adsm08 5,243 #10251 Posted November 3 Work, PT, voting, then I came home, put the wheels back on my Explorer, and anchored my tire balancer to the floor properly and retested it for the issues I've been having. Anchoring the machine is apparently an important step. 1 Share this post Link to post Share on other sites
c-series don 12,657 #10252 Posted November 4 (edited) Well it wasn’t today, it was actually Sunday morning but I’m just getting around to posting this. We had a simple tanker/drafting drill on our FD property. I was the tanker operator, that’s me standing on the back of the tanker. Edited November 4 by c-series don 6 3 Share this post Link to post Share on other sites
Rick3478 478 #10253 Posted November 4 Beautiful weather in NW Ohio encouraged me to make another fall cleaning pass, and encountered a Kohler M12S engine core I had all but forgotten that I have. So I took a photo and put it on the classifieds for the group. Reduced my asking price on 310-8 transaxle while I was at it. Gathered a couple buckets of Hickory nuts and shelled them. Rain predicted for tomorrow morning and I think I'm actually ready for it. Hey, normal clock feels great. Don't have to get up in the dark, got up with the Sun instead. 3 1 Share this post Link to post Share on other sites
953 nut 70,382 #10254 Posted November 4 36 minutes ago, c-series don said: We had a simple tanker/drafting drill on our FD property. Glad it was just a drill. I spent about 20 hours shuttling water from the closest hydrant three miles away to a couple tanks to cover exposures near a barn fire. Three other pumpers and a tank truck were doing the same. Barn full of hay is nearly imposable to extinguish but we saved the house and several other outbuildings as well as the livestock. Cool little rainbow there. 2 Share this post Link to post Share on other sites
ohiofarmer 3,529 #10255 Posted November 5 Just trying and finding out why my batteries were going flat. Actually it was the chargers.One battery was at ten volts and she went to six volts in an hour Then i got out the old manual 2 amp charger and it worked and spun one of the 2 C-160s and the fuel pump was not working. it fired on carb spray. The 314 is up ,but its time to be mounting up a snow plow. At least now i think the three yausa batteries can be saved. We are still mowing /grinding leaves as they fall with the 314. Having old equipment is still preferred to the new stuff. Little things like fuel pumps and such may need swapped out or get an electric assistant pump. therre is a guy called the Flying wrench on Facebook who services equipment and he is fun to watch. He goes to the outdoor equipment with a super organized truck filled with Milwaukee Pak Out boxed and gets it done. 3 Share this post Link to post Share on other sites
CasaytheMann 288 #10256 Posted November 5 (edited) just curious , shoot any penetrating lubrication into fender , chassis opportunities ? really shows it self days later , with related , creeping film . want a hint for , vehicle track zones ? any local , big box , parking lots , rust free for life , pete I'm sorry but I couldn't make any sense from your post. Edited November 5 by CasaytheMann 2 Share this post Link to post Share on other sites
c-series don 12,657 #10257 Posted November 5 @CasaytheMann don’t worry, few can ! 1 1 Share this post Link to post Share on other sites
ohiofarmer 3,529 #10258 Posted November 6 20 hours ago, c-series don said: @CasaytheMann don’t worry, few can ! I will try harder..Sometimes spell correct is not kind. 1. The 314 runs great 2. The c160-8 has a replacement carburetor and once the linkage from the carb to the governor shaft is complete, it should run great as well. 3.The c-160 auto is backfiring through the carb. I would call it a cold backfire with no flames coming out of the carb. if anybody has a recommendation on replacement carbs for these machines from eight to sixteen horsepower, i am all ears.. What i did learn yesterday was to test the fuel pump before servicing the carburetor. I keep hearing from guys like Taryl fixes all that repop carbs work well if you find the right company. But these guys are fixing newer machines than the K series Kohler is used on. . 1 Share this post Link to post Share on other sites
ebinmaine 81,160 #10259 Posted November 7 4 hours ago, ohiofarmer said: if anybody has a recommendation on replacement carbs for these machines from eight to sixteen horsepower, i am all ears.. Those carbs run from 10 to 16 HP. The smaller ones are 8 HP or less. 4 hours ago, ohiofarmer said: What i did learn yesterday was to test the fuel pump before servicing the carburetor. I keep hearing from guys like Taryl fixes all that repop carbs work well if you find the right company. He's probably right... But I've never seen a consistent performing company. Check your own carb at the top. If the throttle shaft is not too loose in the bore, you'll be OK. 4 hours ago, ohiofarmer said: But these guys are fixing newer machines than the K series Kohler is used on. Share this post Link to post Share on other sites
953 nut 70,382 #10260 Posted November 7 10 minutes ago, ebinmaine said: Those carbs run from 10 to 16 HP # 26 is for the 10 and 12 HP, # 30 is for the 14 and 16 HP. You can bolt the wrong one on the same flange but it will never run properly. 1 Share this post Link to post Share on other sites
953 nut 70,382 #10261 Posted November 7 Today I brought Mrs. 953 home from the hospital. Both of us got the flue shots but the flue my wife came down with didn't seem to be the one the shot covered. It was an intestinal virus that hit her like a ton of bricks. She had been visiting a friend at the hospital several times so my guess is that is where she got it. The first symptom was her throwing up right after lunch, I told her if she didn't like my cooking she could just tell me! 1 6 Share this post Link to post Share on other sites
ebinmaine 81,160 #10262 Posted November 7 32 minutes ago, 953 nut said: # 26 is for the 10 and 12 HP, # 30 is for the 14 and 16 HP. You can bolt the wrong one on the same flange but it will never run properly. Quite true. Share this post Link to post Share on other sites
Blue Chips 881 #10263 Posted November 7 Spouse and I just got back from a week in Arizona. She's a Jane Austen fan, and we attended the JASNA (Jane Austen Society of North America) conference in Tucson. She was an official 'attendee,' and I was just listed as her 'companion.' There were over 700 people at the conference, so it was a fairly big affair. I only attended one lecture and the dinner, which was kind of fun, since almost everyone at the dinner dressed in Regency period clothing (including yours truly). I must say that we really looked the part with our Regency get-ups, (even though I don't know how to line dance or play whist). Wife attended a bunch of different lectures and events, and while she was getting 'Jane Austen-ized' I ventured out on my own and visited the Pima Air & Space Museum, which has a massive collection of aircraft, and the Titan Missile Museum (Titan missile silo), which was very interesting but kind of a somber experience at the same time, since it was sort of weird standing in the control room where mass destruction could have been wreaked upon the world. The tour guide had a couple of people in our tour group act as operators and follow the actual sequence that would have been used to launch a missile, which was a bit spooky. Looking down at a disarmed missile in the silo: We had a free day at the conference and visited the Sonora Desert Museum, which I thought was excellent. Here's a scenic view from the museum grounds: We also spent a night in Bisbee, which I rather liked. Very laid-back, artsy-craftsy old copper-mining town. Lots of arts and cultural events for such a small town. There weren't many tourists, despite the nice weather, and it still retains a substantial amount of its old mining-town atmosphere. We may go back someday and spend a little more time there to see if we like it well enough to use it as a winter getaway spot---not necessarily for purchasing a house, but possibly renting a place for a month or so during the dead of winter, since their winters are quite mild, and they rarely get snow. While we were gone, lots of leaves decided to fall here in Maine, and of course they've been soaked by rain, so my backpack blower won't move them very well. I've decided to wait another week (or more) until almost all of the oak leaves are down, and then use one of the Wheel Horses with mulching blades to make three or four complete passes over the lawn to grind them to oblivion, rather than trying to blow them away or rake them up. 5 5 1 Share this post Link to post Share on other sites
adsm08 5,243 #10264 Posted November 8 One of the few finishing touches to the new shop that has gone neglected to this point is the expansion of the shop air system. Most of today was spent running to the store and back, and cutting, threading, and hanging iron pipes for air. All the new line is installed, I just have to button up a few end-of-the-line (literally) things before I can turn the air on and check for leaks. 6 Share this post Link to post Share on other sites
Dan 312-8 647 #10265 Posted November 8 Well, it was actually yesterday... Picked this McLane edger up for $40 on October 27th in Ohio on my way to Cleveland for a business trip. PO said it ran when he bought it in the spring. I didn't try at the time of purchase as I had to keep moving. IT had good compression and oil in the crank case, so I figured I'd take a chance on it. Spent the last week doing cleaning, changed the "oil" if you could call it that, replaced the old gas, cleaned the plug and regapped it (new one in it now). Using the @c-series don method of trying to get a combustion engine running, I sprayed 50:1 gas mix in the carb, and within a few pulls it started, and began running on its own only it I held the governor back, if I let it go it would stall. So not knowing squat about carbs and what to do, I contacted Bob Koch, some of you may know him, he always sets up his tractors right near me and Don at the big show, he has a sweet B-60 that he brings, Bob runs a small engine shop on the side, well in 5 minutes Bob had it running like a top yesterday. Then I had to deal with the broken lever for the throttle cable, ever try to find an exact match of something close to 30 years old... Notta, so I got to looking at the broken plastic lever closer and said to myself, "I can make one", so my new throttle lever made out of 1" x 3/16" steel flatstock will outlast this edger 10 to 1... I brought it home yesterday from Bob's shop and had about 450' lineal feet of sidewalk and curb edging done in 20 minutes! New air cleaner will be here Tuesday and I will drain and replace the crankcase oil again. That's all folks! Have a great day! 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,826 #10266 Posted November 9 Watched a tree crew take down a very large maple... Cabled it 10 years ago but it was time... On a positive note, we have planted 20 more trees than were on our property when we moved in, so we don't feel too bad... 5 Share this post Link to post Share on other sites
ebinmaine 81,160 #10267 Posted November 9 2 hours ago, SylvanLakeWH said: On a positive note, we have planted 20 more trees than were on our property when we moved in, so we don't feel too bad... We got plenty o' trees. You need em. We send em. 1 Share this post Link to post Share on other sites
953 nut 70,382 #10268 Posted November 10 15 hours ago, SylvanLakeWH said: Watched a tree crew take down a very large maple. That tree was much too close to the house, though it provided a lot of shade. Your insurance company thanks you very much. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,826 #10269 Posted November 10 29 minutes ago, 953 nut said: That tree was much too close to the house, though it provided a lot of shade. Your insurance company thanks you very much. Yes But I will not hold my breath for an insurance refund... 1 2 Share this post Link to post Share on other sites
adsm08 5,243 #10270 Posted November 11 On 11/7/2026 at 8:01 PM, adsm08 said: One of the few finishing touches to the new shop that has gone neglected to this point is the expansion of the shop air system. Most of today was spent running to the store and back, and cutting, threading, and hanging iron pipes for air. All the new line is installed, I just have to button up a few end-of-the-line (literally) things before I can turn the air on and check for leaks. Finished this up Sunday and tested for leaks. I had a pretty substantial one from an elbow joint near the beginning of the expansion. I had to cut the next piece of pipe in two to get it out to fix the leak and then get put a union in it. Did that tonight, there are two more, pretty minor leaks still. One is about 14 ft up and I am not going to worry about it. The other is in the regulated line I use for painting and running my press. It had to be taken apart to do the original work, and has to come apart again because the regulator is no good. Anyway.... tonight I had PT for my be shoulder, which I of course agitated threading pipe Saturday, and I got a talking to about undoing all their work right before the ortho follow up. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,703 #10271 Posted yesterday at 06:32 PM Stuck my finger into Lake Michigan today, just the index finger, to cold to take a plunge. First Great Lake I’ve ever seen. It’s like an ocean! 4 3 1 1 Share this post Link to post Share on other sites
953 nut 70,382 #10272 Posted 9 hours ago 19 hours ago, Sparky said: to cold to take a plunge You could go back in a few months and go ice fish ing with @stevasaurus. 1 1 Share this post Link to post Share on other sites
stevasaurus 23,885 #10273 Posted 2 hours ago You look good there Mike !! Nice looking Lake, isn't it !! Share this post Link to post Share on other sites
