Oldskool 6,582 #76 Posted March 11, 2020 Ok guys. I may have found an engine. Kohler 14hp 321SA. It's in an old Case. Is this going to fit the GT? I read somewhere the "S" is for special sump. So just not sure. Also is the output shaft the same dia? Share this post Link to post Share on other sites
953 nut 51,775 #77 Posted March 12, 2020 1 hour ago, Oldskool said: Is this going to fit the GT? I read somewhere the "S" is for special sump. The "S" tells you the engine is equipped with an electric starter. Find out the Spec. # of the engine you are looking at and one of us can look it up to see what you are getting into. 1 Share this post Link to post Share on other sites
Oldskool 6,582 #78 Posted March 12, 2020 3 minutes ago, 953 nut said: The "S" tells you the engine is equipped with an electric starter. Find out the Spec. # of the engine you are looking at and one of us can look it up to see what you are getting into. Thanks. I may buy it either way. Also curious as to how many lbs per sq. in the compression should be. Not looking to buy another basket case engine Share this post Link to post Share on other sites
ebinmaine 63,214 #79 Posted March 12, 2020 24 minutes ago, Oldskool said: Thanks. I may buy it either way. Also curious as to how many lbs per sq. in the compression should be. Not looking to buy another basket case engine Many Kohler engines can only be tested by leakdown. The ACR prevents a compression test from working. 1 Share this post Link to post Share on other sites
Oldskool 6,582 #80 Posted March 12, 2020 Thanks. Wasn't thinking the older engines had the compression release. Guess I'm borrowing a leak down tester Share this post Link to post Share on other sites
ebinmaine 63,214 #81 Posted March 12, 2020 Not sure ALL the 14/16 engines had em. 1 Share this post Link to post Share on other sites
oldredrider 2,547 #82 Posted March 12, 2020 If the engine you found is a K-321AS, it will not be a direct fit. It would have the narrow base oil pan and use the cradle mount, like a late 70's thru early 80's Wheel Horses. 1 Share this post Link to post Share on other sites
Oldskool 6,582 #83 Posted March 12, 2020 4 minutes ago, oldredrider said: If the engine you found is a K-321AS, it will not be a direct fit. It would have the narrow base oil pan and use the cradle mount, like a late 70's thru early 80's Wheel Horses. Is the output shaft the same size? Share this post Link to post Share on other sites
oldredrider 2,547 #84 Posted March 12, 2020 You would need the engine spec # or actual measurement to know. 2 Share this post Link to post Share on other sites
Oldskool 6,582 #85 Posted March 12, 2020 The guy sent these pics of the tag today. I hope these help 1 Share this post Link to post Share on other sites
Oldskool 6,582 #86 Posted March 12, 2020 Here is the tag off the GT's engine. I hope there is good news Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #87 Posted March 12, 2020 Kohler made the K321AS-60410 for Ingersoll Equipment in 1983 Kohler made the K321S-60125B for Wheel Horse in 1970 The serial numbers are used to determine the year of Kohler manufacture. Garry 1 Share this post Link to post Share on other sites
Oldskool 6,582 #88 Posted March 12, 2020 1 minute ago, gwest_ca said: Kohler made the K321AS-60410 for Ingersoll Equipment in 1983 Kohler made the K321S-60125B for Wheel Horse in 1970 Garry Will the 60410 fit in place of the 60125B? Share this post Link to post Share on other sites
pfrederi 17,147 #89 Posted March 13, 2020 Not directly if it is the small oil pan, and you can't just swap pans, the base of the block is different . Look at the pinned post in the engine forum Identifying big block Kohler blocks. I will take a couple pics later of how i put the AS style engine on an Electro. 1 Share this post Link to post Share on other sites
Oldskool 6,582 #90 Posted March 13, 2020 57 minutes ago, pfrederi said: Not directly if it is the small oil pan, and you can't just swap pans, the base of the block is different . Look at the pinned post in the engine forum Identifying big block Kohler blocks. I will take a couple pics later of how i put the AS style engine on an Electro. I just put eyes on the engine. Now I see the difference. It looks like I might be able to modify the mounting plate to make it work. Any body know if it's going to be troublesome getting the hydraulic pump off the shaft? Share this post Link to post Share on other sites
pfrederi 17,147 #91 Posted March 13, 2020 There is no engine plate on a GT14. The frame rails are further apart which will make getting the drop down part of oil pan in place easier than on the Electro but may cause a slight alignment issue with your drive pulley. For spacers I used the ones that came with K181 engines on shaker mounts. plus 3 washers. What hydro pump are you talking about? 1 1 Share this post Link to post Share on other sites
Oldskool 6,582 #92 Posted March 13, 2020 44 minutes ago, pfrederi said: What hydro pump are you talking about? The pump I am referring to is the pump on the Case mower that my donor engine would be coming from. It is mounted on the PTO side Share this post Link to post Share on other sites
pfrederi 17,147 #93 Posted March 13, 2020 Can't help with pump removal but you may have a bigger issue. The crankshaft is kind of short... Share this post Link to post Share on other sites
pfrederi 17,147 #94 Posted March 13, 2020 Also doesn't look like it is drilled for the electric PTO \This is the WH spec Crank 1 Share this post Link to post Share on other sites
Oldskool 6,582 #95 Posted March 13, 2020 35 minutes ago, pfrederi said: Also doesn't look like it is drilled for the electric PTO \This is the WH spec Crank Dang. Way more than I wanted to mess with. To top it all off I haven't heard it fire yet. I think I will keep looking for a differant engine. Thanks for your time and the info. 1 Share this post Link to post Share on other sites
pfrederi 17,147 #96 Posted March 13, 2020 2 minutes ago, Oldskool said: Dang. Way more than I wanted to mess with. To top it all off I haven't heard it fire yet. I think I will keep looking for a differant engine. Thanks for your time and the info. Here is what you need to do before you commit to any other replacement engine. Go to Kohler engine site for parts. https://www.kohlerenginesparts.com/ Look up the spec number in question. get the crankshaft part number then go to eh manuals section here download the crankshaft reference look up the crank number and you can see the various measurements. 1 1 Share this post Link to post Share on other sites
Oldskool 6,582 #97 Posted March 13, 2020 @pfrederi Again, thanks for the info. Looks like I may buy the Case anyways. It has a hydraulic pump on it along with a piston and valve. All useful things for future projects 1 Share this post Link to post Share on other sites
Pullstart 59,744 #98 Posted March 13, 2020 @Oldskool you could just simply pop a 22 hp Predator in there... @Aldon didn’t struggle too hard with it! 1 1 1 Share this post Link to post Share on other sites
Oldskool 6,582 #99 Posted March 14, 2020 26 minutes ago, pullstart said: @Oldskool you could just simply pop a 22 hp Predator in there... @Aldon didn’t struggle too hard with it! Good idea. That was an awesome build. Now I'm rethinking a few things 2 Share this post Link to post Share on other sites
WildmanC120 613 #100 Posted March 14, 2020 @richmondred01 always has some engines for sale. Rebuilt and ready to go. A predator 22hp swap is always fun too. I have one on my C-161 and its great. 2 Share this post Link to post Share on other sites
