Oldskool 6,663 #1 Posted February 17, 2021 I just started gather parts to build "Something from nothing" I have no idea what I'm going to build. Still gather parts buts here is the start. Wheel Horse 8 speed Pair of 12x7-1/2ish wheels Gravely wheels and hubs. Hubs where tapered now have been drilled to 1in. bore. 3 5 Share this post Link to post Share on other sites
ebinmaine 73,088 #2 Posted February 17, 2021 All right already this could get good.... 2 1 Share this post Link to post Share on other sites
Oldskool 6,663 #3 Posted February 17, 2021 The transmission is coming apart to get freshened up because I'm not getting 3rd n 4th gear. @ebinmaine I said I wouldnt use a 3 jaw puller to get the hubs off BUT........I did... 4 1 1 Share this post Link to post Share on other sites
ebinmaine 73,088 #4 Posted February 17, 2021 56 minutes ago, Oldskool said: The transmission is coming apart to get freshened up because I'm not getting 3rd n 4th gear. @ebinmaine I said I wouldnt use a 3 jaw puller to get the hubs off BUT........I did... Heat the lava right to it and you'll do fine. That's a very similar setup to what I do. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #5 Posted February 17, 2021 14 minutes ago, ebinmaine said: Heat the lava right to it and you'll do fine. That's a very similar setup to what I do. They are both off and in 1 piece. 3 2 Share this post Link to post Share on other sites
Pullstart 67,131 #6 Posted February 17, 2021 What’s next? What do you have for a frame? Engine choice? Where does the nitrous bottle sit? Will this require a cage or harness? 4 Share this post Link to post Share on other sites
SylvanLakeWH 28,690 #7 Posted February 17, 2021 Where are the screws? 4 Share this post Link to post Share on other sites
Oldskool 6,663 #8 Posted February 17, 2021 8 minutes ago, pullstart said: What’s next? What do you have for a frame? Engine choice? Where does the nitrous bottle sit? Will this require a cage or harness? I dont have a frame. Engine choice, I knew a guy that had a 4cyl inline Kohler but he decided to keep it. I knew where there was a little diesel but it sold. Then I was thinking twin engine. Soooooo I'm not sure yet. Nitrous bottle, maybe lol Cage or harness probably not. 2 Share this post Link to post Share on other sites
Oldskool 6,663 #9 Posted February 17, 2021 3 minutes ago, SylvanLakeWH said: Where are the screws? In a couple days I will be out for another test run. 3 Share this post Link to post Share on other sites
ebinmaine 73,088 #10 Posted February 17, 2021 13 minutes ago, SylvanLakeWH said: Where are the screws? You got you a screw loose. 3 Share this post Link to post Share on other sites
Tractorhead 9,212 #11 Posted February 17, 2021 24 minutes ago, ebinmaine said: You got you a screw loose. Ddidn‘t we all seat in the same box with the loosen Screws ? 😇 1 3 Share this post Link to post Share on other sites
Tractorhead 9,212 #12 Posted February 17, 2021 Whatever it becomes, i‘m in for inspiration. 👍🤪 1 Share this post Link to post Share on other sites
Oldskool 6,663 #13 Posted February 17, 2021 I've been searching but probably in the wrong place. Where do I find the info on the 8 speed I.D/ rebuilds. Share this post Link to post Share on other sites
ebinmaine 73,088 #14 Posted February 17, 2021 8 minutes ago, Oldskool said: I've been searching but probably in the wrong place. Where do I find the info on the 8 speed I.D/ rebuilds. Information section. Transmission. 1 Share this post Link to post Share on other sites
oliver2-44 10,791 #15 Posted February 17, 2021 @Oldskool got to https://www.wheelhorseforum.com/forum/144-transmissions/ 2 Share this post Link to post Share on other sites
ebinmaine 73,088 #16 Posted February 17, 2021 35 minutes ago, Tractorhead said: Ddidn‘t we all seat in the same box with the loosen Screws ? 😇 YYYEEESSSS!!!!! 2 Share this post Link to post Share on other sites
Oldskool 6,663 #17 Posted February 17, 2021 For sitting in a rotten shed, snow covered and no oil in it, everything is looking pretty good. 2 Share this post Link to post Share on other sites
slim67 2,809 #18 Posted February 17, 2021 2 hours ago, Oldskool said: I dont have a frame. Engine choice, I knew a guy that had a 4cyl inline Kohler but he decided to keep it. I knew where there was a little diesel but it sold. Then I was thinking twin engine. Soooooo I'm not sure yet. Nitrous bottle, maybe lol Cage or harness probably not. too bad you're not closer as I have a little Kubota d600 diesel. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #19 Posted February 17, 2021 6 minutes ago, slim67 said: too bad you're not closer as I have a little Kubota d600 diesel. Ya you are a bit to far out of my traveling area. Heck Eric is and he is in Maine lol 1 Share this post Link to post Share on other sites
Oldskool 6,663 #20 Posted February 17, 2021 I went to the link above and watched the video but did not see how to get the shift fork shafts out and one is stuck in place 1 Share this post Link to post Share on other sites
ebinmaine 73,088 #21 Posted February 18, 2021 27 minutes ago, Oldskool said: I went to the link above and watched the video but did not see how to get the shift fork shafts out and one is stuck in place Those should line up. (That's neutral) Stick a lever where I made a red line and gently pry up. Share this post Link to post Share on other sites
Oldskool 6,663 #22 Posted February 18, 2021 9 minutes ago, ebinmaine said: Those should line up. (That's neutral) Stick a lever where I made a red line and gently pry up. I have it out to neutral now but cant get it to the next detent. But how do they come out of the case when I get them moving freely ? Share this post Link to post Share on other sites
ebinmaine 73,088 #23 Posted February 18, 2021 4 minutes ago, Oldskool said: I have it out to neutral now but cant get it to the next detent. But how do they come out of the case when I get them moving freely ? Should be a hole in the front of the case where there will be a set screw type thing or a freeze plug. Remove that.... PAY ATTENTION. This is the home of the (in) famous "hoobie doobie balls". They will roll from your place to roughly Cincinnati before stopping. 2 1 Share this post Link to post Share on other sites
Oldskool 6,663 #24 Posted February 18, 2021 5 minutes ago, ebinmaine said: Should be a hole in the front of the case where there will be a set screw type thing or a freeze plug. Remove that.... PAY ATTENTION. This is the home of the (in) famous "hoobie doobie balls". They will roll from your place to roughly Cincinnati before stopping. Ok I did see that in the video. I was under the assumption it was a set screw. Mine doesnt have a set screw. So must be a plug? I assume I drill that out and tap to replace with set screw? Share this post Link to post Share on other sites
ebinmaine 73,088 #25 Posted February 18, 2021 18 minutes ago, Oldskool said: Ok I did see that in the video. I was under the assumption it was a set screw. Mine doesnt have a set screw. So must be a plug? I assume I drill that out and tap to replace with set screw? That I'm not sure of. All of mine have had screws.... And now we call in @stevasaurus. 2 Share this post Link to post Share on other sites
