BeninCT 451 #1 Posted January 13, 2021 1. Is there an exact replacement LED light for these rear reflectors? I live on a busy road and might prefer lights over them. 2. tractor has standard round sealed beam glass headlights- is there an LED bulb that is the accepted substitute? 3. thinking of some tiny running lights on the tractor and have seen some that are LED and fit in 5/16” holes of which there are a few on my frame so might be a fun add without drilling. Anyone done anything like this? 2 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #2 Posted January 13, 2021 There are things on the market available. Yes. Somebody else will likely pop up with part numbers. It would be a good idea to get a hold of your local Road commissioner and find out what the statutes are on using a powered vehicle in the road to remove snow. Example: In Massachusetts you must have a registered vehicle to go in the road. Not saying we all do. That's the statute. Here in Maine I don't have to have a vehicle that is registered but I do have to have an orange or amber flashing light visible from 360°. I actually have some of those tiny little LEDs that you're talking about. I'll be putting some on Trina's tractor as backup lights. TBH I hadn't thought of putting them in the frame but that's a great idea. Glad to see you got a plow and am going to be putting that rig to use. Weights weights and more weights is going to be your best friend. 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #3 Posted January 13, 2021 8 minutes ago, BeninCT said: 1. Is there an exact replacement LED light for these rear reflectors? I live on a busy road and might prefer lights over them. 2. tractor has standard round sealed beam glass headlights- is there an LED bulb that is the accepted substitute? 3. thinking of some tiny running lights on the tractor and have seen some that are LED and fit in 5/16” holes of which there are a few on my frame so might be a fun add without drilling. Anyone done anything like this? I am trying to find some rear light too, here is an USA link :https://www.ebay.com/itm/Toro-Wheel-Horse-Tail-Light-105202/193802647482?hash=item2d1f89b7ba:g:XeIAAOSwY2tf14hE And don't forget tor grease those spindels etc 3 Share this post Link to post Share on other sites
Goofey 89 #4 Posted January 13, 2021 Napa has the rear leds. Junglesite has the fronts. 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #6 Posted January 13, 2021 7 minutes ago, Goofey said: fronts Is that the ones that are .. PAR 36? 1 Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted January 13, 2021 I picked up some led trailer marker lights for a couple bucks at a show a few years ago. Same size as what's on my other tractors... Share this post Link to post Share on other sites
The Tuul Crib 7,354 #8 Posted January 13, 2021 Most of your truckstops have these marker lights. 1 Share this post Link to post Share on other sites
Goofey 89 #9 Posted January 13, 2021 24 minutes ago, ebinmaine said: Is that the ones that are .. PAR 36? yes :-) 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #10 Posted January 13, 2021 (edited) 53 minutes ago, ebinmaine said: Is that the ones that are .. PAR 36? are they just the same size? Just a replacement of the factory lamps? @pfrederi Edited January 13, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
ebinmaine 80,767 #11 Posted January 13, 2021 5 minutes ago, Maxwell-8 said: are they just the same size? Just a replacement of the factory lamps? Check the posts above me but I think that's true. 1 Share this post Link to post Share on other sites
peter lena 10,076 #12 Posted January 13, 2021 BEN got mine at walmart , BLAZER BRAND,# C12544R, EASY TO DRILL OT THE POP RIVIT BASE, AND REMOUNT THE NEW LIGHTS. have them on all three of my horses , also added grounding points to all related areas , I too have a road side traffic issue , the lights help out , pete 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #13 Posted January 13, 2021 PAR 36 Parabolic Aluminized Reflector 36 eighths of an inch = 4.5" diameter 3 Share this post Link to post Share on other sites
Goofey 89 #14 Posted January 13, 2021 (edited) Yes the par36 is the factory bulbs. So yes. Direct replacement. Edited January 13, 2021 by Goofey 1 Share this post Link to post Share on other sites
Goofey 89 #15 Posted January 13, 2021 1 hour ago, peter lena said: BLAZER BRAND,# C12544R They are same size but not OEM looks. Share this post Link to post Share on other sites
BeninCT 451 #16 Posted January 13, 2021 (edited) @ebinmaine i wont operate on the road just end up out near it and occasionally crossing to a neighbor so would like more light (plus its a fun little add) @Maxwell-8 perfect just have to see about an LED bulb. Looks like those will be exact replacements for my reflectors to lessen the crime against the tractor also I did grease all that but cleaned off the squeeze out! That kind of crazy here. Hot topic I guess. Was thinking of some small lights like this because they actually fit in a 6mm hole (1/4”) of which there are few on my frame. Also want to put a red light up under the hood so there is a red glow over the engine when running. Just to fit in with the kids up the road https://www.amazon.com/BRIGHTEST-Light-Bolt-Interior-Motorcycle/dp/B01AFU4QBS/ref=sr_1_2_sspa?crid=2CJN9OGUVHB6Q&dchild=1&keywords=small%2Bwaterproof%2Bled%2Blights%2Bsubmersible%2B12%2Bvolt&qid=1610575408&sprefix=small%2B12%2Bvolt%2Bled%2Blights%2Bwater%2Caps%2C204&sr=8-2-spons&smid=A6XWG1D8Q4A4V&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExTlVWR0ZTNTVRVEM5JmVuY3J5cHRlZElkPUEwNjY2NjUxMzE3RlhUTElBUFo3ViZlbmNyeXB0ZWRBZElkPUEwOTUxNTkxMkNKRE02MFZaQkE3NCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 Edited January 13, 2021 by BeninCT 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #17 Posted January 13, 2021 1 hour ago, BeninCT said: @ebinmaine i wont operate on the road just end up out near it and occasionally crossing to a neighbor so would like more light (plus its a fun little add) @Maxwell-8 perfect just have to see about an LED bulb. Looks like those will be exact replacements for my reflectors to lessen the crime against the tractor also I did grease all that but cleaned off the squeeze out! That kind of crazy here. Hot topic I guess. Was thinking of some small lights like this because they actually fit in a 6mm hole (1/4”) of which there are few on my frame. Also want to put a red light up under the hood so there is a red glow over the engine when running. Just to fit in with the kids up the road https://www.amazon.com/BRIGHTEST-Light-Bolt-Interior-Motorcycle/dp/B01AFU4QBS/ref=sr_1_2_sspa?crid=2CJN9OGUVHB6Q&dchild=1&keywords=small%2Bwaterproof%2Bled%2Blights%2Bsubmersible%2B12%2Bvolt&qid=1610575408&sprefix=small%2B12%2Bvolt%2Bled%2Blights%2Bwater%2Caps%2C204&sr=8-2-spons&smid=A6XWG1D8Q4A4V&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExTlVWR0ZTNTVRVEM5JmVuY3J5cHRlZElkPUEwNjY2NjUxMzE3RlhUTElBUFo3ViZlbmNyeXB0ZWRBZElkPUEwOTUxNTkxMkNKRE02MFZaQkE3NCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 Watch the pricing carefully. I ordered 10 white off fleabay for 10 bucks. I texted Trina about this earlier. She's not normally into bling and shiny stuff but these little lights are gonna be a thing in our rides. Good road safety during plowing. Neat eye-catcher at get-togethers. I'm 100% pure redneck hillbilly trucker. CAN'T have too many lights. 3 1 Share this post Link to post Share on other sites
pfrederi 21,183 #18 Posted January 14, 2021 One thing about the red marker lights. After you get your reflectors off see where the extra hole (for the wires) is in your fender. A lot of the cheapy lights have the wire feed in one corner. That may not align with the hole in your fender. No big deal if you do not mind drilling a new hole in the fender but if you do mind... 2 Share this post Link to post Share on other sites
grinchsr 674 #19 Posted January 14, 2021 Superbrightleds.com for the tail lights Part # M9-R4 1 1 Share this post Link to post Share on other sites
BeninCT 451 #20 Posted January 14, 2021 Seems like any 2 x 4” light will do though the factory units are 1 15/16” tall I think. Great info here- post some pics if you have done any of this- going to change some of this on mine in the coming weeks. Share this post Link to post Share on other sites
Skipper 1,792 #21 Posted January 14, 2021 If anyone on this side of the pond needs these front or rear led lights, looking and fitting like the OEM ones, I got them on stock. 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #22 Posted January 14, 2021 (edited) 22 minutes ago, Skipper said: If anyone on this side of the pond needs these front or rear led lights, looking and fitting like the OEM ones, I got them on stock. What's your price for a set of rears to Belgium? If i better DM you, is perfect for me Edited January 14, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
Skipper 1,792 #23 Posted January 14, 2021 Don't think we are supposed to do price talks in public outside the classifieds pm send (in a few minutes) 2 Share this post Link to post Share on other sites
JohnD 145 #24 Posted January 17, 2021 On 1/14/2021 at 6:06 AM, grinchsr said: Superbrightleds.com for the tail lights Part # M9-R4 Those cost less than the Toro lens cover I bought recently! Share this post Link to post Share on other sites
BeninCT 451 #25 Posted January 18, 2021 (edited) Ended up making a bracket instead b/c the amazon lights I go were too small to cover the factory reflectors and I decided to just leave them and have both. Had to do something in the garage on Saturday... Also @pfrederiI put those same LED headlights on and had to wire all the lighting straight from the hot post on the solenoid to eliminate the flicker but they all look great. Thx Edited January 18, 2021 by BeninCT 1 Share this post Link to post Share on other sites
