ebinmaine
New-to-me Horse (and other stuff) Hauler!!
ebinmaine
1 minute ago, CCW said:
@ebinmaine Impressive that you returned to it.  I would have been at the auto shop long ago.
I've wanted one of these Bull nose trucks for a looooonng time.
I've also wanted to build a particularly strong inline six 300 for a looooonng time.
It's been setting around unused collecting dust too long.
Time to ask others for help.
  • Like 4
SylvanLakeWH
So this is the thing that's been blocking access to Colossus???
:angry-tappingfoot:
Glad you finally figured it out... :handgestures-thumbupright:
:D
  • Haha 5
Sparky
Yep, let a pro handle the rear end and whatever else. Get it roadworthy and start enjoying it!
ebinmaine
I'd like to use that as an excuse but no.
They sit parallel to each other inside the barn.
:D
Exactly!
I dunno if it'll happen but I'd really like to see this truck pull a trailer to @JCM 's event in September.  If it has a bed by then I'll toss a tractor or two up there. Six in the trailer.
Sparky
And give the Honda Pilot a break. I know it tows that huge trailer and all but the truck would better suited
ebinmaine
Posted (edited)
Definitely agreed.
The Pilot is rated for 4500 total. We've had it right around that several times and it does very well.
The F250 on the other hand...
Depends on which towing chart you look at. Some factory charts indicate that truck can tow nearly 7,000 lbs.
If modified on the aftermarket by a professional builder they can easily pull a 12,000 lb trailer.
This particular truck has done just that with the previous owner.
Maybe I need a WAY bigger trailer 🤔
Edited by ebinmaine
  • Haha 1
CCW
And then a way bigger truck, and then a way bigger trailer.  Oh where does it end?
  • Haha 1
ebinmaine
Stopped to see the potential repair guy about my truck on the way home. ...
It went really well.
I need to get my truck ready to be towed down there Tuesday or Wednesday of next week so he can look at it late week....
Knock on wood. I hope this all works out.
I told him what I was up to, and he seemed like he was kind of already on the same page before I even defined anything.
Once we get the rear axle issue figured all out, he's going to give the rest of the truck a check over to see what kind of inspection issues and needed repairs we come up with.
Sparky
  Like beef up the drivers seat springs :teasing-neener:
:text-imsorry:
  • Haha 6
ebinmaine
:text-imsorry:
I got no argument with that
ebinmaine
All cleaned out.  Next step is to pull the whole thing backwards a few feet for better front half access and get the rollers out. Reinstall the air cleaner and try to start it.
  • Like 6
ebinmaine
Working on the pre repair shop to-do list this morning.
Bleach seat.
Seal up the roof lights so it can sit outside.
Put axles in pile.
Check that tote for other parts.
Check and count all bearings.
Re-read Redsquare thread to recall all axle information.
Install battery and hold down.
CHANGE ENGINE OIL.
Start:
  • Like 5
ebinmaine
Got some great scrubbing done on the doors, dash, roof and seat.
Didn't do the floor because I'll likely replace it.
  • Like 4
Handy Don
Some things here I haven’t seen in a while: openable vent, window crank, third pedal.
  • Excellent 2
  • Haha 3
  • Heart 1
ebinmaine
LOVE the old stuff.
I'll be adding to the "old look" too by deleting the plastic trim around the cab interior. I like the bare painted metal.
peter lena
@ebinmaine   nice pick up  on that , literally , opportunity  for a  creeping  lubrication soak down  ,  highest available  access point to any closed area , tailgate , doors  , cab to  body  areas , days out will show you tracking , what's.   effective , what needs improvement . inside  upper  tailgate  access , is a lubricant  line showing itself days out with  related film . like a lighter  oil first  , for tracking , then  open gear and cable spray  follow up . creeping on the  lighter oil . napa , macks , cable  oil is a good buy  . would personally  go over that paint  with  penetrant  / then mineral oil , will clean up to an always slick looking finish ,   get the wheel wells  first  , or  go to  home depot  parking  lot  for  rust reference  !  remember  ford frames , have punched in holes ?  they  hold onto moisture , insuring rot . try a  paint spot , related seaming , you just saved that area , good luck with it , oily pete
ebinmaine
You'll be happy to know this one will get treated right.
The whole frame and suspension was painted when the truck was reassembled back in the early 2000s.
It's been driven only about 3,000 to 3,500 miles since. Always stored under cover.
It will continue to have a permanent position in my barn.
The rear frame will be pressure washed and a few small areas wire brushed and repainted.
I'm probably replacing one crossmember because the support brackets for it are a touch thin.
There will be no Ford bed. I'm building a flat bed for it. 7 foot wide most likely. Length not sure yet.
c-series don
If you’re going for the original look and are staying with the steel wheels, I have period correct hub caps for your truck that came off my F-350 SRW they are basically like new.
  • Excellent 2
ebinmaine
I sure am Don.
I'd be very interested.
ebinmaine
Here's another.
The PO converted to a Manual Choke.
SylvanLakeWH
Wait... no blue tooth??!!??!!
:scared-eek:
  • Haha 2
Handy Don
I’ve never owned a manual choke road vehicle, though I’ve had ones with the vent, clutch, and crank windows!
Our family’s '63 three-on-the-tree International Travelall, on which I learned to drive and took the test, had one.
ebinmaine
:scared-eek:
Blue paint. That count?
ebinmaine
Bleach seat.
Put axles in pile.
CHANGE ENGINE OIL.
All of the above is done except installing the battery.
We syphoned out as much of the 5+ year old gas as we could. Got about 6 or 7 gallons.
Also need to add brake fluid.
ebinmaine
Topped of the brake fluid and added about 4 gallons of non ethanol fuel.
Attempted to start but the starter solenoid is corroded.
I removed the wires and removed the solenoid from the inner fender. Tomorrow I'll finish wire brushing the wires and terminals to see if I can get a better connection.
