AHS 1,703 #26 Posted February 5, 2020 8 hours ago, peter lena said: good pick up on that, i would do a thorough BASELINE SERVICE on it, take nothing for granted , and verify all functions. probably a shift boot ,along with a fluid change in the rear end. that deck is not safe to use , you can probably pick up a much better and safer one , from this site or locally. get some sea foam in the tank and flush out the crud. do a couple of hot oil changes to flush out the milky residue , a regular, with the wrong weight oil never totally heating up , 5-30 oil in winter ,does well, 30 wt rest of year. good luck with it , its worth saving , pete Ya, I was thinking about giving it an oil change, a tranny change. I don’t know what the shifter boot looks like. I ordered the choke cable a gas cap today.... the muffler is $247! Ooh, ouch! Anywhere else I can look? I checked eBay, but they want $100 for a rusted one! Share this post Link to post Share on other sites
ebinmaine 81,150 #27 Posted February 6, 2020 Are you looking to replace the muffler to stock or maybe do a stack... Or...? You could call A - Z and see what he says... The shifter boot is almost certainly cracked and garbage. Don't forget to raise the front of the tractor to get the transmission fluid past the center bolt hump. Share this post Link to post Share on other sites
peter lena 10,109 #28 Posted February 6, 2020 AHS, here is a member making mufflers , that you might check out, you could also add that to the WANTED site here . that shifter boot is under the shifter gate plate , about 9 $ on ebay / ammazon. remove the shifter knobs and 4 phillips corner screws , use grease or silicone grease on shift lever or the molded hole on boot , for easy installation. pete 1 1 Share this post Link to post Share on other sites
AHS 1,703 #29 Posted February 7, 2020 @ebinmaine What’s your weather? Not good up here, 28 degrees and freezing rain! I think I’m gonna have to get out the power king. 1 Share this post Link to post Share on other sites
ebinmaine 81,150 #30 Posted February 7, 2020 14 minutes ago, AHS said: @ebinmaine What’s your weather? Not good up here, 28 degrees and freezing rain! I think I’m gonna have to get out the power king. Yepp Same here in Portland. Of course we'll need pictures!!!!!!!! Share this post Link to post Share on other sites
balconio 606 #31 Posted February 7, 2020 On 2/5/2020 at 4:47 PM, AHS said: Ya, I was thinking about giving it an oil change, a tranny change. I don’t know what the shifter boot looks like. I ordered the choke cable a gas cap today.... the muffler is $247! Ooh, ouch! Anywhere else I can look? I checked eBay, but they want $100 for a rusted one! This might work, for the price ~$35 it might be worth trying (Stens 105-296: these are for 12hp Kohler's fitted to Cub cadet). The exhaust will exit towards the back instead of front. Not sure if clearance to the PTO lever would be an issue with the pipe facing backwards. 2 Share this post Link to post Share on other sites
AHS 1,703 #32 Posted February 8, 2020 13 hours ago, balconio said: This might work, for the price ~$35 it might be worth trying (Stens 105-296: these are for 12hp Kohler's fitted to Cub cadet). The exhaust will exit towards the back instead of front. Not sure if clearance to the PTO lever would be an issue with the pipe facing backwards. Or downwards? With the exit facing the frame... I’ll have to get dimensions on it first... that might work. Also @jimkemp made the muffler that I needed in the first picture! I asked him about it.. haven’t heard back yet. Share this post Link to post Share on other sites
AHS 1,703 #33 Posted February 8, 2020 18 hours ago, ebinmaine said: Yepp Same here in Portland. Of course we'll need pictures!!!!!!!! @ebinmaine I brought out the WH with the snow blower, and did up here in the yard where we park. Then I took it down by the road... slush and slush...the WH didn’t mind that too much!!💪 1 Share this post Link to post Share on other sites
ebinmaine 81,150 #34 Posted February 8, 2020 9 minutes ago, AHS said: dimensions I can measure the one I have on Patriot horse later. Makes a great stack or downturn. Just have to get the right length inlet pipe so as to clear the PTO or whatever you have there. Nice quiet deep tone. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,823 #35 Posted February 8, 2020 Just for reference, here is my C-105 with that muffler as a “stack”... 2 Share this post Link to post Share on other sites
Herder 2,356 #36 Posted February 8, 2020 19 hours ago, AHS said: @ebinmaine What’s your weather? Not good up here, 28 degrees and freezing rain! I think I’m gonna have to get out the power king. Power King!! 1 Share this post Link to post Share on other sites
ebinmaine 81,150 #37 Posted February 8, 2020 Kinda see it here.... Blue hooded one. Share this post Link to post Share on other sites
pfrederi 21,312 #38 Posted February 8, 2020 I have that muffler on two of my winter horses. 2 Share this post Link to post Share on other sites
ebinmaine 81,150 #39 Posted February 9, 2020 @The Tool Crib Randy didn't you get one of the above type mufflers for 20-something off the fleabay? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #40 Posted February 9, 2020 53 minutes ago, ebinmaine said: @The Tool Crib Randy didn't you get one of the above type mufflers for 20-something off the fleabay? Yes I did and I really am happy with it. Share this post Link to post Share on other sites
ebinmaine 81,150 #41 Posted February 9, 2020 55 minutes ago, The Tool Crib said: Yes I did and I really am happy with it. Can you PM or text me the link to that when get a minute? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #42 Posted February 9, 2020 15 minutes ago, ebinmaine said: Can you PM or text me the link to that when get a minute? 👍 Share this post Link to post Share on other sites
