ebinmaine 81,278 #76 Posted May 16 1 minute ago, CCW said: @ebinmaine Impressive that you returned to it. I would have been at the auto shop long ago. I've wanted one of these Bull nose trucks for a looooonng time. I've also wanted to build a particularly strong inline six 300 for a looooonng time. It's been setting around unused collecting dust too long. Time to ask others for help. 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #77 Posted May 16 So this is the thing that's been blocking access to Colossus??? Glad you finally figured it out... 1 5 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #78 Posted May 16 Yep, let a pro handle the rear end and whatever else. Get it roadworthy and start enjoying it! 2 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #79 Posted May 16 1 hour ago, SylvanLakeWH said: blocking access to Colossus??? I'd like to use that as an excuse but no. They sit parallel to each other inside the barn. 57 minutes ago, Sparky said: Yep, let a pro handle the rear end and whatever else. Get it roadworthy and start enjoying it! Exactly! I dunno if it'll happen but I'd really like to see this truck pull a trailer to @JCM 's event in September. If it has a bed by then I'll toss a tractor or two up there. Six in the trailer. 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #80 Posted May 16 And give the Honda Pilot a break. I know it tows that huge trailer and all but the truck would better suited 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #81 Posted May 16 (edited) On 5/16/2026 at 2:40 PM, Sparky said: And give the Honda Pilot a break. I know it tows that huge trailer and all but the truck would better suited Definitely agreed. The Pilot is rated for 4500 total. We've had it right around that several times and it does very well. The F250 on the other hand... Depends on which towing chart you look at. Some factory charts indicate that truck can tow nearly 7,000 lbs. If modified on the aftermarket by a professional builder they can easily pull a 12,000 lb trailer. This particular truck has done just that with the previous owner. Maybe I need a WAY bigger trailer 🤔 Edited May 22 by ebinmaine 1 1 Share this post Link to post Share on other sites
CCW 1,522 #82 Posted May 16 14 minutes ago, ebinmaine said: Maybe I need a WAY bigger trailer 🤔 And then a way bigger truck, and then a way bigger trailer. Oh where does it end? 1 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #83 Posted May 18 Stopped to see the potential repair guy about my truck on the way home. ... It went really well. I need to get my truck ready to be towed down there Tuesday or Wednesday of next week so he can look at it late week.... Knock on wood. I hope this all works out. I told him what I was up to, and he seemed like he was kind of already on the same page before I even defined anything. Once we get the rear axle issue figured all out, he's going to give the rest of the truck a check over to see what kind of inspection issues and needed repairs we come up with. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #84 Posted May 18 18 minutes ago, ebinmaine said: Once we get the rear axle issue figured all out, he's going to give the rest of the truck a check over to see what kind of inspection issues and needed repairs we come up with. Like beef up the drivers seat springs 1 6 Share this post Link to post Share on other sites
ebinmaine 81,278 #85 Posted May 18 13 minutes ago, Sparky said: Like beef up the drivers seat springs I got no argument with that 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #86 Posted May 18 All cleaned out. Next step is to pull the whole thing backwards a few feet for better front half access and get the rollers out. Reinstall the air cleaner and try to start it. 6 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #87 Posted May 22 Working on the pre repair shop to-do list this morning. Bleach seat. Seal up the roof lights so it can sit outside. Put axles in pile. Check that tote for other parts. Check and count all bearings. Re-read Redsquare thread to recall all axle information. Install battery and hold down. CHANGE ENGINE OIL. Start: 5 Share this post Link to post Share on other sites
ebinmaine 81,278 #88 Posted May 22 Got some great scrubbing done on the doors, dash, roof and seat. Didn't do the floor because I'll likely replace it. 4 1 Share this post Link to post Share on other sites
Handy Don 17,735 #89 Posted May 22 Some things here I haven’t seen in a while: openable vent, window crank, third pedal. 2 3 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #90 Posted May 22 LOVE the old stuff. I'll be adding to the "old look" too by deleting the plastic trim around the cab interior. I like the bare painted metal. Share this post Link to post Share on other sites
peter lena 10,125 #91 Posted May 22 @ebinmaine nice pick up on that , literally , opportunity for a creeping lubrication soak down , highest available access point to any closed area , tailgate , doors , cab to body areas , days out will show you tracking , what's. effective , what needs improvement . inside upper tailgate access , is a lubricant line showing itself days out with related film . like a lighter oil first , for tracking , then open gear and cable spray follow up . creeping on the lighter oil . napa , macks , cable oil is a good buy . would personally go over that paint with penetrant / then mineral oil , will clean up to an always slick looking finish , get the wheel wells first , or go to home depot parking lot for rust reference ! remember ford frames , have punched in holes ? they hold onto moisture , insuring rot . try a paint spot , related seaming , you just saved that area , good luck with it , oily pete 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #92 Posted May 23 17 hours ago, peter lena said: good luck with it , oily pete You'll be happy to know this one will get treated right. The whole frame and suspension was painted when the truck was reassembled back in the early 2000s. It's been driven only about 3,000 to 3,500 miles since. Always stored under cover. It will continue to have a permanent position in my barn. The rear frame will be pressure washed and a few small areas wire brushed and repainted. I'm probably replacing one crossmember because the support brackets for it are a touch thin. There will be no Ford bed. I'm building a flat bed for it. 7 foot wide most likely. Length not sure yet. 3 Share this post Link to post Share on other sites
c-series don 12,751 #93 Posted May 23 If you’re going for the original look and are staying with the steel wheels, I have period correct hub caps for your truck that came off my F-350 SRW they are basically like new. 4 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #94 Posted May 23 8 hours ago, c-series don said: If you’re going for the original look and are staying with the steel wheels, I sure am Don. 8 hours ago, c-series don said: I have period correct hub caps for your truck that came off my F-350 SRW they are basically like new. I'd be very interested. 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #95 Posted May 25 On 5/22/2026 at 11:08 AM, Handy Don said: Some things here I haven’t seen in a while: openable vent, window crank, third pedal. Here's another. The PO converted to a Manual Choke. 3 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #96 Posted May 25 Wait... no blue tooth??!!??!! 1 2 Share this post Link to post Share on other sites
Handy Don 17,735 #97 Posted May 25 18 minutes ago, ebinmaine said: The PO converted to a Manual Choke. I’ve never owned a manual choke road vehicle, though I’ve had ones with the vent, clutch, and crank windows! Our family’s '63 three-on-the-tree International Travelall, on which I learned to drive and took the test, had one. 3 Share this post Link to post Share on other sites
ebinmaine 81,278 #98 Posted May 25 3 hours ago, SylvanLakeWH said: Wait... no blue tooth??!!??!! Blue paint. That count? 1 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #99 Posted May 25 On 5/22/2026 at 8:43 AM, ebinmaine said: Working on the pre repair shop to-do list this morning. Bleach seat. Seal up the roof lights so it can sit outside. Put axles in pile. Check that tote for other parts. Check and count all bearings. Re-read Redsquare thread to recall all axle information. Install battery and hold down. CHANGE ENGINE OIL. All of the above is done except installing the battery. We syphoned out as much of the 5+ year old gas as we could. Got about 6 or 7 gallons. Also need to add brake fluid. 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #100 Posted May 25 Topped of the brake fluid and added about 4 gallons of non ethanol fuel. Attempted to start but the starter solenoid is corroded. I removed the wires and removed the solenoid from the inner fender. Tomorrow I'll finish wire brushing the wires and terminals to see if I can get a better connection. 1 Share this post Link to post Share on other sites
