Pullstart 70,525 #1 Posted February 1, 2020 I noticed that this 502 and the Commando 800 frames had different transmission mounting plates. @hcminis DJ you mentioned the plate you had cut for the 1045 that was waiting to be welded in. Does the plate get placed over the stamped ribs, or do they need to be pounded flat, or was that plate meant for flat mounting plates like my 502? Note one frame is currently upside down... but a perfect place for a photo op! 1 Share this post Link to post Share on other sites
ebinmaine 79,574 #2 Posted February 1, 2020 Several different ways of reinforcing the area nowadays. @pullstart Kevin what are you doing to help on your big long tractor. On Colossus I'll be using a brace or two and also a VERY heavy duty set of parallel bars as basically a secondary frame. It will run from the mid hitch point, bolt to the axle, to behind the rear tires. The hitch will be at the end of that. Share this post Link to post Share on other sites
Lee1977 7,698 #3 Posted February 1, 2020 Im sure some have used a full plate overthe newer transmission plate. I used two 1/4" x 1 1/2 " steel flat ground to between the ridges. Then braced back up to the frame. 6 2 Share this post Link to post Share on other sites
Pullstart 70,525 #4 Posted February 1, 2020 I guess in a way, I wasn’t looking for bracing suggestions, as much as the back full sized plate that DJ recently cut for his 1045.... in relation to sandwiching the big air gap stamped into the original plate? I believe he mentioned that his plate was cut from a Wheel Horse service advisory.... or whatever they were called. Share this post Link to post Share on other sites
Pullstart 70,525 #5 Posted February 1, 2020 2 hours ago, ebinmaine said: Several different ways of reinforcing the area nowadays. @pullstart Kevin what are you doing to help on your big long tractor. On Colossus I'll be using a brace or two and also a VERY heavy duty set of parallel bars as basically a secondary frame. It will run from the mid hitch point, bolt to the axle, to behind the rear tires. The hitch will be at the end of that. Contemplated just using 1/2 or 3/8” plate and bracing from there. 1 Share this post Link to post Share on other sites
ebinmaine 79,574 #6 Posted February 1, 2020 5 minutes ago, pullstart said: Contemplated just using 1/2 or 3/8” plate and bracing from there. Should be fine with that. That'll take care of any weak spots around the bolt holes. A part of the concern I've seen pics of is the area right at the corner. The angle braces would help that. Share this post Link to post Share on other sites
Lee1977 7,698 #7 Posted February 1, 2020 1 hour ago, pullstart said: I guess in a way, I wasn’t looking for bracing suggestions, as much as the back full sized plate that DJ recently cut for his 1045.... in relation to sandwiching the big air gap stamped into the original plate? I believe he mentioned that his plate was cut from a Wheel Horse service advisory.... or whatever they were called. I was just showing a different way to renforce the transmission mount. Others have used a heavy angle on each side bolted to the transmission and the side of the mount. I put the 1/4" x 11/2" strips on my 520 haven't installed the braces as yet . The flats could also be welded inplace, mine are just bolted. With your abilitys if it's realy busted up just cut it out and build a heaver one. Share this post Link to post Share on other sites
cafoose 3,754 #8 Posted February 1, 2020 Check this out: 1 Share this post Link to post Share on other sites
Stormin 9,988 #9 Posted February 1, 2020 Didn't notice any cracks when I rebuilt the C-121 Black Horse, or my C-125. But I now think I'll be taking a look sooner than later. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #10 Posted February 1, 2020 4 minutes ago, Stormin said: Didn't notice any cracks when I rebuilt the C-121 Black Horse, or my C-125. But I now think I'll be taking a look sooner than later. Be careful storm !! We dont ya hurt! 1 Share this post Link to post Share on other sites
Lee1977 7,698 #11 Posted February 1, 2020 3 minutes ago, Stormin said: Didn't notice any cracks when I rebuilt the C-121 Black Horse, or my C-125. But I now think I'll be taking a look sooner than later. None of mine were cracked either. I did it to my modified 312-8 first then did it to the other ones. Can't see to weld anymore I need them as bullet proof as posible. Share this post Link to post Share on other sites
roadapples 6,987 #12 Posted February 1, 2020 @daveoman1966 had a good fix... Share this post Link to post Share on other sites
hcminis 1,796 #13 Posted February 3, 2020 On 1/31/2020 at 9:35 PM, pullstart said: I noticed that this 502 and the Commando 800 frames had different transmission mounting plates. @hcminis DJ you mentioned the plate you had cut for the 1045 that was waiting to be welded in. Does the plate get placed over the stamped ribs, or do they need to be pounded flat, or was that plate meant for flat mounting plates like my 502? Note one frame is currently upside down... but a perfect place for a photo op! My frame does not have the stamped ribs. So the plate slid right down in and will be welded to the sides as well as top and bottom. I can laser cut more if needed. OR, could make the 2 separate pieces to go above and below the stamped ribs. Could even post a file/picture with dimensions if needed. 1 Share this post Link to post Share on other sites
Pullstart 70,525 #14 Posted February 3, 2020 3 minutes ago, hcminis said: My frame does not have the stamped ribs. So the plate slid right down in and will be welded to the sides as well as top and bottom. I can laser cut more if needed. OR, could make the 2 separate pieces to go above and below the stamped ribs. Could even post a file/picture with dimensions if needed. If you could put up your dimensions please, I should be able to cut a plate out. I was thinking too, maybe hacking the back off and building a 953/1054(/GT14?) style thick plate and calling it good. Share this post Link to post Share on other sites
hcminis 1,796 #15 Posted February 3, 2020 5 minutes ago, pullstart said: If you could put up your dimensions please, I should be able to cut a plate out. I was thinking too, maybe hacking the back off and building a 953/1054(/GT14?) style thick plate and calling it good. Here is the drawing. Let me know if you need anything else. 2 1 1 Share this post Link to post Share on other sites
hcminis 1,796 #16 Posted February 3, 2020 Here is the pdf file of service bulletin sent out from Wheel Horse Frame_Repair_C_300_400_500-SeriesServiceBulletin_WH61-90_425_880600_.pdf 2 1 1 Share this post Link to post Share on other sites
