Mickwhitt
What did you do today?
rjg854
1 hour ago, cleat said:
I had that problem a couple of years ago.
That kind of job isn't pleasant, glad to see it wasn't a lot worse.  Had to have a whole new septic system 2 years ago.  Because I have to use salt to control the iron in the water, it eventually ate the concrete septic tank up. Now systems here in my area all have to be engineered systems because we have so much clay and it doesn't perk well.  Expensive!!!
  • Sad 4
cleat
My water softener goes out to the road ditch out front as does the washing machine.
No septic company would even look at my septic system for repair.
The only option is a new system as they need to bring it up to the latest code ($$$).
Made my $100.00 repair seem good.
I have very sandy soil so drainage is not an issue.
Ed Kennell
No water softener, but my gray  water goes down the gravel road to the state road.    Eco friendly for sure....diluting the tons of salt PENDOT sprays on the road.
HyperPete
Posted (edited)
More flowerbeds for Donna.
Flat shovelling grass is no fun!
Edited by HyperPete
PWL216
Replaced the electric window motor on the drivers side door of my Frontier. The old mechanism’s cable was frayed and got stuck in the motor wheel and eventually just  kept the window in the down position.
peter lena
@Mickwhitt   went over a throttle linkage hiccup , turned out it was a tye wrap  , just glancing  on the  linkage , wiring must have moved over time , as it settled in , hindering  full  smooth action , while there  also found some other areas to enhance . my mower decks turn with ease , at the mule drive , belt point , by hand , also  ex condition of  belts , no fraying or cracking . since going after  my related pulleys , for lubrication up grade , been years now , no pully whine , and engagement  is smooth and easy . put a drop of super lube hydraulic , lube on my heim joints , and cable end  drip access , all move with smooth ease . topped up fuel , and added an ounce of STA BIL  fuel additive , absolutely  stops fuel hose break down . experiment that works , eliminated all related old fuel hose , replace with new , then started using STA BIL , filters are always clean / clear , no debris in fuel bowl or tank , instant starts , pete
adsm08
On 7/20/2025 at 8:45 AM, cafoose said:
Most shower valves have an anti scald device that needs to be adjusted for hotter water.
This was it. I messed with it a bit tonight before hopping in after work and got to take a nice hot shower. I even have a little head space on the heat now.
  • Heart 2
cafoose
I've installed a few of those myself and if no kids are using the shower I've even removed the hot water limiter completely and it got super hot if I wanted it to. :happy-bouncyredfire:
adsm08
I don't think I need to remove it. It gets plenty hot right now, and I may actually move it back a click because I do have kids using the shower.
ebinmaine
The recently purchased Horses Hauler trailer got some dandy new DOT Conspicuity Tape.
The back of the fenders, sides of the fenders, and rear tailgate area all have added visibility.
I added 4 vertical stripes and a horizontal stripe to the gate.
The gate is 1" square tubing. The tape is nearly 2" wide.
The sides have two directional sight.
The bottom of the gate has tape visible while the gate is upright or laying down in the trailer.
With flash to show reflection.
This:
..... is a product called King Starboard.
It's a high density poly something that is marketed to the salt water boat industry.
My thought here is to attach a 1" wide strip to the back of the top of the gate which is the part that hits the ground when the gate drops.
I was able to use the square and razor to repeatedly score the surface followed by snapping the 1" strip off the edge.
To hold it on the trailer I'm thinking of using several self tapping flat pan screws.
Other suggestions welcome.
8ntruck
@Pullstart - i'm trying to send you a PM.  Red Square says you cannot receive messages.
MainelyWheelhorse
Countersunk flat head screws?
MainelyWheelhorse
@ebinmaine Stainless or a rust treated screws that aren’t Phillips might be a good idea too so they aren’t rusted into the ramp later.
ebinmaine
Excellent point
lynnmor
I have a neighbor about 1/4 mile away with that tape on a trailer.  He parks it in a way that headlights shine on it, annoying as hell.
Handy Don
Posted (edited)
Click on @ebinmaine here in this text and then choose “Message”
It’s a quirk in the forum software that you cannot just create new messages. from the inbox--I suspect it might be part of “anti-hacking” protection.
Edited by Handy Don
ebinmaine
Works good..... as long as the other driver is actually paying attention.
WHX??
Window shopped & made an offer for a 854. 'Tis my belief everyone should have one ... who am I to argue with myself? Better to ask forgiveness right??
'Sides Dan came and got his tractors so got a couple open stalls ... :lol:
  • Excellent 7
peter lena
@WHX?? hiding in plane site ?  note the oil stain on the plow quadrant area ?  personally think a lubrication soak down would be the perfect patina for that period  horse . let the oil do all the work , penetrating oil  soak down spray / for days weeks , prefer in a sunny area , for metal heating , wipe down with a clean cloth , mineral oil , same soak  thought , brought out  perfect patina with electric palm buffer , mild cleaning wax , maintain that with  periodic  light oil rub down , pete
peter lena
Posted (edited)
Edited by peter lena
repetition of reply
peter lena
@PWL216   like a chain and cable lubricant  , napa , MACKS  cable spray , also use chain and cable spray inside of all my  closed car areas ?  in a couple of days , there will be a related track on / in lower door seaming , wheel wells , thats a great leader  for heavier  open gear lube tracking , stops rust , pete
  • Thanks 2
rjg854
Looks like it's all there, should keep you busy for a while.  Ya gonna leave it as is or shine it up?
WHX??
I was hoping you would chime in with all there. Looks to be unmolested to boot.
Leave as is fer sure ... patina to die for.
A guy I sold a tractor to last year at portage has it and currently does not run. Kohler so shouldn't take much to get it running right?
This guy collects but if it doesn't run sends them on. To me getting them running is all the fun.
  • Excellent 4
ebinmaine
BBT will tell ya, if it turns over and has any compression, it will run. It's a Kohler.
Ed Kennell
All 4 grandsons are out of college and employed so we are planning to take them and their parents on a cruise to Alaska.     So we went to the Post Office to get new mug shots and applications to renew our passports.     I got a case of sticker shock.    Over $300 to renew two existing passports.    :angry-banghead:
  • Sad 2
