42 inch rear discharge belt sizes?
By
Ifixoldjunk, in Implements and Attachments
Similar Content
By GeoC-120
The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale. Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
42” snow/dozer blade (Model 86-42bc010), with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
Please PM to contact
HH120_running.mp4
By rustyedge1
The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
Thank in advance.
By morePEdal
*16 HP Onan Engine, 665.4 Hours
*8 Speed Transmission
*48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
*Nice 42” Mowing Deck, no rot or welds, smooth spindles
*OEM Wheel Weights, 50 lbs. Each
*Chains
*Valves adjusted this summer, runs great!
*Good battery
*Tires All Hold Air
*LED lights all the way around
*Manuals included
Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
Cash Only!
*WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
*COMING SOON: Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
By Gettysburg Axel
In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
By cJ_3D
Hello helpful Wheel Horse enthusiasts!
Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
So referencing this image here from the service manual for the mower deck (37"):
What exactly am I doing with this adjustment knob and how does it fit into this piece?
Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
Much obliged for the help!
CJ
