Stormin 9,986 #26 Posted June 23, 2020 I think I need to pay a visit to Spec Savers. Had another look and see the top of the grease nipples. I've all the parts for a side discharge except for the deck shell. That was badly damaged. I think it had been run over by something heavy that bent it. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #27 Posted June 23, 2020 24 minutes ago, Stormin said: I think I need to pay a visit to Spec Savers. Had another look and see the top of the grease nipples. I've all the parts for a side discharge except for the deck shell. That was badly damaged. I think it had been run over by something heavy that bent it. Ha ha I know the feeling! Share this post Link to post Share on other sites
Dan.gerous 2,696 #28 Posted June 23, 2020 This is the lift chain that either needs shortening or a solid bar added. Share this post Link to post Share on other sites
ebinmaine 74,488 #29 Posted June 23, 2020 2 minutes ago, Dan.gerous said: This is the lift chain that either needs shortening or a solid bar added. Given the option I'd do the solid bar. We use it for moving dirt once in awhile but mostly it's for scraping the snow a little bit deeper during the winter. We have a dirt driveway so things tend to get compacted and it's nice to be able to give it that little extra oomph to clean things. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #30 Posted June 23, 2020 @Stormin I don't suppose you have the part circled in red? A measurement of it would be handy as no idea how long it should be, or happy to buy it and it's associated little bits😊 Share this post Link to post Share on other sites
Dan.gerous 2,696 #31 Posted June 23, 2020 5 minutes ago, ebinmaine said: Given the option I'd do the solid bar. We use it for moving dirt once in awhile but mostly it's for scraping the snow a little bit deeper during the winter. We have a dirt driveway so things tend to get compacted and it's nice to be able to give it that little extra oomph to clean things. Do you still have the rubber strip on the bottom or do you use a sacrificial steel strip for grading the driveway? The rubber is great on the tarmac and concrete but it lacks the bite of a solid edge when pushing the dirt/gravel/mud in the courtyard. Share this post Link to post Share on other sites
ebinmaine 74,488 #32 Posted June 23, 2020 1 minute ago, Dan.gerous said: Do you still have the rubber strip on the bottom or do you use a sacrificial steel strip for grading the driveway? The rubber is great on the tarmac and concrete but it lacks the bite of a solid edge when pushing the dirt/gravel/mud in the courtyard. We have 2 snow dirt dozer blades that go on the front and 1 mid mount grader. The grader blade has nothing on it but it wouldn't be a big deal to add something. Both push blades have sacrificial steel edges. I keep our snow pushers tilted forward one more notch so they don't have a tendency to dig in quite so much. 1 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #33 Posted June 23, 2020 1 minute ago, ebinmaine said: We have 2 snow dirt dozer blades that go on the front and 1 mid mount grader. The grader blade has nothing on it but it wouldn't be a big deal to add something. Both push blades have sacrificial steel edges. I keep our snow pushers tilted forward one more notch so they don't have a tendency to dig in quite so much. I hadn't looked into fine tuning the angle, kind of just spent a few hours having fun - the tinkerer took a back seat to the inner child. A steel edge as an option would be good, damn like I don't have enough things to do! 1 Share this post Link to post Share on other sites
ebinmaine 74,488 #34 Posted June 23, 2020 4 minutes ago, Dan.gerous said: - the tinkerer took a back seat to the inner child I do that almost every time I get on a tractor. 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #35 Posted June 23, 2020 1 minute ago, ebinmaine said: I do that almost every time I get on a tractor. Yeah they are good fun, I went for a quick test drive to check the plow out and returned several hours later! 1 1 Share this post Link to post Share on other sites
Stormin 9,986 #36 Posted June 23, 2020 I'll look for that rod tomorrow, Dan. As for the plough/dozer blade, I'm the same as Eric. Both that and my mid mount grader have sacrificial strips. 1 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #37 Posted June 23, 2020 7 minutes ago, Stormin said: I'll look for that rod tomorrow, Dan. As for the plough/dozer blade, I'm the same as Eric. Both that and my mid mount grader have sacrificial strips. Cheers for that 👍 Yeah the rubber is good, but steel might be better for some applications. Good to know you can get mid mount graders in the UK Will keep an eye open for one once my wife let's me! Share this post Link to post Share on other sites
Stormin 9,986 #38 Posted June 23, 2020 1 minute ago, Dan.gerous said: Good to know you can get mid mount graders in the UK Will keep an eye open for one once my wife let's me! My mid mount is the same as my dozer blade. Home made. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #39 Posted June 24, 2020 9 hours ago, Stormin said: My mid mount is the same as my dozer blade. Home made. You guys are so clever, I'm far too conservative/lacking skill when it comes to steelwork. Share this post Link to post Share on other sites
Stormin 9,986 #40 Posted June 24, 2020 Here you are Dan. Yours if you want it. 2 Share this post Link to post Share on other sites
Mickwhitt 5,190 #41 Posted June 24, 2020 Looks a great package deal Dan. Lots to play with there. If you need any steel work doing or any parts turningvetc give me a shout. Always happy to fire the lathes and mills up for some swarf making practice. My new exhaust system is great but does take away space where the deck would fit. If you need to cannibalize that deck you were gifting me then please do so. I have a hydraulic sweeper on a two wheel walk behind. Now that would be a project to marry the two. Mick 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #42 Posted June 24, 2020 1 hour ago, Stormin said: Here you are Dan. Yours if you want it. Yes please pm me 😊 Share this post Link to post Share on other sites
Dan.gerous 2,696 #43 Posted June 24, 2020 35 minutes ago, Mickwhitt said: Looks a great package deal Dan. Lots to play with there. If you need any steel work doing or any parts turningvetc give me a shout. Always happy to fire the lathes and mills up for some swarf making practice. My new exhaust system is great but does take away space where the deck would fit. If you need to cannibalize that deck you were gifting me then please do so. I have a hydraulic sweeper on a two wheel walk behind. Now that would be a project to marry the two. Mick Many thanks for the offer Mick, it's nice knowing handy people! No that deck is all yours, I have another one to steal parts off, however it's a different type and that particular bit didn't fit. I found sweepers specifically for the wheelhorse in Denmark. Skipper has one I want to buy next time some cash is free 😊 if you go onto the Danish version of eBay and search wheelhorse they have some awesome stuff. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #44 Posted June 24, 2020 @ebinmaine @Stormin I did the quick fix for now and shortened the chain. Was playing around with the blade angle as it was in the furthest back position, when I put it several positions closer to vertical the ground clearance reduced to 0! The short chain has given me a couple of inches clearance so I can use the wheelhorse with the trailer and blade now. I noticed while playing about under there that the lift mechanism has another arm on it, wonder what that's for? Share this post Link to post Share on other sites
Dan.gerous 2,696 #45 Posted June 24, 2020 Forgot to mention it slightly fouls the steering arm with the shorter chain when you pick it up. Probably just needs a spacer to keep it slightly more to the side. Share this post Link to post Share on other sites
ebinmaine 74,488 #46 Posted June 24, 2020 I don't have any implement other than the plows so I don't know what that extra arm would be for. Because of the very rough terrain that I live on I needed to get the maximum lift that I could from my plow. When I made the brackets for the rear axle I also lowered the attaching point about an inch. Combining that with appropriate placement of the new lift point in the middle, when I lift the plow it sometimes touches the front of the frame. but I don't have an attach a matic or mule drive or anything like that. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #47 Posted June 24, 2020 To gain moldboard height when lifted you need to add spacers to the rear axle plow attach... 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #48 Posted June 24, 2020 31 minutes ago, ebinmaine said: I don't have any implement other than the plows so I don't know what that extra arm would be for. Because of the very rough terrain that I live on I needed to get the maximum lift that I could from my plow. When I made the brackets for the rear axle I also lowered the attaching point about an inch. Combining that with appropriate placement of the new lift point in the middle, when I lift the plow it sometimes touches the front of the frame. but I don't have an attach a matic or mule drive or anything like that. I also notice that other lever for altering the plow angle stops the brake pedal from depressing fully.... Spacer on the rear axle bracket send the next thing to do, I have the same problem with ground clearance around the farm. Ideally want to keep the plow on as much as possible until I buy another house to tow the trailer. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #49 Posted June 24, 2020 1" blocks netted me nearly 2" higher lift at the cutting edge. 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #50 Posted June 24, 2020 58 minutes ago, WVHillbilly520H said: 1" blocks netted me nearly 2" higher lift at the cutting edge. I have found some spacers and removed the bracket, just need to find some longer bolts now. Might see if I can get bigger spacers as mine are only about half inch. 2 Share this post Link to post Share on other sites
