail.com 0 #12 Posted August 8, 2021 11 minutes ago, gwest_ca said: Does the fuse blow when you turn the key to the RUN position? or Does it blow when you turn the key to the START position? You can replace the fuse with a test light or voltmeter to test. This saves blowing fuses. Each test lead goes to the terminals the fuse occupied. When the test light is lit or a voltage reading appears the short is present. The object is to determine what circuit is causing the problem. The wiring is fairly simple on this model. Garry It blow when I turn key to vfc run Share this post Link to post Share on other sites
Gregor 4,848 #13 Posted August 8, 2021 This pic is from the manual for the 1994 Wheel Horse 314-H The wiring harness is Ref. No. 5, Part # 79-3590. You may find one on ebay or somewhere, but who's to say it's any better than what you have. 1 Share this post Link to post Share on other sites
westprw8@gmail.com 0 #14 Posted August 8, 2021 Yes sir this is what my book shows to I seen some on ebay but they are used thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #15 Posted August 8, 2021 The only thing powered in the RUN position is the light circuit but that 15 amp fuse is not blowing so look at the wiring to the seat switch, the seat switch and to the seat switch relay. These wires are white. If you turn the key to RUN not sitting in the seat does it still blow the 25 amp fuse? Garry 1 Share this post Link to post Share on other sites
westprw8@gmail.com 0 #16 Posted August 8, 2021 Not sitting on seat still blows the 25 amp fuse the 15 amp is ok I have the seat switch bypass Share this post Link to post Share on other sites
westprw8@gmail.com 0 #17 Posted August 8, 2021 I put new coil two relay solenoid and pto switches new battery iam thinking short in fuse block?? Share this post Link to post Share on other sites
squonk 48,156 #18 Posted August 8, 2021 36 minutes ago, westprw8@gmail.com said: I put new coil two relay solenoid and pto switches new battery iam thinking short in fuse block?? Not likely. You need a short to GROUND to blow the fuse. Probably a wire chafed, Check the wires all the way to the seat switch where you have it bypassed. we had another member with the exact same scenario and he finally found the spot where the seat switch wire was rubbed through. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #19 Posted August 8, 2021 You can not bypass the seat switch on this model. If you do the engine will never run. For testing purposes just leave the wires off the seat switch. If that eliminates the short plug the wires back into the seat switch. Short has returned? Garry Share this post Link to post Share on other sites
953 nut 69,551 #20 Posted August 8, 2021 Do as Gary @gwest_ca suggested, use a 12 volt test light (best) or meter to replace the fuse for testing. Remove the fuse and connect the test light to the two fuse holder connections. Now when the short is present the test light will be bright and when you clear the short to ground the light will go off. At some point a wire is touching the chaises if the tractor or there is a component that has an internal ground. Take a look at the wiring diagram below, the seat switch and seat switch relay and the wires that go to them should be examined closely. Share this post Link to post Share on other sites
Gregor 4,848 #21 Posted August 9, 2021 You have no idea what is wrong with the wiring at this point. If it were me, I would disconnect the magneto wire from everything, before you inadvertently send 12 volts to the magneto coil. That could really ruin your day. Maybe it's not possible to do, but not know where the problem lies, I think anything might be possible. 1 Share this post Link to post Share on other sites
westprw8@gmail.com 0 #22 Posted August 9, 2021 I have thought of this I give it a try later today or vfc tomorrow thanks Share this post Link to post Share on other sites
peter lena 10,076 #23 Posted August 9, 2021 @squonk agree with squonk on the wiring check out , and wire fraying , another thing that I have done on my wiring , at replacement time , is to CORRECT THE ORIGINAL TIGHT FITTING LAYOUT , which more often that not insures shorting and failure areas. laying down wire in a CABLE WRAP , insures no chafing , changing the tight original set up , is very easy and it just makes sense , to eliminate a problem area ? why not correct a poorly laid out problem . every one I found on my horses , is gone and upgraded . just my own experience, pete Share this post Link to post Share on other sites
westprw8@gmail.com 0 #24 Posted August 9, 2021 Yes already been check had it in shop last week he told me that it is something in electric problem and he charge me 65.00 hour to find the problem thanks Share this post Link to post Share on other sites
