WheelhorseBob 1,550 #51 Posted August 22, 2021 On closer inspection the rims look to have been previously mounted, oh well me thinks they would look great white 🦈 1 Share this post Link to post Share on other sites
Thor27 835 #52 Posted August 22, 2021 Really enjoying your build. Great looking tractor. 3 Share this post Link to post Share on other sites
ebinmaine 73,168 #53 Posted August 22, 2021 22 hours ago, WheelhorseBob said: great white 🦈 I see what ya did there. We talking white white or a little off white? 1 Share this post Link to post Share on other sites
Pullstart 67,146 #54 Posted August 23, 2021 This’s gonna be a sweet C-something! Great work! 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #55 Posted August 24, 2021 Got the shaker plate all cleaned up today. I was ready to buy some new rubber mounts but they are in great shape! 4 Share this post Link to post Share on other sites
Pullstart 67,146 #56 Posted August 24, 2021 If those rubber mounts ever wear out, most people go to solid mounts. There’s a guy who spins aluminum ones, or you could make your own. 1 Share this post Link to post Share on other sites
oldredrider 2,553 #57 Posted August 24, 2021 (edited) @pullstart Any leads on "that guy"? Edited August 24, 2021 by oldredrider 1 Share this post Link to post Share on other sites
squonk 43,994 #58 Posted August 24, 2021 49 minutes ago, oldredrider said: @pullstart Any leads on "that guy"? https://www.zkbrmachine.com/ 1 Share this post Link to post Share on other sites
oldredrider 2,553 #59 Posted August 24, 2021 Thank you! 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #60 Posted August 28, 2021 Hi guys, l’m contemplating my front tire situation. I have these tri-ribs I could use or the other ribbed tires I jus mounted on stock rims. I also changed my mind on the rears and they will be wide AGs on 520 rims. I’m saving the narrow AG’s for a dual rear set up. So narrow tri’s or wide ribs? Btw if I go with the narrow tri’s I would also probably stay with silver rims. Skinny tri’s with fatty AG’s would have some serious cool factor..... 2 Share this post Link to post Share on other sites
Bill D 2,293 #61 Posted August 28, 2021 I like the wide front tires. I would also recommend swapping out that steering wheel for a 15 inch wheel from a 417-8. It makes a big difference in how the tractor steers. 3 Share this post Link to post Share on other sites
c-series don 10,201 #62 Posted August 29, 2021 @WheelhorseBob@Bill D Yup what Bill said ! 1 Share this post Link to post Share on other sites
ebinmaine 73,168 #63 Posted August 29, 2021 23 hours ago, WheelhorseBob said: Skinny tri’s with fatty AG’s would have some serious cool factor I do agree with that... But for the sake of practicality the wide tires would be more beneficial on soft/wet/smooshy ground. I'll third the vote of the last 2 gents. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #64 Posted September 18, 2021 Ok so the worst thing about restoration of a tractor has to be painting rims! Been a bit but made a little progress tonight. Sneak peak at the new skins! 4 2 Share this post Link to post Share on other sites
ebinmaine 73,168 #65 Posted September 18, 2021 9 hours ago, WheelhorseBob said: Ok so the worst thing about restoration of a tractor has to be painting rims! Hard to argue that for sure. If I had a cost effective blast/powder coating place around that would be a consideration. Those rims look excellent! 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #66 Posted September 19, 2021 (edited) Decided to touch up the nicks I put in my front wheels when mounting the tires my twist on playing cards. Works great 👍 Edited September 19, 2021 by WheelhorseBob 3 Share this post Link to post Share on other sites
ebinmaine 73,168 #67 Posted September 19, 2021 1 hour ago, WheelhorseBob said: my twist on playing cards. Works great Yeah but the owner of those cards is gonna be a little irritated.... Seriously though... That's a great trick. Seen it here on this site a time or two in the past. My local Paint Department has used it with great success. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #68 Posted September 21, 2021 More progress today. Need to finish this soon, hunting season is around the corner! Engine mounted and new Carlisle AG’s. 2 5 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #69 Posted September 21, 2021 (edited) Even got engine tins painted. Edited September 21, 2021 by WheelhorseBob 4 Share this post Link to post Share on other sites
ebinmaine 73,168 #70 Posted September 22, 2021 Looookin puuuuuurtyy 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #71 Posted September 23, 2021 The air cleaner cover on my 16hp was badly damaged. The area around the mounting hole was broken out. The hole was 5/8” diameter. Welded a 1/8 “ thick plug and then a fender washer. Should be plenty strong now. Is this a common problem with the larger 16hp filter covers? 2 Share this post Link to post Share on other sites
Lee1977 7,237 #72 Posted September 23, 2021 On 8/21/2021 at 8:58 PM, WheelhorseBob said: NOS.....found me a NOS C-series hood and a set of NOS 520 rear rims amongst other things. Sorry Black hood guys it ain’t looking good from your perspective... The top piece of the hood stand was different on the 78 and 79 models with the old C-series hoods. 1 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #73 Posted September 23, 2021 1 hour ago, Lee1977 said: The top piece of the hood stand was different on the 78 and 79 models with the old C-series hoods. Yes but I believe the hoods are the same. Damn you scared me. I paid good money for that hood! Went out and measured and I seems the same as my 161 Automatic hood. Just need to find a hood ornament from an earlier model! 2 Share this post Link to post Share on other sites
ebinmaine 73,168 #74 Posted September 24, 2021 22 minutes ago, WheelhorseBob said: ornament Somewhere around 64 or 65 up to 75 they had the ornaments. You can also have one printed. 1 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #75 Posted September 24, 2021 Did I mention I love adding the new decals!! Question where does the 15 AMP alternator decal go? Can’t find it on my original K301. 2 Share this post Link to post Share on other sites
