Pullstart 70,447 #276 Posted February 3, 2020 3 hours ago, oilwell1415 said: A fish plate would be OK, but blocks the holes in the frame if you ever may need them. It also doesn't add as much strength as you would think it does. But if you put it on the inside and then filled the holes with weld it would do a lot more for strength and clean up the sides of the frame if you know you will never need them again. What I was thinking was something like this. Adding to the flange of the frame rail increases strength exponentially because it is farther from the centerline of the frame. Angle iron also tends to initially fail because it either twists or bows out ward. Then once the initial failure starts the geometry gets worse and worse until it really fails and gets ugly. Adding a simple cross brace eliminates both of the likely initial failure modes (twisting and bowing out) and adding a little to the flange improves the straight bending strength of the frame rail. Wish I could reply many different times! HAHAHA! Love your drawing notes! HEART! Love your input on the design for strength! THUMBS/THANKS! Whether I understand your brains or not, having it down on print where I can read and chew and read again (out loud helps the most for me) and chew a bit more... is a big help! 3 Share this post Link to post Share on other sites
Pullstart 70,447 #277 Posted February 3, 2020 @oilwell1415 @wallfish @8ntruck Thank you for your inputs. @ebinmaine and me, we’ll be sittin’ back trying to practice our words so we can be wise some day too. In the meantime, we’ll be learning! 2 Share this post Link to post Share on other sites
ebinmaine 79,523 #278 Posted February 3, 2020 2 minutes ago, pullstart said: @oilwell1415 @wallfish @8ntruck Thank you for your inputs. @ebinmaine and me, we’ll be sittin’ back trying to practice our words so we can be wise some day too. In the meantime, we’ll be learning! I'm wise. Wise ahhhh. Wait maybe that's not what you meant. I can usually pull off a half-decent expression of intelligence at least once or twice a year. 3 Share this post Link to post Share on other sites
oilwell1415 563 #279 Posted February 3, 2020 I wouldn’t go so far as wise. I just went to school for so long I couldn’t help but pick up a few things. Honestly, I grew up in the country fixing stuff. I think the biggest thing I got from school was computer skills (I use that term loosely) and some fancy math. 1 1 Share this post Link to post Share on other sites
Pullstart 70,447 #280 Posted February 3, 2020 Say we meet in the middle? This would help support the welded area, but not get in the way of say a mid mount attachment, or snow plow if that were in the works some day? 2 Share this post Link to post Share on other sites
19richie66 17,928 #281 Posted February 4, 2020 There. Fixed it for you. 1 1 7 Share this post Link to post Share on other sites
953 nut 67,245 #282 Posted February 4, 2020 Richie, why did you put Kevin in the dump bed? 5 Share this post Link to post Share on other sites
wallfish 20,158 #283 Posted February 4, 2020 (edited) 1 hour ago, 19richie66 said: There. Fixed it for you. YEAH Now it looks like old school traction bars under there! He can always tow a trailer if he has to move some dirt Edited February 4, 2020 by wallfish 1 1 Share this post Link to post Share on other sites
Achto 32,035 #284 Posted February 4, 2020 4 hours ago, ebinmaine said: I don't want to know THAT it did something. I want to know WHY it did something... This reminds me of a statement from one of my teachers in high school. " If you know how to do some thing, you can get a job. If you know why you do it, you can be the boss. " 3 2 Share this post Link to post Share on other sites
wallfish 20,158 #285 Posted February 4, 2020 Since we're doing cartoons 6 Share this post Link to post Share on other sites
wallfish 20,158 #286 Posted February 4, 2020 21 minutes ago, 953 nut said: Richie, why did you put Kevin in the dump bed? Because of what he has him doing in there 4 Share this post Link to post Share on other sites
SylvanLakeWH 31,669 #287 Posted February 4, 2020 So... Remind me... This thread is about making cartoon drawings of a dude building bridges while drinking adult beverages in a dump bed while his daughter gets launched from a potato gun, with a stable frame? 4 Share this post Link to post Share on other sites
ebinmaine 79,523 #288 Posted February 4, 2020 2 minutes ago, SylvanLakeWH said: So... Remind me... This thread is about making cartoon drawings of a dude building bridges while drinking adult beverages in a dump bed while his daughter gets launched from a potato gun, with a stable frame? YYEESSS!!! 1 1 Share this post Link to post Share on other sites
ebinmaine 79,523 #289 Posted February 4, 2020 Hey where's that potato launcher being mounted?? 1 Share this post Link to post Share on other sites
ebinmaine 79,523 #290 Posted February 4, 2020 @19richie66 AWESOME Share this post Link to post Share on other sites
oilwell1415 563 #291 Posted February 4, 2020 3 hours ago, pullstart said: Say we meet in the middle? This would help support the welded area, but not get in the way of say a mid mount attachment, or snow plow if that were in the works some day? That will work. You just have to make sure the front half and back half are tied together at the mid point. On the rear diagonal it may be better to run if from the bottom rear to the top at the front to provide more support to the trans mount. Real world it probably won't matter, but if you're going to do it you should take advantage of everything you can get for the effort. 1 Share this post Link to post Share on other sites
8ntruck 9,021 #292 Posted February 4, 2020 (edited) Yup. As far as wisdom goes, please take everything I write with a grain or two of salt. Edited February 4, 2020 by 8ntruck 1 Share this post Link to post Share on other sites
8ntruck 9,021 #293 Posted February 4, 2020 (edited) Kev - just thought I'd throw another couple of cents worth of opinion into the ring. Probably too soon to talk about paint color, but, how about an MDOT theme? Orange, with yellow and green flashing lights, a belly plow underneath, and a salt spreader out back. After all, you do plow driveways..... Edited February 5, 2020 by 8ntruck 1 2 Share this post Link to post Share on other sites
ebinmaine 79,523 #294 Posted February 4, 2020 7 hours ago, oilwell1415 said: Real world it probably won't matter If it's built strong enough that it never matters... Excellent. That's EXACTLY what I'd be going for. 5 hours ago, 8ntruck said: please take everything I write with a grain or two of salt Mine is more like a Small container.... 1 Share this post Link to post Share on other sites
R. L. Addison 300 #295 Posted February 6, 2020 I would love to be able to build a project like this and have given it a lot of thought on certain areas of design. I am saving a few parts as I go along, ( D series axles valves & cylinders, & some other things that do not come to this feeble mind at this point) even knowing it can never materialize. I would never use a pawl parking lock on this type of project for my personal use, I would use the brake band type on the hydraulic drive motor as is used on later Sundstrand units. In my opinion it is much more practical, safer, and much more serviceable than the pawl type. I would use pawl only for double safety (with band type) and might be a good idea with children. Also would give option for individual wheel brakes. My ideal would be the D axles with a straight keyway for two hubs for dual wheels (6.00 - 12's) with the insides tires @ recommended pressure, & the outside tires @ less to relieve stress on the outside needle bearings in the final drive case. I would use Omco valves for the hydraulics as they have the open centers needed for the makeup flow for piston to piston pump in the hydrostat as needed and can be added if needed for later modifications if needed. Also with the piston to piston hydro, you would have the splined input shaft w/fan in pulley & no need for that pulley which is interfering with the tire. Could be more, but it is past bedtime & I hope to get up to clear sidewalks for schoolkids. R.A. 1 Share this post Link to post Share on other sites
Pullstart 70,447 #296 Posted February 6, 2020 5 hours ago, R. L. Addison said: I would love to be able to build a project like this and have given it a lot of thought on certain areas of design. I am saving a few parts as I go along, ( D series axles valves & cylinders, & some other things that do not come to this feeble mind at this point) even knowing it can never materialize. I would never use a pawl parking lock on this type of project for my personal use, I would use the brake band type on the hydraulic drive motor as is used on later Sundstrand units. In my opinion it is much more practical, safer, and much more serviceable than the pawl type. I would use pawl only for double safety (with band type) and might be a good idea with children. Also would give option for individual wheel brakes. My ideal would be the D axles with a straight keyway for two hubs for dual wheels (6.00 - 12's) with the insides tires @ recommended pressure, & the outside tires @ less to relieve stress on the outside needle bearings in the final drive case. I would use Omco valves for the hydraulics as they have the open centers needed for the makeup flow for piston to piston pump in the hydrostat as needed and can be added if needed for later modifications if needed. Also with the piston to piston hydro, you would have the splined input shaft w/fan in pulley & no need for that pulley which is interfering with the tire. Could be more, but it is past bedtime & I hope to get up to clear sidewalks for schoolkids. R.A. Thanks for your input! I too am on my way out to clear some snow... we finally achieved just barely 2” and the storm’s almost over. I’d like to know more about the brake band hub on later Sundstrand pumps, I wasn’t aware of them... Share this post Link to post Share on other sites
oilwell1415 563 #297 Posted February 6, 2020 Another brake option might be some go kart brakes. With all of the room inside those wheels you could probably make something work on the axles. You could probably get a pair of go kart band brakes for under $50. Share this post Link to post Share on other sites
Pullstart 70,447 #298 Posted February 6, 2020 57 minutes ago, oilwell1415 said: Another brake option might be some go kart brakes. With all of the room inside those wheels you could probably make something work on the axles. You could probably get a pair of go kart band brakes for under $50. My wheel adapters could could easily be fitted with drums... whether I use tractor/kart style bands, or even adapt some automotive backing plates and shoes... 1 Share this post Link to post Share on other sites
Stormin 9,988 #299 Posted February 6, 2020 Bands would be my choice. Simple, easy to make, easier to keep clean and less likely to seize up in adverse conditions. 1 Share this post Link to post Share on other sites
Pullstart 70,447 #300 Posted February 6, 2020 10 minutes ago, Stormin said: Bands would be my choice. Simple, easy to make, easier to keep clean and less likely to seize up in adverse conditions. Plus I might be able to support a vendor here... 1 Share this post Link to post Share on other sites
