Pullstart 68,647 #576 Posted August 12, 2020 Prayers to those effected in the train incident, sad story in tough times as it is... Share this post Link to post Share on other sites
WHX?? 53,765 #577 Posted August 12, 2020 (edited) I've gotten into the habit of always deburring copper as thats just how I was taught as an apprentice. Easier these days what with the power methods available. A step bit in a drill motor works well too. Good thing you ain't charging by the hour as the cost would get way out of hand the way yer going at it! You should be using store bought manifolds and those usually dont' go on till after floor and framing is done and final heat source install. Reverse return is not needed if using them as they have balancing valves and flowmeters built right in as well as a easy way to zone. Simple design & layouts just get these. Edited August 12, 2020 by WHX24 1 Share this post Link to post Share on other sites
Pullstart 68,647 #578 Posted August 12, 2020 Yeah, this is a freebie for the FIL Jim. I’m sure he’ll get me back some day They want to be able to pressure test before and during concrete pour, so I’ll toss this on and run a line out the window with a gauge. 1 Share this post Link to post Share on other sites
WHX?? 53,765 #579 Posted August 12, 2020 (edited) Pressure test = absolutely! We label all the ends per zone and then just tie it all together with crimp fittings plug on one tail and pressure gauge and shrader valve on the other. Tie every up on a rebar frame to keep it out of the concrete. Take lots of pics of the layout for future reference if needed. We been using these for a professional look but were using the conduit ells for years when we knew no better. . http://www.theezroute.com/ Where you at when we need infloor pics Plunge!?!?!? @JCM Trying to coach a rookie here! .... Prolly out more horses! Edited August 12, 2020 by WHX24 2 Share this post Link to post Share on other sites
Pullstart 68,647 #580 Posted August 12, 2020 6 minutes ago, WHX24 said: Pressure test = absolutely! We label all the ends per zone and then just tie it all together with crimp fittings plug on one tail and pressure gauge and shrader valve on the other. Tie every up on a rebar frame to keep it out of the concrete. Take lots of pics of the layout for future reference if needed. We been using these for a professional look but were using the conduit ells for years when we knew no better. . http://www.theezroute.com/ Where you at when we need infloor pics Plunge!?!?!? @JCM Trying to coach a rookie here! .... Prolly out more horses! like they say... if you want to find the easy way, hire a lazy man! Thanks Uncle Jim! Share this post Link to post Share on other sites
Pullstart 68,647 #581 Posted August 12, 2020 (edited) Took Uncle Jim’s advice and put a chamfer bit in my drill. Manifold test system is all assembled for indoors. I’ll toss the outside system together and be good to go. Edited August 12, 2020 by pullstart Picture didn’t load 2 Share this post Link to post Share on other sites
JCM 10,507 #582 Posted August 12, 2020 Your talking to an old school Plumber here. Always ream copper tube after cutting. I have not done much radiant. Did a 6500 square foot home and a few others but needed extra sets of hands that were not always around. Did a house with Weil-McLain cast iron baseboard with the reverse piping system and that was some serious work. House was a concrete slab with sleepers and then all oak hardwood floors, your stub ups better be precise, can't cut CI baseboard like copper fin tube. I will admit I am not a radiant heat specialist, cast iron baseboard heat in our home and 2 cast iron woodstoves for backup, 1 in the living room and 1 in the basement to keep the floors warm, sort of like radiant but without all the piping and controls etc. By the way, nice work. 1 Share this post Link to post Share on other sites
Mickwhitt 5,253 #583 Posted August 12, 2020 Well, a few days ago I went to my local park to remove the seating from a basketball court which is constantly being vandalised. Its made of weld mesh panels and i cut them out with a disc grinder. We used the panels to reinforce a section of fence youths have damaged. Over night the steel panels mysteriously found their way back to the seats, rebuilt by the teenage vandals responsible for the seats being removed in the first place. So I had to remove them permanently today and cart the steel back home. The yoofs were most annoyed as this was their space we were dissing. Funny I thought we paid for it through our taxes. And its a play area for small children to use not for teens to hang out, do drugs and fumble in each others underwear. But anyway, yoofs threatening me with violence apart I now have a lot of weldmesh and steel bar to play with. I also have a nice new John Deere ride on mower gifted to our community group from the park group in thanks for the work on the play area. 5 Share this post Link to post Share on other sites
Pullstart 68,647 #584 Posted August 12, 2020 I used a wad of copper and some paracord to string the manifold up. Now, I can make my pex connections and keep it all close to right. 1 Share this post Link to post Share on other sites
Tractorhead 9,215 #585 Posted August 12, 2020 11 hours ago, ebinmaine said: As avid mountain hikers, Trina and I have been to the highest points in Maine and New Hampshire and many many of the surrounding hills. I can't quite see Europe from here. I'm sure it's close. I do a Wink, did you see it Buddy? 😇👋 1 2 Share this post Link to post Share on other sites
Pullstart 68,647 #586 Posted August 13, 2020 In leu of my recent hand jab, Rylee is tackling the lawn chores today, under strict supervision. She is a champ on that Scag! 2 2 Share this post Link to post Share on other sites
WHX?? 53,765 #587 Posted August 13, 2020 Grass looks nice and green Kev musta got some rain over there? 1 Share this post Link to post Share on other sites
Pullstart 68,647 #588 Posted August 13, 2020 Pullstart Stables, presenting Barnum and Bailey’s 2 ring circus... construction style! Manifold is complete, test piping run out the window! 1 Share this post Link to post Share on other sites
Stormin 9,987 #589 Posted August 13, 2020 Drove back from south Wales today from meeting the new found section of SWMBO's family. Brought a new project home. Just fitted in the back of the car. 38yrs old and the last 20 buried in the back of a farm shed. 3 1 1 2 Share this post Link to post Share on other sites
ebinmaine 76,564 #590 Posted August 13, 2020 1 hour ago, Stormin said: project We'll be looking for updates. Hopefully it takes you slightly less time than my 2 current tractor projects. 4 Share this post Link to post Share on other sites
Pullstart 68,647 #591 Posted August 14, 2020 4 hours ago, ebinmaine said: We'll be looking for updates. Hopefully it takes you slightly less time than my 2 current tractor projects. We’ve almost forgot you have active tractor projects! 6 Share this post Link to post Share on other sites
Stormin 9,987 #592 Posted August 14, 2020 (edited) 7 hours ago, ebinmaine said: We'll be looking for updates. Oh eck! Why did I mention it? I think I may be in for some pay back. Edited August 14, 2020 by Stormin 2 Share this post Link to post Share on other sites
Mickwhitt 5,253 #593 Posted August 14, 2020 Two things Norm... One, its not red! And B, it appears to be deficient in the sum of two wheels. In short, and not to put too fine a point on it, That ain't no tractor! 1 3 Share this post Link to post Share on other sites
Stormin 9,987 #594 Posted August 14, 2020 4 minutes ago, Mickwhitt said: Two things Norm... One, its not red! And B, it appears to be deficient in the sum of two wheels. In short, and not to put too fine a point on it, That ain't no tractor! Your very observant for a Yorkshireman, Mick. Motorcycles are in my blood. From riding pillion with my father from the age of eight, up to nine years ago, there's always been one around. 2 2 Share this post Link to post Share on other sites
squonk 45,086 #595 Posted August 14, 2020 7 hours ago, Stormin said: Oh eck! Why did I mention it? I think I may be in for some pay back. Don’t think you have anything to worry about nORM! Share this post Link to post Share on other sites
Mickwhitt 5,253 #596 Posted August 14, 2020 Its one vehicle I've never driven, never. I've had a go in diggers, dozers, garbage compactors but I have never sat astride a motorbike let alone ridden one. I was a pedal cycle patrol officer in Sheffield for a few years trained to the international police mountain bike standard so im no stranger to two wheels. But two wheels and an engine have never appealed to me for some reason. Maybe it was the slide show we were treated to at school when I was 14, showing the mortal remains of large number of ex-motorcyclists who had come to grief on two wheels. Everything from legs snapped off to heads in pieces told me these things were dangerous. I was sick for days after and have a real phobia of motorbikes as a result. Maybe in this day and age I would claim PTSD and child abuse lol. 1 1 Share this post Link to post Share on other sites
Stormin 9,987 #597 Posted August 14, 2020 I've only broken one leg and that was playing rounds. Baseball in the US. Share this post Link to post Share on other sites
D_Mac 9,333 #598 Posted August 14, 2020 Had my doctors appointment today. I was getting my results from the 2 CT scans I had done last week. Last year I was diagnosed with Pancreatic and Throat Cancer. Had my surgeries and treatments. One year has passed now and time to see how I am doing. The CT scans I had last week were on my abdomen and chest. I still need to go for ones to my throat and head area. Todays results were good. Abdomen is showing no signs of the cancer and my chest and lungs are showing improvements. My lungs were damaged from Pulmonary Embolisms I developed while I was in the hospital. They want a PET scan in 6 more months. I have to meet with my radiologist and my throat surgeon and make the appointments to check on my throat. No one was seeing patients during the Corona shut down but are now. So I will take this good news and keep my fingers crossed for the next step. My throat still bothers me daily. I would rather go through what they did to my stomach 100 times over then one more time of what was done to my throat. Stay Healthy Everyone !!! Dont take good health for granted !! 2 1 1 Share this post Link to post Share on other sites
Pullstart 68,647 #599 Posted August 14, 2020 Here’s to a throat scan as positive as your chest and abdomen @D_Mac! 1 1 Share this post Link to post Share on other sites
ACman 7,683 #600 Posted August 15, 2020 On 8/13/2020 at 5:32 PM, pullstart said: If it’s not your first rodeo with in floor heat disregard. Just a suggestion make sure those lines aren’t too close to the toilet flange. You don’t want to be melting the wax ring 2 1 Share this post Link to post Share on other sites
