Dennis C. 142 #1 Posted September 21, 2020 Being relatively new to WH tractors, I need some feed back. While checking the transmission oil level on the 312-8 I noticed the dip stick was thick and milky. At some point in the tractors life water must have collected in the sump. I drained the old oil, flushed the trans with kerosene twice and filled with 80-90wt gear oil. Took the tractor out around the neighborhood and there is whining in the transmission. Some it sounds like a bearing at times as the noise will get louder and then quiet down. Are these trannys typically noisy? Thanks Share this post Link to post Share on other sites
peter lena 10,016 #2 Posted September 21, 2020 DENNIS, THANKS FOR THE QUESTION, the milky solution was a water intrusion , probably at the shifter boot, that should be replaced , another thing , did you jack up the front end at flush time to enhance drainage? i like the fact that you flushed it twice with kero, that will help in clean out. having done this a number of times ,the road drive is very important, and using every gear and hi/lo range , reverse seamed to really help mine out , remember you are still cleaning and restoring bearing movement . the units are typically not noisy , but as much use and shifting with clean fluid is the answer. i still think you're in the restoring function stage. how long did you use the kero? i put hours on mine ,and road time , shifting and range shifting , mine just kept getting better , all 3 of my horses , have had this , and today , they are smooth and quiet , local cul de sac , is my test track , let us know , pete 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,145 #3 Posted September 21, 2020 Trick is to get all the gunk out and then run 'em with clean oil... They are amazingly durable. My last one was quite noisy and the "oil" looked like a coffee with too much cream... Did the drain, clean, drain and clean oil, twice and worked like a charm... 2 Share this post Link to post Share on other sites
CCW 1,519 #4 Posted September 21, 2020 I too had the milky oil in transmission from a leaky shift boot. Boot itself was just fine, but would not stay in position. Solved the problem by putting a small hose clamp around the top of the boot after I put it back in place. 1 Share this post Link to post Share on other sites
tunahead72 2,645 #5 Posted September 21, 2020 2 hours ago, Dennis C. said: ... I drained the old oil, flushed the trans with kerosene twice and filled with 80-90wt gear oil... Just to clarify... Did you drive the tractor around with the kerosene, like @peter lena is suggesting? I think that's an important part of the whole cleaning process. 1 Share this post Link to post Share on other sites
peter lena 10,016 #6 Posted September 22, 2020 dennis c , as i said you must drive that flushing solution around and make numerous gear changes and hi/lo changes as well, it takes time. you cannot just add a flush and then drain it , you have to put it to work . after you do that a few times and put some road/ work time on them ,they start to get better. these gear boxes are very rugged , and with a regular oil change and a possible boot change as well , they work with ease, pete 2 Share this post Link to post Share on other sites
echris 1,426 #7 Posted September 22, 2020 I wonder if doing this process under load makes a difference. When I got my 310-8 the trans fluid was chocolate milk. I flushed it 2x with diesel, running it on jack stands through all gears high/low for 10 mins per gear each time, with an oil flush also 10 mins per gear between. I still have a bit of what I think is bearing noise, many hours later, fluid sparkly clean. @Dennis C. I noticed with mine, under load, going uphill etc, it gets much louder. Tooling around on level ground it's silent. Is that what you see? Share this post Link to post Share on other sites
oliver2-44 11,694 #8 Posted September 22, 2020 @echris While flushing on jack stands or driving around can clean up a transmission it can’t repair pitting in the gear teeth the water caused. I have a Suburban transmission I opened and rebuilt but at the time didn’t have gears to replace The pitted ones. It works fine but it sure is noisy 1 Share this post Link to post Share on other sites
Dennis C. 142 #9 Posted September 22, 2020 Thanks for all your replies and GREAT info. Not being familiar with the WH transmission, I was wasn't confident how long I should drive around with the kero in the transmission. At most, I drove about 10 minutes. You suggest I drive longer? How long would be safe? I certainly can flush the tranny again. I checked the oil yesterday after driving around and it's clear. And yes, Pete I jacked up the front of the tractor to make sure the sump fully drained. Under load is when the tranny seems to be loud and occasionally I hear a squeal like a rusty bearing would make. Overall the tractor is in good shape and will last my lifetime. 1 Share this post Link to post Share on other sites
953 nut 68,519 #10 Posted September 22, 2020 12 minutes ago, Dennis C. said: occasionally I hear a squeal like a rusty bearing would make. Like Jim @oliver2-44 said, flushing will get the bad stuff out, but it won't repair damage that resulted from the bad stuff being there. I wouldn't be to concerned about a little occasional whining and squealing if it doesn't get any worse. Share this post Link to post Share on other sites
peter lena 10,016 #11 Posted September 22, 2020 DENNIS C. that 10 minute drive will not do it, i put a couple of combined hours on my flush , another thing i emphasize is the road time , do you have access to any paved road that is not traffic busy ? you need to heat up that oil and stop and start every gear and hi/lo ranges often to operate / circulate the flushing , lubrication function. you are not putting a high stress pull on the gearing , so the fluid qualities are more to clean than save. i have done this numerous times , often in reverse for long periods of time , every flush and refill , i use the walmart 75-90 basic oil , its cheaper yet it does the job. after all of your shifting comes back , then i go to a higher rated oil. its the road / heated gear oil and use of every gear function that will recover your issue. let us know how its going, pete Share this post Link to post Share on other sites
Dennis C. 142 #12 Posted September 25, 2020 OK, a lengthy flush was completed, maybe not as long as suggested but completed anyway. Filled the tranny with 80-90 wt gear oil and have been hauling firewood out of the woods for the past 3 days. Transmission is much quieter and the squealing noise is gone. Found a new riding companion. My daughters dog loves to ride on the tractor with me!! 1 Share this post Link to post Share on other sites
