ebinmaine 81,281 #8501 Posted July 15, 2025 2 hours ago, 8ntruck said: Also interesting to note the lack fo counterbalance springs on the hood hinges of the Baracuda. Part of the extreme weight saving on that car. I wonder if there are any aluminum body panels on that one. Rule of thumb - 100 pound weight saving = about .1 second reduction in 1/4 mile elapsed time. @ebinmaine what transmission was in that car - Torqueflite or 4 speed? We looked at a ton of cars and I'm not positive but I think it was a stick 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8502 Posted July 15, 2025 This morning I headed up the Seacoast. I had to go into a little town called Southport. Never been there.... Pretty area. Share this post Link to post Share on other sites
adsm08 5,247 #8503 Posted July 15, 2025 I ripped the crotch out of my pants at work today. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8504 Posted July 15, 2025 7 minutes ago, adsm08 said: I ripped the crotch out of my pants at work today. 😬 😲 Share this post Link to post Share on other sites
SylvanLakeWH 32,920 #8505 Posted July 15, 2025 (edited) Oakland County (Michigan) Fair... Pretty small tractor area, but decent hit & miss display. No 's... Edited July 15, 2025 by SylvanLakeWH 5 1 Share this post Link to post Share on other sites
adsm08 5,247 #8506 Posted July 15, 2025 40 minutes ago, ebinmaine said: 😬 😲 Eh, I just split the seam, at the lowest point, and it was already mid afternoon. Just got some extra ventilation. 1 Share this post Link to post Share on other sites
8ntruck 9,420 #8507 Posted July 16, 2025 I got Pack Rat, the B-110 out and did some cart work moving items between the house and lake house in preparation for the folks coming for the weekend. I seem to be on a string of bad mechanical luck - water pump on the outboard, the chipper going dead, and now, one of the tires on the cart has developed a leak. I ended up charging the tank on my pancake compressor and carrying it in the cart. I'd load the cart, fill the tire, drive the 100 yards to the other house, unload then load the cart, inflate the tire, drive to the other house, etc, etc, etc. The current tires on the cart are cheaper wheelbarrow tires, maybe 6 years old. The sidewalls are cracking, so it is time for replacement. I'll go with something heavier for replacements. I think the cart wheels are 8" by 4" wide. 1 Share this post Link to post Share on other sites
8ntruck 9,420 #8508 Posted July 17, 2025 (edited) I pulled the pontoon as close to land as I could get it and dug into the water pump replacement. It went pretty much as advertised, even though I was working in the water. Here is what I found: Which impeller is new, an which is old? Anyone? Anyone? This job would be a lot easier with the boat on the trailer and out of the water. I think maybe, this should be a PM job every 4 seasons or so. Edited July 17, 2025 by 8ntruck 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,942 #8509 Posted July 17, 2025 2 hours ago, 8ntruck said: PM job every 4 seasons or so. Maybe every 2 seasons. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #8510 Posted July 17, 2025 7 hours ago, 8ntruck said: Which impeller is new, an which is old? Anyone? Anyone? Ooooo. Oooooo! Wait! Uuuuhhhhhhh The black one? 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,920 #8511 Posted July 17, 2025 8 hours ago, 8ntruck said: Which impeller is new, an which is old? Anyone? Anyone? So my question to the engineers in the house: why plastic? Why not aluminum or some other non-rusteeseum? We changed our cheap plastic impeller every few years in the old Johnson 60 and it was torn up every time... PITA... 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #8512 Posted July 17, 2025 8 minutes ago, SylvanLakeWH said: So my question to the engineers in the house: why plastic? Why not aluminum or some other non-rusteeseum? We changed our cheap plastic impeller every few years in the old Johnson 60 and it was torn up every time... PITA... Is there a need for a sacrificial part? A weak Link in the chain? If the gear rotor was made out of a harder material would the housing become the damaged piece? 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,920 #8513 Posted July 17, 2025 Just now, ebinmaine said: Is there a need for a sacrificial part? A weak Link in the chain? If the gear rotor was made out of a harder material would the housing become the damaged piece? Ahh... makes sense... Share this post Link to post Share on other sites
Ed Kennell 47,942 #8514 Posted July 17, 2025 (edited) 4 hours ago, SylvanLakeWH said: So my question to the engineers in the house: why plastic? Why not aluminum or some other non-rusteeseum? The impellers in most marine engine pumps are made from a flexible plastic or rubber as the vanes must flex as the impeller rotates in the excentric housing. Most of the failures are caused by overheating that causes the rubber impeller to become brittle resulting in the fingers breaking off. Overheating is caused by lack of water caused by a plastic bag over the intake, the engine tilted up too high, mud in the intake, and engines left running after the loaded boat is pulled out of the water. I don't start my engines during long term storage as the fuel system is drained and the cylinders have been fogged. But I do have the muffs and water on and turn the engines over monthly to flex the impeller fingers to prevent them from taking a permanent set. Edited July 17, 2025 by Ed Kennell 3 2 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8515 Posted July 17, 2025 (edited) 13 hours ago, 8ntruck said: Seeing so much material no longer attached to the impeller makes me wonder where that material ended up! Edited July 17, 2025 by Handy Don 2 Share this post Link to post Share on other sites
8ntruck 9,420 #8516 Posted July 17, 2025 3 hours ago, Handy Don said: Seeing so much material no longer attached to the impeller makes me wonder where that material ended up! While I was butting it back together, I had that same thought. I'll assume that the bits and pieces made it through the cooling system and exited through the propeller hub. 1 Share this post Link to post Share on other sites
Handy Don 17,735 #8517 Posted July 17, 2025 8 minutes ago, 8ntruck said: While I was butting it back together, I had that same thought. I'll assume that the bits and pieces made it through the cooling system and exited through the propeller hub. 🤞 1 Share this post Link to post Share on other sites
8ntruck 9,420 #8518 Posted July 17, 2025 14 hours ago, Ed Kennell said: Maybe every 2 seasons. Funny thing. When making arrangements for storage last fall, while talking about oil changes on the engine and lower unit, I did ask about the impeller. He stated that it was probably OK since the newer impellers last longer now. Guess I get to tell him 'I told you so' this year. 3 Share this post Link to post Share on other sites
ML3 2,571 #8519 Posted July 17, 2025 On 7/15/2025 at 7:34 PM, SylvanLakeWH said: Oakland County (Michigan) Fair... Pretty small tractor area, but decent hit & miss display. No 's... Hit & miss engines are so cool. I got 3. 1st one is Fairbanks Morse Z 2nd is Alpha DeLaval 3rd Mccormick Deering LB 1 3 Share this post Link to post Share on other sites
squonk 48,427 #8520 Posted July 17, 2025 Made a headliner retainer out of a piece of Ridgi Wall for my Honda Ridgeline. 1 Share this post Link to post Share on other sites
squonk 48,427 #8521 Posted July 17, 2025 If I had a dollar for every boat water pump impeller I sold at Napa I could buy @Jrblanke a half dozen Shoo Fly pies! 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #8522 Posted July 17, 2025 2 hours ago, ML3 said: Hit & miss engines are so cool. I got 3. 1st one is Fairbanks Morse Z I had a FM here for awhile. Mine was a Flywheel engine but not a true Hit n miss. Spark cadence was constant. Love the sound. I gave it to a local fella for some project he was fiddlin with. Share this post Link to post Share on other sites
Beap52 2,537 #8523 Posted July 17, 2025 On 7/15/2025 at 6:50 PM, adsm08 said: Eh, I just split the seam, at the lowest point, and it was already mid afternoon. Just got some extra ventilation. Apparently, when a fellow reaches a certain age, he is prone to fail in zipping his zipper. I've reached that age and my wife is quick to point it out. I just tell her "I'm air cooled." In another topic was hit and miss engines. They are almost memorizing watching and listening to them run. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #8524 Posted July 17, 2025 1 hour ago, Beap52 said: Apparently, when a fellow reaches a certain age, he is prone to fail in zipping his zipper. I've reached that age and my wife is quick to point it out. I just tell her "I'm air cooled." In another topic was hit and miss engines. They are almost memorizing watching and listening to them run. Here's the FM I had. 2 Share this post Link to post Share on other sites
953 nut 70,649 #8525 Posted July 17, 2025 1 hour ago, Beap52 said: hit and miss engines. They are almost memorizing watching and listening to them run. I'm a bit like a hit and miss engine myself. When placed under a load I will do my best to accomplish the task at hand, when idling around I may let out a little poooof now and then. 1 5 Share this post Link to post Share on other sites
