Jeff-C175 7,207 #26 Posted July 11, 2021 27 minutes ago, WheelHorse520H said: a concrete slab If you do go with a slab, make sure to use a heavy plastic liner UNDER the slab and bring the liner up the sides in order to prevent the concrete from wicking moisture from the ground. Share this post Link to post Share on other sites
WheelHorse520H 710 #27 Posted July 11, 2021 54 minutes ago, Jeff-C175 said: If you do go with a slab, make sure to use a heavy plastic liner UNDER the slab and bring the liner up the sides in order to prevent the concrete from wicking moisture from the ground. … Otherwise I will have the same problem I do now. Smart, thanks for the tip. Share this post Link to post Share on other sites
rmaynard 17,113 #28 Posted July 11, 2021 3 hours ago, WheelHorse520H said: Yes it is asphalt, but three of the four sides have doors although the dehumidifier is not a bad move after hearing what @rmaynard went through. I wired in a bathroom vent. It uses very little electricity. However, a dehumidifier is like a reverse air conditioner. It will eat you alive in electric bills. Share this post Link to post Share on other sites
WheelHorse520H 710 #29 Posted July 11, 2021 2 hours ago, rmaynard said: I wired in a bathroom vent. It uses very little electricity. However, a dehumidifier is like a reverse air conditioner. It will eat you alive in electric bills. That’s also true, I will see if I can find an energy efficient one but I will cross that bridge when I get to it. Share this post Link to post Share on other sites
