rjg854 12,630 #8551 Posted July 21 1 hour ago, cleat said: I had that problem a couple of years ago. That kind of job isn't pleasant, glad to see it wasn't a lot worse. Had to have a whole new septic system 2 years ago. Because I have to use salt to control the iron in the water, it eventually ate the concrete septic tank up. Now systems here in my area all have to be engineered systems because we have so much clay and it doesn't perk well. Expensive!!! 4 Share this post Link to post Share on other sites
cleat 8,078 #8552 Posted July 21 2 hours ago, rjg854 said: That kind of job isn't pleasant, glad to see it wasn't a lot worse. Had to have a whole new septic system 2 years ago. Because I have to use salt to control the iron in the water, it eventually ate the concrete septic tank up. Now systems here in my area all have to be engineered systems because we have so much clay and it doesn't perk well. Expensive!!! My water softener goes out to the road ditch out front as does the washing machine. No septic company would even look at my septic system for repair. The only option is a new system as they need to bring it up to the latest code ($$$). Made my $100.00 repair seem good. I have very sandy soil so drainage is not an issue. 2 Share this post Link to post Share on other sites
Ed Kennell 43,791 #8553 Posted July 21 42 minutes ago, cleat said: My water softener goes out to the road ditch out front as does the washing machine. No water softener, but my gray water goes down the gravel road to the state road. Eco friendly for sure....diluting the tons of salt PENDOT sprays on the road. 2 Share this post Link to post Share on other sites
HyperPete 886 #8554 Posted July 21 (edited) More flowerbeds for Donna. Flat shovelling grass is no fun! Edited July 21 by HyperPete 2 Share this post Link to post Share on other sites
PWL216 1,134 #8555 Posted July 21 Replaced the electric window motor on the drivers side door of my Frontier. The old mechanism’s cable was frayed and got stuck in the motor wheel and eventually just kept the window in the down position. IMG_2712.mov 1 Share this post Link to post Share on other sites
peter lena 9,559 #8556 Posted July 21 @Mickwhitt went over a throttle linkage hiccup , turned out it was a tye wrap , just glancing on the linkage , wiring must have moved over time , as it settled in , hindering full smooth action , while there also found some other areas to enhance . my mower decks turn with ease , at the mule drive , belt point , by hand , also ex condition of belts , no fraying or cracking . since going after my related pulleys , for lubrication up grade , been years now , no pully whine , and engagement is smooth and easy . put a drop of super lube hydraulic , lube on my heim joints , and cable end drip access , all move with smooth ease . topped up fuel , and added an ounce of STA BIL fuel additive , absolutely stops fuel hose break down . experiment that works , eliminated all related old fuel hose , replace with new , then started using STA BIL , filters are always clean / clear , no debris in fuel bowl or tank , instant starts , pete 1 Share this post Link to post Share on other sites
adsm08 3,869 #8557 Posted July 21 On 7/20/2025 at 8:45 AM, cafoose said: Most shower valves have an anti scald device that needs to be adjusted for hotter water. This was it. I messed with it a bit tonight before hopping in after work and got to take a nice hot shower. I even have a little head space on the heat now. 2 1 2 Share this post Link to post Share on other sites
cafoose 3,524 #8558 Posted July 21 1 hour ago, adsm08 said: This was it. I messed with it a bit tonight before hopping in after work and got to take a nice hot shower. I even have a little head space on the heat now. I've installed a few of those myself and if no kids are using the shower I've even removed the hot water limiter completely and it got super hot if I wanted it to. 2 Share this post Link to post Share on other sites
adsm08 3,869 #8559 Posted July 21 Just now, cafoose said: I've installed a few of those myself and if no kids are using the shower I've even removed the hot water limiter completely and it got super hot if I wanted it to. I don't think I need to remove it. It gets plenty hot right now, and I may actually move it back a click because I do have kids using the shower. 3 Share this post Link to post Share on other sites
ebinmaine 75,775 #8560 Posted July 22 The recently purchased Horses Hauler trailer got some dandy new DOT Conspicuity Tape. The back of the fenders, sides of the fenders, and rear tailgate area all have added visibility. I added 4 vertical stripes and a horizontal stripe to the gate. The gate is 1" square tubing. The tape is nearly 2" wide. The sides have two directional sight. The bottom of the gate has tape visible while the gate is upright or laying down in the trailer. With flash to show reflection. This: ..... is a product called King Starboard. It's a high density poly something that is marketed to the salt water boat industry. My thought here is to attach a 1" wide strip to the back of the top of the gate which is the part that hits the ground when the gate drops. I was able to use the square and razor to repeatedly score the surface followed by snapping the 1" strip off the edge. To hold it on the trailer I'm thinking of using several self tapping flat pan screws. Other suggestions welcome. 2 1 Share this post Link to post Share on other sites
8ntruck 8,346 #8561 Posted July 22 @Pullstart - i'm trying to send you a PM. Red Square says you cannot receive messages. Share this post Link to post Share on other sites
MainelyWheelhorse 2,246 #8562 Posted July 22 5 minutes ago, ebinmaine said: To hold it on the trailer I'm thinking of using several self tapping flat pan screws. Other suggestions welcome. Countersunk flat head screws? 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,246 #8563 Posted July 22 @ebinmaine Stainless or a rust treated screws that aren’t Phillips might be a good idea too so they aren’t rusted into the ramp later. 1 Share this post Link to post Share on other sites
ebinmaine 75,775 #8564 Posted July 22 7 minutes ago, MainelyWheelhorse said: Stainless or a rust treated screws Excellent point 1 1 Share this post Link to post Share on other sites
lynnmor 8,259 #8565 Posted July 22 19 minutes ago, ebinmaine said: The recently purchased Horses Hauler trailer got some dandy new DOT Conspicuity Tape. The back of the fenders, sides of the fenders, and rear tailgate area all have added visibility. I added 4 vertical stripes and a horizontal stripe to the gate. The gate is 1" square tubing. The tape is nearly 2" wide. The sides have two directional sight. The bottom of the gate has tape visible while the gate is upright or laying down in the trailer. I have a neighbor about 1/4 mile away with that tape on a trailer. He parks it in a way that headlights shine on it, annoying as hell. 1 Share this post Link to post Share on other sites
Handy Don 15,205 #8566 Posted July 22 (edited) 26 minutes ago, 8ntruck said: @Pullstart - i'm trying to send you a PM. Red Square says you cannot receive messages. Click on @ebinmaine here in this text and then choose “Message” It’s a quirk in the forum software that you cannot just create new messages. from the inbox--I suspect it might be part of “anti-hacking” protection. Edited July 22 by Handy Don 1 Share this post Link to post Share on other sites
ebinmaine 75,775 #8567 Posted July 22 10 minutes ago, lynnmor said: I have a neighbor about 1/4 mile away with that tape on a trailer. He parks it in a way that headlights shine on it, annoying as hell. Works good..... as long as the other driver is actually paying attention. Share this post Link to post Share on other sites
WHX?? 53,350 #8568 Posted July 22 Window shopped & made an offer for a 854. 'Tis my belief everyone should have one ... who am I to argue with myself? Better to ask forgiveness right?? 'Sides Dan came and got his tractors so got a couple open stalls ... 1 7 Share this post Link to post Share on other sites
peter lena 9,559 #8569 Posted July 22 @WHX?? hiding in plane site ? note the oil stain on the plow quadrant area ? personally think a lubrication soak down would be the perfect patina for that period horse . let the oil do all the work , penetrating oil soak down spray / for days weeks , prefer in a sunny area , for metal heating , wipe down with a clean cloth , mineral oil , same soak thought , brought out perfect patina with electric palm buffer , mild cleaning wax , maintain that with periodic light oil rub down , pete 1 Share this post Link to post Share on other sites
peter lena 9,559 #8570 Posted July 22 (edited) @WHX?? hiding in plane site ? note the oil stain on the plow quadrant area ? personally think a lubrication soak down would be the perfect patina for that period horse . let the oil do all the work , penetrating oil soak down spray / for days weeks , prefer in a sunny area , for metal heating , wipe down with a clean cloth , mineral oil , same soak thought , brought out perfect patina with electric palm buffer , mild cleaning wax , maintain that with periodic light oil rub down , pete Edited July 22 by peter lena repetition of reply Share this post Link to post Share on other sites
peter lena 9,559 #8571 Posted July 22 @PWL216 like a chain and cable lubricant , napa , MACKS cable spray , also use chain and cable spray inside of all my closed car areas ? in a couple of days , there will be a related track on / in lower door seaming , wheel wells , thats a great leader for heavier open gear lube tracking , stops rust , pete 2 Share this post Link to post Share on other sites
rjg854 12,630 #8572 Posted July 22 10 hours ago, WHX?? said: Window shopped & made an offer for a 854. Looks like it's all there, should keep you busy for a while. Ya gonna leave it as is or shine it up? Share this post Link to post Share on other sites
WHX?? 53,350 #8573 Posted July 22 Just now, rjg854 said: Looks like it's all there, should keep you busy for a while. Ya gonna leave it as is or shine it up? I was hoping you would chime in with all there. Looks to be unmolested to boot. Leave as is fer sure ... patina to die for. A guy I sold a tractor to last year at portage has it and currently does not run. Kohler so shouldn't take much to get it running right? This guy collects but if it doesn't run sends them on. To me getting them running is all the fun. 4 Share this post Link to post Share on other sites
ebinmaine 75,775 #8574 Posted July 22 1 hour ago, WHX?? said: Kohler so shouldn't take much to get it running right? BBT will tell ya, if it turns over and has any compression, it will run. It's a Kohler. 2 Share this post Link to post Share on other sites
Ed Kennell 43,791 #8575 Posted July 22 All 4 grandsons are out of college and employed so we are planning to take them and their parents on a cruise to Alaska. So we went to the Post Office to get new mug shots and applications to renew our passports. I got a case of sticker shock. Over $300 to renew two existing passports. 2 Share this post Link to post Share on other sites
