Rob R
42" S/D Triple Blade Mower Spindle (mandrel)
Rob R
Hi guys need you help have a 42" side Discharge Deck (Triple Blade) mower deck, mounted on a C-81, that is in bad need of an outside Spindle (Mandrel) the pulley on top is # 5877. The bottom bearing is toast. so I poise the following questions. Note pics attached.
1. Does any on have one of these for less then a Kings ransome?
2. Is it possible to disassemble and install an new bearing from like NAPA?
3. All three spindles have NO Zerk grease fittings can I drill and add some...... if yes where on the housing is the best place to do this.
Thanks feel free to add any other options......
Achto
@PeacemakerJack do you have any spindles that might fit this application??
WHX??
If he don't you or I might Dan. Those look alot like the spindles on  that deck we decided not to refurb. Might be worth checking.
Might be the top side  they used a real common bearing bottom may well be a needle bearing. You need to disassemble and find out.
That is a crossover deck that used the old style shell but the new style carriage.
Any numbers on the deck at all or long gone?
Edited by WHX24
Not the pic I wanted
Rob R
I Went out and finally did locate a miss placed (moved) I.D. tag the #s are 42MS01 6174
Thanks for the great information and Parts Manual excerpt. I will try to get the bad Spindle out and apart to see just how bad the damage is, my guess is that all the bolts will break off and make things kinda miserable.
Edited by Rob R
WHX??
This looks like the one should have a common bearing on the top and a needle on the bottom. Basically the same spindles as these. Yours might be the type K non greaseable ones tho if they have been upgraded. Only one way to find out and that's peel it apart which sounds like it has to done anyway.
Rob R
So after MUCH heat and slow progress I go the Mandrel off and apart. I need a new upper roller bearing and a lower needle bearing.... on flea-bee and the Internet they want a small fortune for them so I went to McMaster-Carr and found their R12 in both categories (total $ around $30.00) just might work so taking a chance and will see what happens..... might need a little creative shimming but so be it...... to be continued.....  The Macmaster bearings R12 one needle and one roller arrived.... as stated they were slightly shorter then the stock bearing so I shimmed them until correct width. Installed and cut the front and back lawn..... back in business.... thanks for the help!  Save another one that was laying in the woods for at least 15 years.
Edited by Rob R
JustHorse'nAround
Any chance you still have the McMaster part numbers? I have two 42" SD decks which sound more like a bag of hammers in an avalanche than a precision machine.
Thanks!
Rob R
Thanks!
Sorry I do NOT have the exact # I used they were in the R12 category on the internet site. I did have to shim them and this took a while to get right.... not sure it was worth the time and effort to do this especially with two. Suggest you take the existing to NAPA or spend time with a rep from McMaster Carr to get the correct bearings.
  • Similar Content
    • Joe Warren
      By Joe Warren
      Mower Spindle Components
      mostly new old stock
      Prices shown do not include the cost to ship.
      Message me with your needs and any questions.
      Thank you.
      Joe
      PART NUMBER(S)
      DESCRIPTION
      QTY. AVAILABLE
      PRICE EACH
      103711
      NOS Spindle shaft assembly
      1
      39
      103711 (used)
      Used spindle shaft assembly
      1
      29
      101686 or 5875
      NOS Spindle shaft sub-assembly
      1
      49
      104890
      NOS Spindle shaft
      1
      49
      104982
      NOS Spindle shaft
      1
      44
      107998 or 107446
      NOS Spindle shaft
      2
      89
      109912
      NOS Spindle shaft
      1
      59
      112673 or 109965
      NOS Spindle shaft
      1
      59
      108849
      NOS Spindle shaft
      1
      89
      102780 or 104373
      NOS Spindle cups 1.0” tall
      2
      39
      NOS Spindle cups 0.9” tall
      2
      39
      102784 or 104374
      NOS Spindle cups 0.8” tall
      1
      39
      100289
      NOS Needle bearing, MFD USA Torrington
      2
      19
      101411
      NOS Ball bearing, sealed both sides, MFD China
      2
      29
      101480 or 1515 or 5493
      6
      9
      106084
      NOS Ball bearing, sealed one side, MFD Japan
      11
      9
      106085
      NOS Ball bearing, open, not sealed, MFD Taiwan
      16
      9
      106070
      NOS Seal spacer
      10
      9
      100674
      NOS Spacer-pulley
      1
      13
      107445
      NOS Spacer-bearing
      1
      9
      106069
      NOS Spacer
      1
      9
      110234
      NOS Lock bolt-pulley
      4
      2
      110242 or 908033
      NOS Lock bolt-blade
      11
      2
      915090 or 32146-20
      NOS Lock nut-pulley
      11
      2
      936028 or 32120-42 or 52-6640
      NOS Snap ring
      7
      2
      8389
      spindle housing
      1
      39
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
    • She's a Newbie
      By She's a Newbie
      I bought a C-160 beautifully restored but I plan on using it for a dependable mower.  The deck is totally shot.  I have a 42" deck that is currently on a 310-8.  Will it fit on my C-160?
      Also, do most of you members use a lawn mower jack to work on your wheel horses?  If so, which one would you recommend?  Thanks you!
    • Joe Warren
      By Joe Warren
      one new old stock spindle housing
      part number 106063
      $79 includes shipping within US lower 48.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
