ACman 7,741 #176 Posted August 10, 2022 I believe the case/ihc is a little darker and remember if you get implement paint it usually dries slower . Definitely don’t need adverse reactions happening at this point . 2 Share this post Link to post Share on other sites
Pullstart 71,259 #177 Posted August 10, 2022 1 hour ago, davem1111 said: I haven't heard of this "grease trick" yet - what is it? anything you don’t want paint to stick to grease it. It’ll wipe away when finished! 1 1 Share this post Link to post Share on other sites
Achto 32,751 #178 Posted August 10, 2022 (edited) 1 hour ago, ACman said: believe the case/ihc is a little darker and remember if you get implement paint it usually dries slower . Definitely The earlier Farmall (pre 1949) IH50 paint is a bit darker yet than the Case/ IH IH2150 paint. Haven't seen the Farmall paint on the shelf in a long time though. Edited August 10, 2022 by Achto Share this post Link to post Share on other sites
Achto 32,751 #179 Posted August 10, 2022 @Pullstart, do you have a body shop or a jobber near by that mixes paint? You could take one of your body panels to them and have them mix a correct match for you. 1 Share this post Link to post Share on other sites
Pullstart 71,259 #180 Posted August 10, 2022 2 minutes ago, Achto said: @Pullstart, do you have a body shop or a jobber near by that mixes paint? You could take one of your body panels to them and have them mix a correct match for you. I’m just doing the drums in the rear for now… to make the “new wheels” effect pop a little more. If we ever do a full resto, I’ll go that route 1 Share this post Link to post Share on other sites
Pullstart 71,259 #181 Posted August 10, 2022 Hey @Achto what say you? Obviously we’re not talking a class A panel. How much more red should I take off here? I’ll be getting down to bare metal before it’s all gone I bet! 1 1 Share this post Link to post Share on other sites
Achto 32,751 #182 Posted August 10, 2022 (edited) 11 minutes ago, Pullstart said: How much more red should I take off here? That depends on how smooth you want the finish. Looks like a fair amount minor of pitting yet. Could stop where you are at and let some of the history shine through. If you hit some bare metal, just spray a coat of self etching over it right before painting. If you want a smooth finish. Then you may have to get it as smooth as you can right now, hog some more primer on it, and wet sand it again. Edited August 10, 2022 by Achto 2 Share this post Link to post Share on other sites
ACman 7,741 #183 Posted August 10, 2022 (edited) This reminds me as a kid trying to get or 29 Allis Chalmers model U ready for the Wauseon Ohio show . That year they were featuring Chalmers and we were on a big deadline to get it done. I remember digging out that old nasty grease. First tractor to have air tires and we had the oldest one there plus the only one on rubber tires . Edited August 10, 2022 by ACman 1 Share this post Link to post Share on other sites
Handy Don 17,475 #184 Posted August 10, 2022 4 hours ago, davem1111 said: I haven't heard of this "grease trick" yet - what is it? Paint won't stick to grease. A light grease coating on, say, the inside bore of the wheel hub lets you simply wipe off any "overspray" after you're done. I'll be using that trick to keep the spindle bores of the RM-366 mower deck plate paint-free without having to try to tape them off. (Paint first; install bearings later ) 1 Share this post Link to post Share on other sites
Handy Don 17,475 #185 Posted August 10, 2022 3 hours ago, Achto said: stop where you are at and let some of the history shine through I like this suggestion! Share this post Link to post Share on other sites
953 nut 69,371 #186 Posted August 10, 2022 4 hours ago, Pullstart said: Obviously we’re not talking a class A panel. How much more red should I take off here? I would spray some satin clear and call it done! Patina rules! 1 Share this post Link to post Share on other sites
Pullstart 71,259 #187 Posted August 10, 2022 13 minutes ago, 953 nut said: I would spray some satin clear and call it done! Patina rules! Yeah, wrong tractor for making patina though…. Well in our eyes 1 Share this post Link to post Share on other sites
Pullstart 71,259 #188 Posted August 10, 2022 I’m not sure if the IH red is any darker but it’s on! 2 2 Share this post Link to post Share on other sites
Pullstart 71,259 #189 Posted August 10, 2022 My paint tray Self etching primer applied, next is Antique White! 2 1 Share this post Link to post Share on other sites
Pullstart 71,259 #190 Posted August 10, 2022 Coat #1 3 2 Share this post Link to post Share on other sites
19richie66 17,935 #191 Posted August 10, 2022 (edited) 15 minutes ago, Pullstart said: I’m not sure if the IH red is any darker but it’s on! Looks fine! Roll with it. Is that a 520 swept a le I see laying back there? Edited August 10, 2022 by 19richie66 1 Share this post Link to post Share on other sites
Pullstart 71,259 #192 Posted August 10, 2022 4 minutes ago, 19richie66 said: Looks fine! Roll with it. Is that a 520 swept a le I see laying back there? good eye! I THINK I figured out where it’ll land too! 1 Share this post Link to post Share on other sites
8ntruck 9,304 #194 Posted August 11, 2022 (edited) Good thread. Both front tires on Clyde are leaking. I am fed up enough with them that I am going to order some ribbed tires for him. I can't make myself put new tires on the crusty wheels, so they will need to be refinished. Think I'll follow your guide here. Edited August 12, 2022 by 8ntruck 3 Share this post Link to post Share on other sites
rjg854 13,360 #195 Posted August 11, 2022 1 hour ago, 8ntruck said: I am going to order some robbed tires What's the website for robbed tires, can you get them cheap that way. 1 5 Share this post Link to post Share on other sites
8ntruck 9,304 #196 Posted August 12, 2022 2 hours ago, rjg854 said: What's the website for robbed tires, can you get them cheap that way. Dang auto spell correction! 1 2 Share this post Link to post Share on other sites
rjg854 13,360 #197 Posted August 12, 2022 happens me more than I want to say Share this post Link to post Share on other sites
Pullstart 71,259 #198 Posted August 12, 2022 6 minutes ago, rjg854 said: happens me more than I want to say I’m glad it happens you Randy Back to the Senior progress. Specifically the right front spindle’s vertical slop. I went to the hardware store yesterday for some 1” round shims, thrust washers, anything. They had no idea. Trying to sell me wooden contractor shims. I found a 5 pack of 1” thrust washers straight from George of the Jungle for $10 and they’ll be here tomorrow. It’s kind of hard not to fall into their corporate gains when I can’t find what I need locally from the trusted hardware source. I’m letting the paint on the wheels cure in the hot sun for a couple days and will start mounting tires. I’ve got the mini tire changer clamped to the shop lift arm and can use the big tire changer for the rears. I also (thanks to @953 nut for turning me on to this product) ordered some tire lubricant for easy mounting. Hopefully I don’t wreck these fresh painted rollers! 1 1 Share this post Link to post Share on other sites
Handy Don 17,475 #199 Posted August 12, 2022 7.7 pounds? Man, that'll lube a lot of tires, I suspect. Share this post Link to post Share on other sites
Pullstart 71,259 #200 Posted August 12, 2022 3 minutes ago, Handy Don said: 7.7 pounds? Man, that'll lube a lot of tires, I suspect. I have a feeling it has a pretty long shelf life… and many tires get changed here in the shop… for tractors and automotive purposes 1 1 Share this post Link to post Share on other sites
