Oldskool 6,678 #151 Posted January 26, 2020 I have a snow/dozer blade but apparently I am missing the pedal and linkage/s circled in this pic. Any info and close up pics would help. Thanks Share this post Link to post Share on other sites
wallfish 20,049 #152 Posted January 26, 2020 The blade that pedal is for is a Suburban Blade, so you'll need the special RJ adapter bracket which connects it to the tractor if you don't already have it. It's a factory bracket made for adapting the blade to the RJ and it hangs under the frame. The only thing that pedal does is pull on a chain to release a pin so the blade can index left and right. A small rope is used to pull the blade left and right. It's old skool technology for sure. I have posted measurements for that pedal before, can't remember if I still have one or not. The blade pictured earlier in this thread is the RJ blade and doesn't use that pedal. Share this post Link to post Share on other sites
Oldskool 6,678 #153 Posted January 27, 2020 @wallfish My blade looks like this one with the same 2 plate mounts to the frame but thats all I have. What makes it go up and down? Share this post Link to post Share on other sites
wallfish 20,049 #154 Posted January 27, 2020 That's the correct RJ blade. A solid link with 2 holes, it's connected to the lift with bolts. Post a pic of the blade and it's frame 1 Share this post Link to post Share on other sites
Oldskool 6,678 #155 Posted January 27, 2020 @wallfish I will get some pics of it tomorrow. Also I was wondering about a mowing deck. What year range would be correct? I found one that may be right but not sure and I don't have a pic of that either. One of the 90degree drives looks like a 2" pipe fitting. Sound rite? Share this post Link to post Share on other sites
wallfish 20,049 #156 Posted January 27, 2020 (edited) The one you pictured above about the pedal is correct. An RJ deck will have the deck engagement pedal right on the deck and have no wheels. You can see that on the lower left of the deck shell in the pic above. Pic also shows the correct belt guard for the deck. If you're after attachments, look for a CBR-32 Sickle bar, those are a cool attachment. You should go down to the big WH show in PA this coming June. You can find any and everything you want plus the stuff you didn't know you needed until you see it. Great show, great people, great time, guaranteed Edited January 27, 2020 by wallfish 1 Share this post Link to post Share on other sites
Oldskool 6,678 #157 Posted January 27, 2020 OK the one i found isn't the right kind of deck then. Ya I like the Sickle bar myself too I will keep my eyes open for one. Would love to go to a show but June is in my busy season. Thanks for the info Share this post Link to post Share on other sites
ebinmaine 79,154 #158 Posted January 27, 2020 11 minutes ago, Oldskool said: go to a show July at Owls Head Transportation Museum. Annual Truck And Tractor Show. 2 Share this post Link to post Share on other sites
Oldskool 6,678 #159 Posted January 27, 2020 That one I could do. It's been years since I have been there. 1 Share this post Link to post Share on other sites
ebinmaine 79,154 #160 Posted January 27, 2020 I'll keep you posted as to what's cooking but I'm pretty sure it's July 19 and 20 this year. I have family and friends that goes there. This will be the fifth year I think. Trina and I each bring a tractor. It would be awesome to get the Maine contingent there. You and I. @Stepney. @AHS. @JCM And whoever... 3 Share this post Link to post Share on other sites
Oldskool 6,678 #161 Posted January 27, 2020 Sounds like fun. The last time I was there was for a Street Rod show. If the turn out is anywhere near the same there ought to be alot. Share this post Link to post Share on other sites
ebinmaine 79,154 #162 Posted January 27, 2020 25 minutes ago, Oldskool said: Sounds like fun. The last time I was there was for a Street Rod show. If the turn out is anywhere near the same there ought to be alot. They attract semi trucks from all over New England and beyond. This year's theme is going to be military vehicles. That obviously has a unique draw by itself but everything else is more than welcome. Fantastic show. They are trying to draw more farm and garden tractors in. I would bring more if I had a way to haul them. I can only move two at a time. 1 Share this post Link to post Share on other sites
Ed Kennell 46,209 #163 Posted January 27, 2020 40 minutes ago, ebinmaine said: I would bring more if I had a way to haul them. I can only move two at a time. @pullstart Ya wanna show Eric how to move horses Kevin? 4 Share this post Link to post Share on other sites
Pullstart 70,105 #164 Posted January 27, 2020 1 minute ago, Ed Kennell said: @pullstart Ya wanna show Eric how to move horses Kevin? How many bumper pulls in a row are allowed in ME? I recall seeing some iffy loads in MN or WI popping up on here last summer? Maybe BBT needs to build EB’s car into a pickup... then I’ll be all over load tech tips! 1 Share this post Link to post Share on other sites
bottjernat1 2,196 #165 Posted January 27, 2020 (edited) 14 hours ago, wallfish said: That's the correct RJ blade. A solid link with 2 holes, it's connected to the lift with bolts. Post a pic of the blade and it's frame Here is my rj58 if this helps it has the factory blade setup except the adjustable height someone added. i was going to put it back to original but this kinda comes in handy! Edited January 27, 2020 by bottjernat1 1 Share this post Link to post Share on other sites
Stepney 2,357 #166 Posted January 27, 2020 I'm trying to save some extra off work time for shows, so maybe I could go .. I'll have that 2 place sled trailer and the truck so I could probably manage 3 WH's and the Maytag/a few engines.. 1 Share this post Link to post Share on other sites
ebinmaine 79,154 #167 Posted January 27, 2020 3 minutes ago, Stepney said: I'm trying to save some extra off work time for shows, so maybe I could go .. I'll have that 2 place sled trailer and the truck so I could probably manage 3 WH's and the Maytag/a few engines.. I think I've mentioned to you and I know I've told Jim, jcm. We go up and camp nearby for a couple nights. Anybody who wants to go would be welcome and we have a ton of gear so you really would not need to bring anything but you. Share this post Link to post Share on other sites
wallfish 20,049 #168 Posted January 27, 2020 6 hours ago, bottjernat1 said: Here is my rj58 if this helps it has the factory blade setup except the adjustable height someone added. i was going to put it back to original but this kinda comes in handy! Some of those were added on by dealers in late 59 when they came out on the 1960 models. Not sure if any were done from the factory but they could have. 1 Share this post Link to post Share on other sites
AHS 1,679 #169 Posted January 27, 2020 8 hours ago, ebinmaine said: I'll keep you posted as to what's cooking but I'm pretty sure it's July 19 and 20 this year. I have family and friends that goes there. This will be the fifth year I think. Trina and I each bring a tractor. It would be awesome to get the Maine contingent there. You and I. @Stepney. @AHS. @JCM And whoever... Ya! Cool! Share this post Link to post Share on other sites
ebinmaine 79,154 #170 Posted January 27, 2020 It's the 18th and 19th of July. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #171 Posted February 7, 2020 I am having sediment bowl issues on the RJ. I can't seem to come up with parts to rebuild mine or a correct replacement. Can someone point me in the right direction? Share this post Link to post Share on other sites
wallfish 20,049 #172 Posted February 7, 2020 you can buy a new one http://www.psep.biz/store/small_engine_fuel_filters.htm 1 Share this post Link to post Share on other sites
Oldskool 6,678 #173 Posted February 7, 2020 1 hour ago, wallfish said: you can buy a new one http://www.psep.biz/store/small_engine_fuel_filters.htm Ordered and on its way. Thank you @wallfish. Now maybe I can start driving this thing around without draining the tank when I'm done lol Share this post Link to post Share on other sites
Oldskool 6,678 #174 Posted February 13, 2020 The sediment bowl showed up. So maybe the RJ will be a little more trouble free 2 Share this post Link to post Share on other sites
Oldskool 6,678 #175 Posted March 15, 2020 In a day as good as this, horses have gotta run. 1 3 Share this post Link to post Share on other sites
