Achto 29,341 #51 Posted April 14, 2021 14 minutes ago, WHX24 said: Dan thinks the front rims should be mounted with the valve stem to the inside which makes sense for stem protection and wheel weights. If that's true all my early sixties tractor are on backwards. Issue with running them to the inside the rim gets pretty close to the spindle arm. .... some pics as I was playing... anyone know which is correct? I did a lil research & now believe that on early front rims did have the valve stem to the outside. I also came to the conclusion that these rims can not be used without an inner tube. If you look at the weld that holds the 2 halves of the rim together it does not go all the way around. 2 Share this post Link to post Share on other sites
squonk 43,628 #52 Posted April 14, 2021 3 hours ago, WHX24 said: I'm liken those rears Dan I had an eyeball on them for the flame but the X 4 was a killer! Guess I just gotta run those old Pullstart hand me downs on my 701...that's alright my herd is ag heavy anyway! So anyway here's the ? gents... Dan thinks the front rims should be mounted with the valve stem to the inside which makes sense for stem protection and wheel weights. If that's true all my early sixties tractor are on backwards. Issue with running them to the inside the rim gets pretty close to the spindle arm. .... some pics as I was playing... anyone know which is correct? Jim, these are the rims my 701 had. Stem on the inside 3 1 Share this post Link to post Share on other sites
Achto 29,341 #53 Posted April 14, 2021 Thanks @squonk !! Plot Thickens I guess I'll try them both ways & see which way they track better with the rear tires. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #54 Posted April 14, 2021 @Achto& the clown in where what ever state and of course @squonk I have my Dad's 72 Commando 800 , the valve stems on all 4 rims are on the outside. I don't know if he reversed the rims or not , but he made wheel weights for the rear that had a notch for the valve stems. Having the stems on the outside of the rim makes it easier to check the pressure and fill with air as needed. 2 1 Share this post Link to post Share on other sites
WHX?? 51,623 #55 Posted April 15, 2021 (edited) 7 hours ago, Achto said: weld that holds the 2 halves of the rim together it does not go all the way around That I did not know I used tubes anyway cause they were on the shelf and the stem holes are too rusted for stems to seat. Did I give you a few of those stem hole bushings Dan?? If not Iet me know I got a butt load. needed some for these rims. I was also just guessing they were tubed from South Bend because of the penchant to load tires of the Burbs and RJs??? 4 hours ago, squonk said: Jim, these are the rims my 701 had. Stem on the inside Yah but is this correct Mike? Lets ask @Lane Ranger To my knowledge Waldo '62 was the last year they used rims with the different sized hub spacers and went to shorter spindles. then all stems were to the inside...front and rear. Perhaps another historian can confirm this? Edited April 15, 2021 by WHX24 3 Share this post Link to post Share on other sites
rjg854 12,120 #56 Posted April 15, 2021 front wheel weights don't have a spot for the valve stem cast into them. So obviously the valve stem has to be on the inside of the rim. Or you'd have to take the weight off when you wanted to check air pressure. 1 1 Share this post Link to post Share on other sites
Achto 29,341 #57 Posted April 15, 2021 11 hours ago, WHX24 said: Did I give you a few of those stem hole bushings Dan?? I thought that you gave me some. Couldn't find 'em when I put the front tires on of course. 1 Share this post Link to post Share on other sites
WHX?? 51,623 #58 Posted April 15, 2021 For what it's worth a snip of the IPL showing the stem to the inside? 2 Share this post Link to post Share on other sites
WHX?? 51,623 #59 Posted April 15, 2021 3 hours ago, rjg854 said: take the weight off when you wanted to check air pressure. Or to grease the bearings... 2 Share this post Link to post Share on other sites
stevasaurus 23,272 #60 Posted April 15, 2021 They all came from the factory with the valves on the inside...reasoning being...to protect the valve stem from bushes, trees, fences, lawn flamingos, swimming pools etc. In other words, out of harm's way. If you don't have those issues, it is easy to swap the rims to put the valve to the outside and make it easier to check and air tires. It is that simple gents, and that easy if you have bad knees. 7 1 Share this post Link to post Share on other sites
WHX?? 51,623 #61 Posted April 15, 2021 (edited) Agreed Dino.... since this is just a show cruzer they stay to the outside & anybody points out it's wrong it's...... Same for the mismatched rims. Edited April 15, 2021 by WHX24 1 3 Share this post Link to post Share on other sites
stevasaurus 23,272 #62 Posted April 15, 2021 If you are young, inside...if you are not so young, outside. Just have your ag's pointed in the right direction. 1 4 1 Share this post Link to post Share on other sites
Lane Ranger 11,379 #63 Posted April 16, 2021 Mine are on the outside but I never claimed to be much of an original purist! Not sure wheels are original . This horse was traded back forth four times with two Wheel Horse owners before I rescued it from them! 3 1 1 Share this post Link to post Share on other sites
WHX?? 51,623 #64 Posted April 16, 2021 10 hours ago, Lane Ranger said: I never claimed to be much of an original purist! Me neither Lane as the MN boys ain't got me completely brainwashed.... yet! ' Specially when it comes to making improvements over factory like that hood hinge on yours. Sides when they get dirty running around at a muddy tractor show or worked in the garden... The way to tell if they are original or near original is look at the edge of the rim. It will have a pronounced curve to the inside. Looks like Dan's are and in my pic you can see left side is, passenger side no. Looks like Mikes are too. A painters pain to get paint under that curve without the runs. 2 1 Share this post Link to post Share on other sites
squonk 43,628 #65 Posted April 16, 2021 8 minutes ago, WHX24 said: A painters pain to get paint under that curve without the runs. Eat a balanced diet and paint away! (Sorry but I had the hit that softball out of the park! ) 3 Share this post Link to post Share on other sites
Achto 29,341 #66 Posted April 16, 2021 No work today so it's go time for assembly. I'll post more pic's of my progress at the end of the day. 6 2 Share this post Link to post Share on other sites
WHX?? 51,623 #67 Posted April 16, 2021 (edited) 13 minutes ago, Achto said: No work today !?!?!??!?!?!? whats up with that!?!?!?!? 13 minutes ago, Achto said: time for assembly. This always the part I like if one has all his hardware. No greasy parts to clean or repair .. seems to go fast and progress is seen right away. Hey wait a minute that floor looks way too clean ...you is at pumpkin farmers ain't ya! Edited April 16, 2021 by WHX24 1 1 1 Share this post Link to post Share on other sites
Achto 29,341 #68 Posted April 16, 2021 Yep, most of my stuff is at Pumpkin Farmers from helping him with his basket Case. Might as well assemble it there. 1 1 Share this post Link to post Share on other sites
WHX?? 51,623 #69 Posted April 16, 2021 2 minutes ago, Achto said: basket Case. 1 Share this post Link to post Share on other sites
squonk 43,628 #70 Posted April 16, 2021 25 minutes ago, Achto said: No work today so it's go time for assembly. I'll post more pic's of my progress at the end of the day. NICE TRACTOR!!! 2 1 Share this post Link to post Share on other sites
stevasaurus 23,272 #71 Posted April 16, 2021 It was a nice tractor, until I had to look at it twice. 4 Share this post Link to post Share on other sites
WHX?? 51,623 #72 Posted April 16, 2021 Hey while your there Dan see if that motor I gave him has the dipstick tube Skunk is lookin for and if he used it? 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,206 #73 Posted April 16, 2021 1 hour ago, WHX24 said: Skunk Share this post Link to post Share on other sites
Achto 29,341 #74 Posted April 16, 2021 (edited) A progress report as promised. Had a fairly successful day and only had to make one trip to the hardware store. Even though they didn't leak before, I changed all of the shaft seals on the transmission. As long as all the pulleys & hubs were off I figured it a good idea. This is where I stopped for the day. I'll share my progress again after tomorrows adventures. Edited April 16, 2021 by Achto 1 6 1 2 Share this post Link to post Share on other sites
Achto 29,341 #75 Posted April 16, 2021 6 hours ago, WHX24 said: Hey while your there Dan see if that motor I gave him has the dipstick tube Skunk is lookin for and if he used it? I'll check tomorrow Jim. 1 Share this post Link to post Share on other sites
