Lee1977 7,499 #101 Posted March 5, 2020 1 hour ago, dells68 said: Hey EB. No I haven’t soaked it. It was so full of crud that looked like mud when I got it that it makes me wonder what the poor thing has been through! I found a new complete carb along with tuneup kit for $50 on fleabay, so I figured I’d give it a shot. The only thing about that carb is the fuel adjustment is plugged off like all other EPA compliant stuff. I’ll probably have to remove the cap to adjust it if needed. At least I know it runs, just not getting enough fuel to maintain a consistent idle. If you look into the throat of the carb, you can see a spray of fuel pulsing. Should be here next Mon and I’ll give it a shot! I had a Briggs Vanguard 16 back in the early 90's l coudn't get to run with out surging. I found out they made a jet for high altitude. The jet was removable on the early models screwed in. Changed the jet it was a lot better. I have a 2010 Briggs Vanguard 18, never had reason to look inside the carb. on it. 1 Share this post Link to post Share on other sites
dells68 7,499 #102 Posted March 5, 2020 1 minute ago, Ed Kennell said: Might be interesting to stick an electric pump in front of the carb? Might be an idea. It actually has a pulse pump on it. Could be the pump for sure. If the carb doesn’t fix it, I might try an electric pump! Share this post Link to post Share on other sites
Tractorhead 9,215 #103 Posted March 5, 2020 I‘m in with @Lee1977 while i watch your video, i can see the light movement on your Throttlelever on the right. but i see also the rhytmic movement on the governor and i believe to remind that the engine reacts to slow. Based on that and the reaction the Engine gives, it seems to me the carb runs to rich not to lean, like a continouse work in „choked“ operation. i believe - if i see it right- the blowbacks are just happened on throttle up movement by the governor, short before the Engine increases the speed. i would firstly check the nozzle, if it’s screwed type and all is clean below, maybe it loosing a bit, or maybe PO tryed to clean it with a nozzle needle or a to thick wire and bored it a bit in the diameter ( maybe one or two sizes) up without recognizes it. Or it is maybe as lee mentioned simply a wrong nozzle. the governor itself seems to work very smooth. 1 Share this post Link to post Share on other sites
Pullstart 68,602 #104 Posted March 5, 2020 To make sure it’s not a governor adjustment issue, you could disconnect it and operate the throttle manually for a bit 1 Share this post Link to post Share on other sites
19richie66 17,770 #105 Posted March 6, 2020 Make sure the “atmospheric vent” on the pulse pump isn’t plugged with dirt. They get jam packed with crud and then the valves inside the pump can’t “breathe” 1 1 Share this post Link to post Share on other sites
dells68 7,499 #106 Posted March 7, 2020 Well, add a little surge be gone and this is what you get! I put on a new $50 carb from flebay and off she went. Pretty darn smooth now! Nice smooth idle. Now, on with the rest... 1 6 Share this post Link to post Share on other sites
ebinmaine 76,466 #107 Posted March 7, 2020 52 minutes ago, dells68 said: Nice Sounds lovely Dell !! 1 Share this post Link to post Share on other sites
dells68 7,499 #108 Posted March 8, 2020 Just a little more tinkering tonight. I made covers for the belt and brake setup where they protrude into the tub. I also made an aluminum panel to cover some of the backed dash and drilled a place to mount the ignition switch. Here’s also a pic of the choke, throttle, and steering pin. 4 1 1 1 Share this post Link to post Share on other sites
Pullstart 68,602 #109 Posted March 9, 2020 Awesome work! Share this post Link to post Share on other sites
dells68 7,499 #110 Posted March 12, 2020 Had a chance a couple of nights ago to rub down the sheet metal with boiled linseed oil. I really like the colors that popped on the gas tank when I oiled it. I also used a rusty brown paint on the fender wells to age them without having to worry about rust getting all over me. I also made up my seat supports/plywood to get ready to foam and cover them. Getting there slowly! 5 6 Share this post Link to post Share on other sites
Pullstart 68,602 #111 Posted March 12, 2020 Quote 22 horses and counting . . . how many running, waiting to be picked up, or waiting on their turn in the shop - I don't have a clue. I've officially gotten to the collector phase of hoarding - I don't know how many we have now!!!! I like your signature update by the way! 2 Share this post Link to post Share on other sites
dells68 7,499 #112 Posted March 14, 2020 Another quick update. Since corona is here and we can’t really get out, I’ve worked on the horse a little. I pressure washed the tires I’m going to use on it and plan to tube the back ones later tonight. I had bought some foam and a Indian looking blanket to cover the seat with. Really wanted a Mexican blanket, it couldn’t find any locally, so this will have to do. I decided to shorten and widen the back a little. Here’s how it looked installed. I think it turned out ok. 2 6 1 Share this post Link to post Share on other sites
dells68 7,499 #113 Posted March 17, 2020 Looks like I’m going to have a little more time to mess around thanks to ole corona. I did manage to wrap the exhaust with heat wrap and fabbed up a guard for the fuel tank from old Ford 501 mower sections. And @pullstart I had to pay a little honor to you with only one headlight. Got that one off of the Cyclops 857 when I bought it. 4 4 Share this post Link to post Share on other sites
19richie66 17,770 #114 Posted March 17, 2020 Looking sick Dells...... in a good way 👍 I would even be tempted to name it the “Corona Cruiser” 1 6 Share this post Link to post Share on other sites
dells68 7,499 #115 Posted March 17, 2020 Just put the rear wheels and lights on. Here’s a rear view. Nice fat meats! 6 Share this post Link to post Share on other sites
Pullstart 68,602 #116 Posted March 17, 2020 I feel like we need a few shots from a couple feet back Dell! You’re starting to make these pics into Uncle Jim Special teasers! 1 4 Share this post Link to post Share on other sites
ebinmaine 76,466 #117 Posted March 17, 2020 54 minutes ago, 19richie66 said: Looking sick Dells...... in a good way 👍 I would even be tempted to name it the “Corona Cruiser” I worked with a fella at one point who had raced several different types of motorcycles over his years. He had a road racing motorcycle that was fully lettered for the Corona Race Team amongst other things. Wonder whatever happened to that machine.... 1 Share this post Link to post Share on other sites
dells68 7,499 #118 Posted March 17, 2020 Just took her out for the cerimonial run and found that I’m going to have to move or adjust my belt stop. Runs good, looks odd, and drives just as odd! Those front wheels lean with the flipped axle and spindles when you turn and boy are they a long way out! I’m going to adjust the belt stops now and I’ll post my results later. 2 7 3 Share this post Link to post Share on other sites
dells68 7,499 #119 Posted March 17, 2020 Just got done adjusting the belt stop and now she stops, shifts, and drives great! Here’s a video I took on my first drive out. I’ve toured with the idea of making a roadster windshield and cycle fenders for the front. After getting her out, I noticed that the spindles allow the wheels to tilt in a little when sitting straight. One of the spindles has been welded on before, so I don’t mind to cut and straighten them. What do you guys think? 3 4 1 Share this post Link to post Share on other sites
WHX?? 53,697 #120 Posted March 17, 2020 I think it pretty cool the way it sits!! Richie nailed it..... 2 hours ago, 19richie66 said: Looking sick Dells...… 1 1 Share this post Link to post Share on other sites
Pullstart 68,602 #121 Posted March 17, 2020 Me likely! 1 1 Share this post Link to post Share on other sites
rjg854 12,716 #122 Posted March 17, 2020 Lookin reeeaaal good 1 Share this post Link to post Share on other sites
dells68 7,499 #123 Posted March 17, 2020 @WHX24, sorry buddy had to change one thing - those tilted spindles. Pictures don’t show it real well, but in person and when driving it, the front wheels cambered in at the top like a swing axle bug when dropped down. One cut on each, a little leverage, rewelding, and voila the front wheels stand straight when looking out over the hood. I swear it made me feel like they were going to bend on up and lay the axle on the ground! Think I’m done — for now! 3 1 Share this post Link to post Share on other sites
WHX?? 53,697 #124 Posted March 17, 2020 I guess I can't tell from the pics Dells. ... kinda feel like I am getting the triple bird from those gas tank thingys out front! You need to paint them white like fangs.... hey ...then some red blotches like blood on them! .... boy could you have fun on 2 Share this post Link to post Share on other sites
Pullstart 68,602 #125 Posted March 18, 2020 59 minutes ago, WHX24 said: I guess I can't tell from the pics Dells. ... kinda feel like I am getting the triple bird from those gas tank thingys out front! You need to paint them white like fangs.... hey ...then some red blotches like blood on them! .... boy could you have fun on Are those from a sickle mower? You could add a bomber style mouth and teeth and pinup gal on this Corona Cruiser and keep the D Red... 1 1 Share this post Link to post Share on other sites
