Jeff-C175 7,211 #1 Posted May 4, 2021 Anybody here ever try these? https://www.amazon.com/gp/product/B01MQX8QJY?ref=em_1p_11_ti&ref_=pe_27542510_581313550 Share this post Link to post Share on other sites
pfrederi 21,095 #2 Posted May 4, 2021 They used to sell this stuff or something like it on TV one of those infomercial the voice over was a woman with a very very seductive voice....I bought some at a military vehicle show years ages ago tried it once didn't work and it is still around here some where Share this post Link to post Share on other sites
Jeff-C175 7,211 #3 Posted May 4, 2021 59 minutes ago, pfrederi said: on TV I think I saw "As Seen on TV" somewhere in that page on Amazon, yes, you are correct. I didn't think they would really work. Share this post Link to post Share on other sites
pacer 3,180 #4 Posted May 4, 2021 I saw that one or a similar and immediately questioned it, so I went on a search for reviews and ..... well, lets just say that they got some pretty scathing reviews. 1 Share this post Link to post Share on other sites
8ntruck 9,244 #5 Posted May 4, 2021 (edited) I've seen them for sale in the commercial building during the State Fair. They are talked up as the solution for everything. Seems too good to be true. Have not tried them. Edited May 4, 2021 by 8ntruck 1 Share this post Link to post Share on other sites
WHX?? 57,884 #6 Posted May 4, 2021 I use these, they are flux cored and work slicker than cat cr@p on linoleum .... 3 Share this post Link to post Share on other sites
ebinmaine 80,455 #7 Posted May 5, 2021 @WHX24 That's pretty slick..... 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #8 Posted May 5, 2021 1 hour ago, WHX24 said: these Work like a brazing rod? Share this post Link to post Share on other sites
WHX?? 57,884 #9 Posted May 5, 2021 (edited) Yep... needs very low heat and very easy to use. We use them for patching AL coils that like Skunky @squonk ran a screw into. I used them to patch/fill in holes in a AL 701 tank wher the PO had a throttle mounted. Is a bit of technique to using them so practice a bit of scrap is advised. Edited May 5, 2021 by WHX24 speeling 2 Share this post Link to post Share on other sites
squonk 47,986 #10 Posted May 5, 2021 5 minutes ago, WHX24 said: Yep... needs very low heat and very easy to use. We use them for patching AL coils that like Skunky @squonk ran a screw into. Dab of silicone on the point of the screw before installing.A real time saver! I sealed a rad on an International Bus with Freshen Up Gum! 2 Share this post Link to post Share on other sites
WHX?? 57,884 #11 Posted May 5, 2021 Yah well we all know you wiped yer rear with a cactus too Squonky...... 2 Share this post Link to post Share on other sites
squonk 47,986 #12 Posted May 5, 2021 Pine cone. Get the story straight! 1 2 Share this post Link to post Share on other sites
squonk 47,986 #13 Posted May 5, 2021 Gum story is true. Filled the rad with water and Genny Creme-Ale from the band cooler plus a little water from the ditch. 2 Share this post Link to post Share on other sites
