Ifixoldjunk
42 inch rear discharge belt sizes?
Ifixoldjunk
I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
gwest_ca
Click on the picture in the link. The belts are listed on the page that comes up.
Ifixoldjunk
Thanks man✌️
Porkskin
Dropped by to throw out a question around my 1986 x310-A with a 42" deck. Blew the belt on the deck today so this info was very helpful in getting me on a path to correctly ID the deck, and so now I also know what belt I need. Meanwhile, is it me or is this rig incredibly loud with the blades spinning? I put my ballistic ears on and even those could be a little stronger in the sound blockage department.
Ifixoldjunk
Yeah I thought mine was loud too. As long as nothings rubbing or grinding I think it’s fine.
Handy Don
I ALWAYS wear my 30db "ears" before I even start a motor (mowers, chipper, chain saw, pressure washer, trimmer, blower, generator, etc.). Makes them all sound fine to me. :D
Porkskin
Don's got the right idea! Heck I even wear mine so I don't have to hear kids squeal. So, I'm wrestling with the deck belt right now. This was after discovering both spindle pulleys completely scaled. Meaning, thick corrosion inside the "V". I chipped all that away good enough for now. We'll see if pulleys running a belt that are smoother will make a difference. Otherwise I hope to get 2 pulleys and an idler in here sometime soon. In fact, I'll plan on refurbing the whole deck based on lots of great ideas you guys have in the forum.
tom2p
if the mower deck noise is excessive - this could be the result of a loose idler ... too much movement of the idler ... too loose ... nylon bushings / washers and /or the idler bar could be excessively worn ... spring lost tension (?)
one telltale sign - noise increase as idler moves back and forth when deck / blades are engaged
corroded pulleys (inside portion that contacts the belt) can destroy a belt - sometimes in as little as a few hours ...  (just something to consider)
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
