JoeM 10,317 #1 Posted August 3, 2021 Seen this guy's stuff on FB, interesting concept. 1 Share this post Link to post Share on other sites
ebinmaine 81,048 #2 Posted August 3, 2021 Is that the 4 standard carriage bolts holding the wheels together with a piece of PVC between? Share this post Link to post Share on other sites
Pullstart 71,482 #3 Posted August 3, 2021 1 hour ago, ebinmaine said: Is that the 4 standard carriage bolts holding the wheels together with a piece of PVC between? Possibly, that idea from what I recall originated with @SylvanLakeWH and “The WHRat WHrecker” around RedSquare. Still the only one I’ve seen personally and they work great! Those ones above, look like wheel blanks for the liters with simple tabs welded on. 1 Share this post Link to post Share on other sites
JoeM 10,317 #4 Posted August 3, 2021 2 hours ago, ebinmaine said: Is that the 4 standard carriage bolts holding the wheels together with a piece of PVC between? IDK it doesn't say but looks like metal. Touts them as custom made to order. 1 hour ago, pullstart said: looks like wheel blanks for the outers with simple tabs welded on For sure. I like how deep that side view, have to get a small kid to climb in there to start the lugs when wheels are assembled. 1 2 Share this post Link to post Share on other sites
ebinmaine 81,048 #5 Posted August 4, 2021 23 minutes ago, JoeM said: I like how deep that side view, have to get a small kid to climb in there to start the lugs when wheels are assembled Best I can do there is a BBT. No kid but pretty small. If'n I were to do this I'd bolt the wheels to the LUG BOLTS like any tractor should have then use the carriage bolts to attach the second wheel set. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,777 #6 Posted August 4, 2021 (edited) 2 hours ago, pullstart said: Possibly, that idea from what I recall originated with @SylvanLakeWH and “The WHRat WHrecker” around RedSquare. Still the only one I’ve seen personally and they work great! Those ones above, look like wheel blanks for the liters with simple tabs welded on. They do work great… easy too… cut 12” pvc pipe with a circular saw. Very solid. If I recall, The WHrat WHrecker’s are 2” wide… @pullstart has the rest of the 12” pvc pipe… I’m thinking business opportunity… can you say duality spacer kits? Edited August 4, 2021 by SylvanLakeWH 2 1 Share this post Link to post Share on other sites
ebinmaine 81,048 #7 Posted August 4, 2021 I've thought several times of doing a dually tractor but can't figure out how to justify it. Other than coolness factor of course. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,777 #8 Posted August 4, 2021 9 minutes ago, ebinmaine said: I've thought several times of doing a dually tractor but can't figure out how to justify it. Other than coolness factor of course. Perhaps Colossus would be even more colossal if it were a dually… 1 Share this post Link to post Share on other sites
Pullstart 71,482 #9 Posted August 4, 2021 1 hour ago, ebinmaine said: Other than coolness factor of course. What else do you need? 1 3 Share this post Link to post Share on other sites
ebinmaine 81,048 #10 Posted August 4, 2021 7 hours ago, SylvanLakeWH said: Perhaps Colossus would be even more colossal if it were a dually… I put serious thought into that and decided singles is the way to go because of financial reasons. Combining tires, wheels, and the dual adapter set, to add another set of skins would be $400 - $500. 1 Share this post Link to post Share on other sites
WHX?? 58,324 #11 Posted August 4, 2021 11 hours ago, ebinmaine said: Other than coolness factor of course. 10 hours ago, pullstart said: What else do you need? Truth be told about the only time they might be of use is working & using a ground engaging implement in a muddy garden. Maybe turfs & mowing on a slick slope??? No benefit other than the cool factor having them on the fronts but is is different just to say I did that. 5 3 1 Share this post Link to post Share on other sites
Zeek 2,310 #12 Posted August 4, 2021 Funny I just saw these adapters on fleabay yesterday. Kind of pricey and not my thing, but I guess it's a quick way to do it. 3 Share this post Link to post Share on other sites
WHX?? 58,324 #13 Posted August 4, 2021 Agreed Zeek have to be awful cool for 140 clams... If your a fabricator less than 20 to make them. Justice in case any one's interested T-MO offered this a while back . Dual Wheel Adapter.pdf 2 Share this post Link to post Share on other sites
JoeM 10,317 #14 Posted August 4, 2021 12 hours ago, ebinmaine said: can't figure out how to justify it Well if you have a flat the spare is already on? This guy is not taking any chances! Had this biker friend 40 years ago that drove one of those choppers. He wheeled up one day, dismounted the leaned backed bicycle sized seat, straightened his back out and said "man what you got to do to look cool!" Cool is always Cool! 5 Share this post Link to post Share on other sites
ebinmaine 81,048 #15 Posted August 4, 2021 37 minutes ago, JoeM said: This guy is not taking any chances! That right there is kind of like the ultimate in surface compaction reduction methods. 1 Share this post Link to post Share on other sites
Pullstart 71,482 #16 Posted August 4, 2021 41 minutes ago, ebinmaine said: That right there is kind of like the ultimate in surface compaction reduction methods. ‘Cept you gotta take the tires off to turn the thing! 2 Share this post Link to post Share on other sites
Handy Don 17,634 #17 Posted August 4, 2021 17 minutes ago, pullstart said: ‘Cept you gotta take the tires off to turn the thing! Where they use those, they plow west in the morning and then turn to plow east in the afternoon. Lotsa room! 1 1 Share this post Link to post Share on other sites
Crazyredhorse 296 #18 Posted August 7, 2021 I like the skinnier duel ags on there. but that j.d. just looks stupid wide. 1 Share this post Link to post Share on other sites
Pullstart 71,482 #19 Posted August 8, 2021 21 hours ago, Crazyredhorse said: I like the skinnier duel ags on there. but that j.d. just looks stupid wide. It looks like 24x12-12’s on that one. 23x8.50-12’s in duals seem just right to me Share this post Link to post Share on other sites
Snoopy11 5,731 #20 Posted August 18, 2021 What about dual for an L-157? I like the idea... Don Share this post Link to post Share on other sites
WHX?? 58,324 #21 Posted August 19, 2021 55 minutes ago, Snoopy11 said: What about dual for an L-157 Been done ...Lowell's boy on a show LR. 3 Share this post Link to post Share on other sites
RandyLittrell 3,946 #22 Posted August 20, 2021 On 8/3/2021 at 3:56 PM, ebinmaine said: Is that the 4 standard carriage bolts holding the wheels together with a piece of PVC between? That is how I do the duals on mine. I haven't had the duals on for awhile though. Randy 1 Share this post Link to post Share on other sites
ChubbyMinnow 34 #23 Posted August 22, 2021 On 8/18/2021 at 7:07 PM, WHX?? said: Been done ...Lowell's boy on a show LR. Details on how would be greatly appreciated. Share this post Link to post Share on other sites
WHX?? 58,324 #24 Posted August 22, 2021 Yer a newbie Chubby so gonna let ya slide once. Talk to Lowell @wheelhorseman at Pioneer Power..... might be a very small chance he be ther...... Big dude who picks his @$$ alot and has an old lady we just adore..... and his shop is what like 10 minutes from you? 1 Share this post Link to post Share on other sites
ChubbyMinnow 34 #25 Posted August 22, 2021 10 hours ago, WHX?? said: Yer a newbie Chubby so gonna let ya slide once. Talk to Lowell @wheelhorseman at Pioneer Power..... might be a very small chance he be ther...... Big dude who picks his @$$ alot and has an old lady we just adore..... and his shop is what like 10 minutes from you? 10-4. Man your kinda sending me on a wild goose chase. You will recognize me easily. I will be the one on the side chasing his tail cause you just about described every couple from my parts. 2 Share this post Link to post Share on other sites
