Jimmy0331 27 #1 Posted November 5, 2020 How’s it going. So I located a brand new in the box plow and frame the numbers on frame are 0648bc01 b1063. Does anyone know what tractors it will fit on. The rear mount it came with is narrower than the one that is currently on my tractor. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #2 Posted November 5, 2020 The b1063 should be a serial number but serials don't have letters. The C in the model number indicates it is for the C-Series at the time. Click on the picture Garry Share this post Link to post Share on other sites
ebinmaine 80,960 #3 Posted November 5, 2020 39 minutes ago, Jimmy0331 said: How’s it going. So I located a brand new in the box plow and frame the numbers on frame are 0648bc01 b1063. Does anyone know what tractors it will fit on. The rear mount it came with is narrower than the one that is currently on my tractor. Thanks. Do you have pics of the plow/frame and or your tractor? Share this post Link to post Share on other sites
Jimmy0331 27 #4 Posted November 6, 2020 Yeah that’s the exact plow in the diagram. I have a few tractors and want to try to mount it on one them. Most likely my 67 1267 or which ever one I can for it on. But I don’t think the rear mounting bracket will work. I also have a 69 raider 12, 64 654 71 commando 800, and 86 308-8. I don’t believe it will fit any but wanted confirmation from the you guys who know best. Thanks again as always for the help and Info. I’ll get a picture after supper. Share this post Link to post Share on other sites
ebinmaine 80,960 #5 Posted November 6, 2020 That plow will fit any of the long frame tractors you've mentioned. 1267. 69 Raider. 308-8. Share this post Link to post Share on other sites
ebinmaine 80,960 #6 Posted November 6, 2020 It's the bracket I'm curious about Share this post Link to post Share on other sites
Jimmy0331 27 #7 Posted November 6, 2020 So the dirty bigger bracket came off the 1267 and the newer smaller bracket came with the plow and frame. 1 Share this post Link to post Share on other sites
ebinmaine 80,960 #8 Posted November 6, 2020 I'm not familiar with that smaller piece. Perhaps @953 nut or @pfrederi could help. Maybe off a 200 series or a Lawn Ranger? Share this post Link to post Share on other sites
JohnD 145 #9 Posted November 6, 2020 Its hard to tell the scale, but the one on the right looks like what is under my '83 C-175. I measure 12" from silver latch to latch. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #10 Posted November 6, 2020 The one on the left mounts to the front of the square axle housings. The one on the right mounts to the bottom of the square axle housings. Each assembly needs to stay with their plow. If you look at the list of plows in the file I linked you to it will make sense to you. Click on that picture in the link. Roll the one on the right so the cut-out notch is on the bottom and then turn end for end. Now it's position matches the one on the left. Garry Share this post Link to post Share on other sites
Jimmy0331 27 #11 Posted November 6, 2020 Ok I see it now. I was looking at it as a front mount. Makes total sense now. Thanks again for all the help. In everyone’s opinion which tractor would be best for the plow setup and what tractor would be best for snow thrower. I usually use the raider with snow thrower but in a year I magically acquired 4 more tractors. Lol. Thanks. Share this post Link to post Share on other sites
ebinmaine 80,960 #12 Posted November 6, 2020 16 minutes ago, Jimmy0331 said: In everyone’s opinion which tractor would be best for the plow setup and what tractor would be best for snow thrower 1 hour ago, ebinmaine said: 1267. 69 Raider. 308-8. I'll go back here for a minute. Snowblowing needs some HP to spin the tines. Keep the snowblower on the Raider. Plowing ISN'T about power. Either the 1267 or 308 is adequate for plowing power. Plowing is about traction. You need weights and chains. LOTS of WEIGHTS. Fluid fill the tires and hang a bunch of metal stuff off the tractor. Share this post Link to post Share on other sites
