RJ Hamner
Clutch Safety Switch Problem
gwest_ca
To see a picture of the 103480 switch click on the picture
Garry
rmaynard
The demystification guide for the 1995 is a bit confusing for that year since it serves both the 8 speed and the hydro. So if it were me, I'd start with the basics. Disconnect the wires from the switch and connect your meter. Depress the clutch and see if the meter shows that the switch is closed. If so, the switch is okay. If not, you have a bad switch. Some 416-8 models have the wires on the switch going from your 12 volt source (ignition switch) directly to the starter solenoid, other have it going to the starter relay. Reconnect the wires and find out where yours goes.  See if there is continuity from the switch to that point.
Edited by rmaynard
squonk
The reason why the Fridgi switch does not close unless fully depressed is because you do not want you evaporator fan(s) to come on unless the door is fully closed. If they come on with hot humid air coming thru a door gasket that isn't sealed you will have warm milk and a block of ice on the coil in the morning.
Wondering if you could rig something on the arm to push the switch rocker all the way or move the switch out.
oldredrider
Personally,  I like the "down at the clutch pedal" switch idea. Keeps it simple, like it should be.
Bill D
Sorry you are having so much trouble with the clutch switch.  I only suggested using that fridge switch because I saw it on here.  I have not personally used it.  Bill
RJ Hamner
I had seen that post myself and was thinking about it before you mentioned it.  Hey, you're the one who noticed my mistake.  That's two thumbs up in my book.
  • Similar Content
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • morePEdal
      By morePEdal
      416-8 with Onan P216 Engine
      The good:
      *576 hours
      *Nice, clean deck (42”)
      *Nice Plow
      *Wheel Weights
      *Chains
      *2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
      *Original receipts and paperwork and manuals.
      *Receipt showing tune-up and changing from the deck to the plow in November 2021
      The bad:
      *The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
      *Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
      *I didn’t get a chance to test drive it because of this.
      *One front tire goes flat fast, one rear tire has a slow leak.
      *He is going to buy a battery before I look at it again on Friday so I can test drive it.
      What do you think is the issue? Is it the battery or fuel system?
      Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
      *He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
      He’s asking $500.
    • Boyd
      By Boyd
      wheel horse garden tractor mower, rear discharge mowing deck & snow blower both in good condition and runs well. all the parts for the snow blower are with it.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
